ctrl_alt_del
777 With 3 Contrails
Thu Jan 08, 2009 9:32 am
http://www.flugzeugbilder.de/show.php?id=806977
Anyone know what the third contrail is? Air outlet valve?
keesje
RE: 777 With 3 Contrails
Thu Jan 08, 2009 10:02 am
APU
oly720man
Thu Jan 08, 2009 10:08 am
Would the APU be on during cruise?
It looks like something is venting from the bottom of the fuselage aft of the wing root fairing. There's a stream of condensation anyway.
ctrl_alt_del
Thu Jan 08, 2009 10:11 am
Hi Keesje,
Maybe my eyes are deceiving me but I don't think it's coming from the APU.
It appears to be well forward of the APU on the underside of the fuselage.
The APU is most likely off in this phase of flight.
TupolevTu154
Thu Jan 08, 2009 10:28 am
I'm no mechanic/engineer but that's not from the APU. It wouldn't be operational at that stage of flight. And as Oly720man said, there's definitely something being vented from the aft fuselage, possibly from the galley sinks.
HT
Thu Jan 08, 2009 10:53 am
Quoting TupolevTu154 (Reply 4):
Is this still common on modern airliners?
Is it only the fluids from the toilets that go into the waste water tank ?
At which location of the a/c does the consumed fraction of cabin air gets blown off / released ?
Would it contain enough moisture to form visible condensation ?
-HT
larspl
Thu Jan 08, 2009 11:21 am
the APU is usually not on, but certain operations/procedures could require the apu to be on. for example; if an engine generator is u/s it could be required.
however, in this case it looks like water from the galley or toilet sink.
facebook.com/ddaclassicairlines
Pihero
Thu Jan 08, 2009 11:37 am
Quoting Oly720man (Reply 2):
Spot on.
It's a water drain mast.
Contrail designer
FlyASAGuy2005
Thu Jan 08, 2009 1:05 pm
You can tell it's not the APU. The trail is coming from well under the fuselage.
What gets measured gets done.
Tristarsteve
Thu Jan 08, 2009 1:18 pm
Quoting LarSPL (Reply 6):
The B777 has two generators on each engine. The APU is not required for a generator failure.
Quoting Pihero (Reply 7):
Agreed. On the B777 there is a water drain valve in the line to each drain mast. It builds up a head of pressure then opens and releases a lot of water in one go.
Quoting HT (Reply 5):
The B787 is the first airliner to direct grey water into the waste tank. It has no drain masts.
ctrl_alt_del
Thu Jan 08, 2009 1:34 pm
Interesting.
How many kgs/lbs of water typically does a 777 carry/release on a trans-Atlantic flight?
Does the use of drain masts significantly reduce fuel consumption?
Tristarsteve
Thu Jan 08, 2009 1:46 pm
Quoting CTRL_ALT_DEL (Reply 10):
About 800kg on a daylight flight. Less on a night flight (the pax are asleep!)
Transpac787
Fri Jan 09, 2009 1:57 am
I'm no A&P by any means, but I do know that in some cases, a 777 *will* run the APU in flight. This past October I flew DME-ORD on an AA 777, and we were briefly delayed departing DME to get some additional fuel. In flight the captain came back and talked with my briefly (having hung out with the crew on the 2-day layover) and I asked him why we needed the additional fuel and he said because we would be running the APU the entire flight given some ETOPS restriction of some sort.
I have ~no~ idea what the restriction was - if there was an engine generator INOP or what - but I do know for a fact we ran the APU the entire flight from DME to ORD.
soon7x7
Fri Jan 09, 2009 2:48 am
I've often wondered what is eminating from the belly area of the aircraft. I live under the JFK approach from Europe and always notice the "third stream" venting off the tail cone even though I'm aware it is originating from the belly area...thought it was those last minute rushes to the lavatory which would not bode well as when I witness this I am usually at my sailboat and this discharge occurs over the waters I play in.  frown
tdscanuck
Fri Jan 09, 2009 3:56 am
Quoting TristarSteve (Reply 9):
If everything is normal, it's not required for system functions, but it certainly can be on and may have to be on in certain dispatch or ETOPS conditions.
TristarSteve is right, to the best of my knowledge. Only the 787 keeps its grey water on board. All other modern airliners drop grey water out a mast, whilbe black water (toilets) is held.
It goes out at the outflow valves...the location varies by aircraft type. Cabin air is pretty dry, so I suspect it doesn't cause condensation under most conditions, even with the large temperature drop. Even if it does cause condensation, the mass flow is hugely smaller than the engines so it might not be visible from far away.
That's a very interesting systems design problem. You save fuel by losing the extra weight, but you burn more by dragging the drain mast through the air. I suspect the optimum solution depends a lot on both your aerodynamics, your size, and your mission profile.
Tom.
pikachu
Fri Jan 09, 2009 5:38 am
"The B777 has two generators on each engine. The APU is not required for a generator failure."
You may wish to double check your QRH about what to do with the APU when you lose a generator...
AirbusA370
Fri Jan 09, 2009 12:04 pm
The A380 does that also, AFAIK.
This happens when you put your excessive coffee in the sink and not in the toilet:
http://www.flickr.com/photos/30247109@N00/2111278667/
gf777
Thu Jan 22, 2009 7:55 pm
Quoting Ctrl_alt_del (Thread starter):
This is the grey water system aft drain location.
This could be the Hydraulic air driven pumps which we have two of them in the 777 (left aft body fairing) and they operate as demand pumps if they needed.
True, the B777 has two generators in each engine, but one is buck up and can provide only 20 kVA for the essential loads (unlike the main generator which supply 120 kVA and the APU generator 120 kVA), so in case of one generator failure or engine failure the APU will be needed the whole flight. (the APU in B777 can provide electrical power at any altitude and pneumatic power up to 22,000 feet)
dragon6172
Fri Jan 23, 2009 1:53 am
In the words of Cousin Eddie...."Sh@#$er was full!!"
Have you all checked yours?
Phrogs Phorever
Users browsing this forum: BoeingGuy and 2 guests
