Mortyman
Fuselage Width DC 10 Vs MD 11
Mon Dec 15, 2008 4:51 pm
I know the MD 11 is longer than the DC 10, but what about the fuselage width . Is the DC 10 wider than the MD11 or is it only the lenght of the MD 11 that makes it look that way ?
The DC 10 looks fatter....
DC 10 - fuselage width 19 ft 9 in (6.02 m )
MD11 - ?
STT757
RE: Fuselage Width DC 10 Vs MD 11
Mon Dec 15, 2008 4:55 pm
smcmac32msn
Mon Dec 15, 2008 4:56 pm
Hey Obama, keep the change! I want my dollar back.
EMBQA
Mon Dec 15, 2008 5:00 pm
Both are the same......
CARST
Mon Dec 15, 2008 5:03 pm
DC-10:
http://www.boeing.com/commercial/airports/acaps/dc10sec2.pdf
Page 17: 602cm / 237in
MD-11:
http://www.boeing.com/commercial/airports/acaps/md11sec2.pdf
Page 16: 602cm / 237in
Both airplanes are using the same fuselage...
Mortyman
Mon Dec 15, 2008 5:07 pm
Thanx
But then my 1/500 scale model from Herpa of an Scanair DC 10 is seriously different from one of my MD 11 models... and I don't think it's just because the MD 11 is longer ... The DC 10 looks fat and heavy compared to the sleek MD 11.
Can Herpa really gotten the scale that wrong ??
TVNWZ
Mon Dec 15, 2008 5:11 pm
Quoting Mortyman (Reply 5):
Yes.
CARST
Mon Dec 15, 2008 5:15 pm
Quoting TVNWZ (Reply 6):
Yes.
Perhaps one of your models isn't 1:500... i had some other models too with the wrong size which didn't fit in the fleet of my other models.
Mortyman
Mon Dec 15, 2008 5:20 pm
Quoting CARST (Reply 7):
Says 1/500 on all the boxes to my various MD 11's and DC 10 models. I only have the one DC 10 model though.I had expected it to be shorter wich is was, but not that it would be so wide.. Maybe it's an optical illusion...
Mortyman
Mon Dec 15, 2008 5:48 pm
According to the boxes,both are 1/500
TVNWZ
Mon Dec 15, 2008 6:05 pm
You could measure the width and multiply by 500.
na
Mon Dec 15, 2008 6:07 pm
That are older models.
I have a Herpa DC-10 and MD-11 from the New Generation series built since about 2003. They fit together, fuselage width the same, just the nose of the DC-10 is odd.
These models are build in China, not every model is done right. After long years Herpa still doesnt get the grey belly right on the Lufthansa A330s/340s, and the freight door of the LH Star Alliance 744 is missing. Also the red on the Qantas 744 is different than the tone of the A380, wings colours are sometimes wrong and so on.
Rj111
Mon Dec 15, 2008 6:17 pm
Probably just an illusion from the different lengths, or the fact that the DC-10 is all white making the edges easier to see.
Why don't you try measuring the circumferance with a piece of string?
[Edited 2008-12-15 10:25:49]
rikkus67
Mon Dec 15, 2008 6:32 pm
Quoting RJ111 (Reply 12):
Excellent suggestion RJ111!
I build 1/144 models, and the revell vs. airfix 747-200 is astonishingly different.
AC.WA.CP.DL.RW.CO.WG.WJ.WN.KI.FL.SK.ACL.UA.US.F9
khobar
Mon Dec 15, 2008 7:38 pm
Quoting Rikkus67 (Reply 13):
Interesting. If you don't mind - in what way(s)?
EMBQA
Mon Dec 15, 2008 7:51 pm
Quoting Khobar (Reply 14):
Quality in the molds.....
Quoting Mortyman (Reply 9):
Here is the deal... in the real world the DC-10 and MD-11 both are 19'-9" wide. The quality of your models leaves a little to be desired. It's a model.. they are not exact....I have seen some models offered that look nothing like the real aircraft.. very poor copies. Some look pretty close. I have a large collection of Embraer factory models and see several things that are not exact... close, but working with these aircraft everyday I see as wrong.
To be honest.. looking at your overhead picture it looks more like an L1011 lines, so maybe they modified a mold. Look at the nose area. The SAS is all wrong.. closer to an L10 nose, then a DC-10 nose. The sweep on the wings is different on the SAS then on the KLM... look at the size of the Horz. Stab... the KLM looks to be much closer to correct size.
[Edited 2008-12-15 12:13:59]
timz
Mon Dec 15, 2008 8:20 pm
Quoting EMBQA (Reply 15):
Don't forget the actual DC-10 tailplane is 20% longer than the MD-11's.
EMBQA
Mon Dec 15, 2008 8:21 pm
Quoting Timz (Reply 16):
That I didn't know....Thanks
na
Mon Dec 15, 2008 9:41 pm
I think you are mistaken. I have superimposed DC-10 and MD11 longlense sideviews with minimum distorsion and beside detail modifications the tailfin of both are identical. No way there is such difference. The odd small fin on top of the rear part of the tail-mounted engine makes the MD11s tailfin is even longer than the DC10s!
But what exactly do you mean by that, 20% longer? The tailfin, no, cant be. And the tailcone of the MD-11 is longer than the DC-10s, not the other way around, thats easy to see.
smeg
Mon Dec 15, 2008 9:51 pm
Quoting NA (Reply 18):
I think that there is a confusion in terms here!
Horizontal stabiliser "wingspan" is smaller on the MD-11 than on the DC-10 in real life (by about 20%). This is also reflected on the photo of the models from above.
na
Mon Dec 15, 2008 9:55 pm
Ok, that I understand. Thank you. I thought you meant the whole tailsection.
FX1816
Mon Dec 15, 2008 11:13 pm
The only thing that I would add is that comparing models by Herpa can be quite difficult as I have a few in my collection and, no offense, but Herpa models are by far the lowest quality I have come accross. Try comparing Gemini or Dragon Wings DC-10's and MD-11's they would appear much closer in dimensions to eachother. Having worked around alot of DC-10's and MD-11's I can say that Dragon Wings does the best job making them with Gemini right there with them. Although my favorite now is the Hogan Wings 1/200 scale MD-11!!!
FX1816
TrijetsRMissed
Tue Dec 16, 2008 12:34 am
The No. 2 engine on the DC-10 is more sweptback and the MD-11 has the screwdriver tailcone, both of which are not clearly visible on the models. In short, not everything is 100% on the models, but the cabin width is the same.
There's nothing quite like a trijet.
DUALRATED
Tue Dec 16, 2008 12:44 am
Your dc-10 is taller than your MD-11 thats how you know the scales are off.
AIRLINERS.NET MODERATORS SUCK MOOSE DICK!!!!
FX1816
Tue Dec 16, 2008 1:38 am
Quoting DUALRATED (Reply 23):
They are the same scale, they are both 1/500 scale Herpa models but the older generation Herpa models did have quite visible inaccuracies.
FX1816
milesrich
Wed Mar 25, 2009 7:27 am
This topic should be changed to "Fuselage width on Herpa models of the DC-10 and MD-11." As several above pointed out, the fuselage is the same. The MD-11 is a little longer and is built with lighter weight materials. In all the years that McDonnell Douglas was a commercial air manufacturer, they really never designed a completely new airplane. All the MD-80's and 90's were based on the DC-9 plans. They just kept stretching it, putting in new avionics, glass cockpits, newere engines etc. I guess you could say the same thng about the DC-4,6,7 as they had the same wings and fuselage too. (The DC-7C had a new wing). First lengthened and pressurized and then re-engined with extra tanks. I never have figured out why the purchase price of a DC-7 was so much more expensive than a DC-6B. After all, even though those engines had the turbo compound compressors, the CW-3350 was developed for the P-38 and B-29, just as the PW 2800 was developed for the P-47, and other naval carrier planes.
CanadianNorth
Sat Mar 28, 2009 5:30 pm
In real life the fuselage widths should be the same. Solution here is get out a vernier and measure, then you'll know for sure. No thought process involved, just take a $20 crappy tire vernier and stick it on. Much more accurate than either eyeballing it or using a piece of string.
If the real world fuselage width is 237 inches as stated above, then a 1:500 model should measure approximately .474" wide.
CanadianNorth
HS-748, just like a 747 but better!
Users browsing this forum: FAST Enterprise [Crawler] and 1 guest
