quickmover
Comparing The 757 To The 707
Fri Nov 21, 2008 3:45 am
Just watching the old movie Airport. Are the 757 and 707 similar in size and range? I know the 57 would be much better on fuel, would this make the range in line with the 07?
Lexy
RE: Comparing The 757 To The 707
Fri Nov 21, 2008 3:49 am
757 fuselodge is a bit more narrow and it is shorter than the 707.
Range for the 757: maximum of 3,467nm
Range for the 707: maximum of 3,735nm
All range numbers are for loaded aircraft.
[Edited 2008-11-20 19:51:55]
Nashville, Tennessee KBNA
quickmover
Fri Nov 21, 2008 4:16 am
Thank you.
Surprising about the width though. I always thought the 707, 727, 737 and 757 were all the same width.
dalb777
Fri Nov 21, 2008 4:19 am
Quoting Lexy (Reply 1):
According to the Boeing website:
757
Wing span 124 ft 10 in (38.05 m)
Overall Length 155 ft 3 in (47.32 m)
Range 3,900nm (4,488 miles)
707 (367-80 Prototype (1954) )
Wing span 130 feet (39.6 m)
Overall length 128 feet (39 m)
Range 3,067 nm (3,530 miles)
707 (Advanced 707-320B)
Wing span 145 feet 9 in (44.42 m)
Overall length 152 feet 11 in (46.6 m)
Range 5,353 nm (6,160 miles)
The 757 is longer than both models of the 707. Width was not available where I got this 707 information.
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
quickmover
Fri Nov 21, 2008 4:30 am
Quoting Dalb777 (Reply 3):
Wow. The advanced version with almost twice as much range. There must be alot more fuel capacity on that type.
Max Q
Fri Nov 21, 2008 5:19 am
The 707 -320 series was flying long haul a long time before the first Widebodies appeared.
LHR-LAX, HKG-SYD were a few examples, she was a true long range aircraft, far more capable, distance wise than the 757 which really was developed as a medium range aircraft.
However the 75 had such growth capability, by default it has become a superb long haul aircraft for smaller city connections.
Of course the grand old 707 could fly a lot further, it was a lot heavier, and burned a lot more fuel to do that !
ovrpowrd727
Fri Nov 21, 2008 5:35 am
there are some videos on youtube that give great insight to the specs and performance of the 707s. those four tiny engines did a lot for the airframe, it basically brought the west coast to Europe.
http://www.youtube.com/watch?v=GatXdmPyx_A, this video is in 4 pieces and gives a great explanation to the whole project.
DocLightning
Fri Nov 21, 2008 9:08 am
Quoting Ovrpowrd727 (Reply 6):
"Malformed video ID."
Mind fixing that? Thx!
-Doc Lightning-
-Carl Sagan
Stealthz
Fri Nov 21, 2008 9:47 am
Not according to Boeing
707 & 757 both have an external width of 148 inches and internal dimension of 139.3 inches
Mender
Fri Nov 21, 2008 9:53 am
Is this for the front half or the back half of the aircraft?
Not many people notice the overall diameter of the fuselage is different on each half of the 757.
(Before someone corrects me, I know the width is the same but the diameter is different)
SEPilot
Fri Nov 21, 2008 10:37 am
Quoting Quickmover (Reply 4):
Yes, there was; but the real difference is much more powerful engines, which enabled it to carry more fuel.
Stealthz
Fri Nov 21, 2008 12:16 pm
Quoting Mender (Reply 9):
Not doubting you but this interests me and I am having trouble finding any documaentary evidence of this, certainly Boeings online info does not readily show this.
SEPilot
Fri Nov 21, 2008 12:39 pm
Quoting StealthZ (Reply 11):
Actually, I believe that almost all single aisle Boeing airliners have a dual lobe fuselage rather than cylindrical; the Stratocruiser and the Stratoliner show this most dramatically, but all of the single aisle jetliners follow the same pattern. It is just less dramatic and hardly noticeable.
Stealthz
Fri Nov 21, 2008 1:05 pm
Quoting SEPilot (Reply 12):
I understand that and the dimensions I quoted earlier were the max width, what I am having trouble finding is reference to different widths at front and rear half of aircraft as mentioned by Mender in reply 9
Mender
Fri Nov 21, 2008 1:08 pm
Look at a side on photograph of a 757 and you'll notice there is more ground clearance below the fuselage, forward of the wings than behind the wings. Thats because the overall diameter of the fuse is bigger behind that wing box.
Examples
http://www.airliners.net/photo/Tajik...C_&prev_id=1425012&next_id=1424975
http://www.airliners.net/photo/Avian...C_&prev_id=1425854&next_id=1425810
Stealthz
Fri Nov 21, 2008 2:14 pm
Mender,
The photos certainly look that way and the only data I can find shows that the rear cargo bay is approx 10" taller than than the forward one.
But to be really picky the original point was about the width not the height!
Neither the 707 or 757 is circular so discussions of diameter are moot.
Chris
PS still would like to see some hard data on the rear fuselage dimensions of the B757 though so if anyone can help it would be appreciated.
ovrpowrd727
Fri Nov 21, 2008 8:16 pm
i have the exact title of the movie flick
'Boeing 707-"Year One"-1960-Part l' that is the title of the video on youtube, the link i gave earlier in the forum is the link that is available but this is the exact title...hope you enjoy
Quoting DocLightning (Reply 7):
Viscount724
Fri Nov 21, 2008 10:34 pm
757-200 fuselage is actually about 8 ft. longer than the longest 707, the -320/420 although the overall length is only about 3 ft. longer due to different tail designs. But the 757 is not narrower than the 707. All Boeing narrowbody passenger aircraft from the 707 through the 757 have the same fuselage width. The fuselage height varies (707/720/757 fuselage is deeper top to bottom than the 727/737) but the width is the same. The Dash 80 prototype had a narrower fuselage than the production 707 as does the KC-135 tanker. The original 707 design was for 5-abreast economy class seating but the fuselage was widened to match the DC-8's 6-abreast design. I believe the 707 fuselage wound up 1 inch wider than the DC-8.
Quoting Max Q (Reply 5):
The 707-320 series was flying long haul a long time before the first Widebodies appeared.
The 707-320 was flying LAX-LHR nonstop with no problems starting in 1960 if not mistaken. When the 320B/320C (and comparable DC-8-50) with turbofans arrived a year or so later the range increased further. The original 707-120 was designed for US transcontinental range (JFK-LAX etc.) and even Pan Am's inaugural 707-120 flight from New York to Paris 50 years ago last month required a fuel stop at Gander.
The 707-320B/C carries almost twice as much fuel as the 757 and max. takeoff weight is about 30% greater.
ovrpowrd727
Sat Nov 22, 2008 4:36 am
Quoting Viscount724 (Reply 17):
How was that possible when the wing design on the 757 is better and the power on the 757 is greater...the 707 had 4 engines powering up to 17000lbs of thrust while the 757 has 2 engines going up to 43000lbs of thrust, i don't understand the aerodynamics of that. I'm referring to the weights of the two aircraft
Max Q
Sat Nov 22, 2008 7:56 am
The 707 320C carried approximately 160,000 pounds of fuel, the same incidentally as a 767 as against the 752's 75000 pounds
(or over twice the fuel load)
The 707 also weighed almost 100,000 pounds more than the 757, with gross weights approaching 350,000 pounds
Think of the 767 as the far more capable widebody successor to the 707, and the 757 as the much more capable successor to the 727.
The 757 is a relatively lightweight medium range aircraft, which, by virtue of it's in built growth capability and superb engines can be used for long haul.
The 707 is a genuine heavy, long range airliner and was always intended as such.
MD-90
Sat Nov 22, 2008 8:24 am
Quoting Ovrpowrd727 (Reply 18):
Wing area: 185m for the 757 and 283m for the 707-320.
Plus the 707 loses an engine on takeoff (18K or 19K on the -320, not 17K) and it still has 54K or 57K of thrust, which is more than any 757 on one engine.
ovrpowrd727
Sat Nov 22, 2008 3:56 pm
i stand corrected, i looks like age caught up with the classic, thx for clearing that up...i also took into consideration the fact that the fuselages were the same lengths so the space ahsn't changed ad all that plus the overall length etc.
seabosdca
Sun Nov 23, 2008 5:31 am
Quoting Max Q (Reply 19):
And the 767 can carry way more passengers and stuff significantly further on that load of fuel... there's progress for you.
Quoting MD-90 (Reply 20):
 checkmark  If you had tried to put a 57k engine on a 757, it would have been a very different airplane, and much less well suited for most of its missions.
Sun Nov 23, 2008 6:12 am
Quoting SEPilot (Reply 10):
The "B" and "C" 707s had Turbofans, while the others had Turbojets. This meant more power for much less fuel.
SilentJC
Sun Nov 23, 2008 8:39 am
The comma after ID threw the whole thing off. Enjoy.
Users browsing this forum: Max Q and 2 guests
