AA777-200
Need Tech Info On 737-200 And -800 Asap!
Thu Dec 18, 2008 1:24 am
Hey I need help ASAP! Im at work right now and we have a charter coming in that was supposed to be a 737-200 and they upgraded it to a 737-800. I need the wingspans for both aircraft for parking! We DO NOT have a push back bar and need clearance for a turn out and I dont have time to look this up right now please! Thank you!
Brad
planesailing
RE: Need Tech Info On 737-200 And -800 Asap!
Thu Dec 18, 2008 1:27 am
737-800 - Wing span 34.31m (112ft 7in)
737-200 - Wing span 28.35m (93ft 0in)
Both from this website.
Stitch
Thu Dec 18, 2008 1:28 am
Per Boeing's ACAPS - the 737-200 has a span of 93 ft / 28.35m.
The 737-800 is 112ft 7in / 34.32m. With factory winglets, the span is 117ft 5in / 35.79m.
More data can be found at http://www.boeing.com/commercial/airports/737.htm
AA777-200
Thu Dec 18, 2008 1:35 am
Thank you!
filler
AA737-823
Thu Dec 18, 2008 4:07 pm
P.S.... you DO have a towbar.... it's the same as the 737-200!!!
AA777-200
Thu Dec 18, 2008 8:18 pm
We DONT have a towbar  Smile We do turn outs with the 737-200s also! The only towbars on the field are MD80 727 757 and A320. It ended up fitting perfect and turned out just fine. Just had to do a little tweaking on the parking spot. Thanks for the input though everyone!
Brad
vikkyvik
Fri Dec 19, 2008 12:38 am
Quoting AA777-200 (Thread starter):
Don't take this the wrong way, but it takes far less time to look it up on Boeing's website (or probably a hundred other sites....including this one) than it does to post about it and wait for a reply.
Fri Dec 19, 2008 12:34 pm
Quoting AA737-823 (Reply 4):
Don't be too sure....The towbar may be the same but the attachment can differ from operator.
some use the cross pin others use the lugs surrounding the crosspin  Smile
It happened here with IC/CD.
regds
MEL
AA777-200
Fri Dec 19, 2008 10:36 pm
I started to look it up on Boeings website but I couldnt find it and was busy with another flight at the time so I just gave up and posted for someone who might know or could find it faster than me.
Thanks everyone for the help and input though, I appreciate it!
Brad
Users browsing this forum: laser8 and 1 guest
