HT
Landing Speed: Avro And ERJ
Thu Jan 08, 2009 6:03 am
Inspired by the discussion following a ERJ-145 of BE overshooting STR's 10974 ft / 3345 m runway in winterly conditions a few days ago (no damages to speak of, no injuries), the following question came up:
What are the typical landing speeds of
a) the AVRO/BAe-146 series
b) ERJ-145
when there are no specific limitations (runway fairly long, no ice, no high winds, decent pax load ~ 80% LF) ?
Related question: Are there differences in procedures (i.e. different limitations) in flying into an airport with a ERJ-145 if equipped with Thrust Reversers resp. lacking those (as they are only optional on the ERJ145) ?
-HT
KAUSpilot
RE: Landing Speed: Avro And ERJ
Thu Jan 08, 2009 7:23 am
I have no experience with the BAe-146, so I cannot answer that aspect of your inquiry.
Vref (landing) speeds for the EMB-145 range anywhere from about 110-135 knots depending on aircraft weight. The final approach is typcally flown 5 knots faster than this, maybe 10 knots faster if gusty winds exist. If category II/III (low visibility) conditions existed, the landing speed would be even higher, as this requires a smaller flap setting to be used, but still no higher than 140 knots.
There are no penalties, at least at my operator for an inoperative thrust reverser. The landing performance charts do not account for T/R usage when depicting required/actual landing distances. After touchdown, the stopping distance is based only on the drag from landing flaps, fully extended ground spoilers, and maximum braking.
6000 ft is roughly the minimum required runway length for an EMB-145 to be dispatched to at sea level (assuming a landing at max weight), increasing about 2% per thousand feet of elevation. A 15% correction factor must be applied for a contaminated runway, such as snow or rain. Actual landing distance is about 2/3 of that, so between 3500-4000 ft. That figure increases by 15% for a contaminated runway, an additional 15% for low visibility (less thn 3/4 SM), and an additional 18% for a tailwind. Again, I can only vouch for procedues at the operator where I'm employed.
pilotpip
Thu Jan 08, 2009 8:39 am
Thrust reversers aren't taken into account in landing performance as KAUS pointed out.
The carrier I used to fly at had aircraft with and without T/Rs. No difference in numbers, however I ALWAYS used flaps 45 if the runway was wet or contaminated in the aircraft without them. If it was equipped with them I might consider flaps 22 if the conditions were favorable. While not considered in performance calculations, they do make a noticeable difference.
DMI
HT
Thu Jan 08, 2009 10:34 am
Thanks for the two replies.
Quoting KAUSpilot (Reply 1):
Not being a pilot myself, please allow me the following questions to understand this situation better:
Below which speed (= aircraft vs.the surrounding air) do flaps and spoilers become (almost) ineffective ?
If a runway is reported to have limited friction, how is "breaking power" being set before touchdown ?
Does it get set to "Max" or is some lower setting selected ?
-HT
ThePinnacleKid
Thu Jan 08, 2009 2:28 pm
Quoting HT (Reply 3):
The ERJ does not have an auto braking system... it's all accomplished with foot power by the pilot... (except for the parking brake which is a lever on the captain's side of the center pedestal)
"Sonny, did we land? or were we shot down?"
HT
Thu Jan 08, 2009 3:28 pm
Quoting ThePinnacleKid (Reply 4):
Thanks for the info. I was not aware of this fact.
-HT
glidepath73
Thu Jan 08, 2009 9:14 pm
Interesting! Might it be possible that at those overruns not enough brake power was applied?
Quoting Pilotpip (Reply 2):
Strange that the performance calculation is done on the same base as a/c with T/R's...
Anyway, thanks for those information's guys. Always happy landings to you!  Smile
Patrick
Aviation! That rocks...
pilotpip
Thu Jan 08, 2009 10:57 pm
Quoting Glidepath73 (Reply 6):
Performance figures are based on worst case scenario. Takeoff performance numbers are based on single engine ops but we usually use both of them  Wink
Autobrakes really don't have much to do with it. Antiskid will still limit the force if it's detecting wheels moving at different speeds. The ERJ is also brake by wire so the computer is still doing what it feels is best for what the user is asking it to do.
DMI
