legoguy
Boeing 787 Engines
Thu Jan 15, 2009 5:06 pm
The Boeing 787 will feature engines from both Rolls Royce and General Electric and both as far as I am aware feature the triangular chevrons on the trailing edge of the engine cowling. These chevrons are quite interesting to me. Rolls Royce will also be producing an engine for the A350 XWB (the Trent 1000 XWB?) yet as far as I am aware, the engine will not feature the chevrons. Why is this? Is the Chevron design a Boeing development or engine manufacturer development?
Also, I'm not sure if this is still the case but I believe the engines on the 787 will be one colour as multiple colours would lead to layering of paint layers and the edges would cause extra drag. Again is this a Boeing development to reduce drag or is it an engine manufacturer development again?
Dave
Can you say 'Beer Can' without sounding like a Jamaican saying 'Bacon'?
Tristarsteve
RE: Boeing 787 Engines
Thu Jan 15, 2009 5:30 pm
I don't know for sure but, the engine cowlings are usually produced by the airframe manufacturer, and not the engine manufacturer. So the chevrons on the B787 are a Boeing design which is why they feature on both engine types.
A10WARTHOG
Thu Jan 15, 2009 6:42 pm
Quoting Legoguy (Thread starter):
If the customer wants more than one color or wants a logo on their cowls, I would guess that Boeing will do it.
kappel
Thu Jan 15, 2009 8:43 pm
Quoting TristarSteve (Reply 1):
I believe the E-jets also have this feature on the engines. From what I've read, these chevrons decrease noise levels, but also increase drag.
L1011,733,734,73G,738,743,744,752,763,772,77W,DC855,DC863,DC930,DC950,MD11,MD88,306,319,320,321,343,346,ARJ85,CR7,E195
UAL747
Thu Jan 15, 2009 10:49 pm
Quoting Kappel (Reply 3):
If this is indeed the case, I can hardly see why it would be beneficial. I doubt these chevrons actually reduce noise enough to make it something that airlines would consider over decreasing drag. If this is indeed the case, then I doubt we will see them on airliners.
UAL
Thu Jan 15, 2009 11:15 pm
Quoting UAL747 (Reply 4):
I think airlines are quite willing to increase fuel consumption in some cases. AFAIK SQ needed quieter engines on the 380 to operate at LHR. They took quite a steep fuel burn penalty to get them.
tdscanuck
Thu Jan 15, 2009 11:26 pm
It's a Boeing thing. They were running around on the Quiet Technology Demonstrator 777 a few years ago.
This was a change after some of the original livery concepts came out. Apparently, they figured out that if they got the nacelle smooth enough they could preserve laminar flow for a lot longer and make a noticeable drag improvement:
http://www.azom.com/news.asp?newsID=5961
Quoting A10WARTHOG (Reply 2):
I'm not sure that that's the case...they might be able to do it if they agree to accept the fuel burn hit, but that might throw off the performance numbers and force Boeing to do a separate set of documents, which they probably don't want to do.
If you're limited into an airport by noise, it's certainly beneficial. A little more fuel burn makes a lot more money than no flight. OEM's already speed a lot of money and manufacturing time on acoustic treatments for engine nacelles to control noise, this is just more of the same philosophy.
If it were all about fuel burn, they'd ditch the acoustic treatments on existing jets and save the weight.
Tom.
legoguy
Fri Jan 16, 2009 3:26 am
Thanks for the replies guys, everything mentioned helps to clear up my questions. As mentioned the Embraer 170/190 series seems to feature the triangular cherons but they look as if they are located on the exhaust rather than the outer cowling.
I didn't realize the engine cowlings were designed and built by the aircraft manufacturers themselves  Smile I did remember seeing an 777-300ER with chevrons as a test bed. I presume there are no plans on introducing the hcevrons to the GE 90 engines at any point in the future.
tdscanuck
Fri Jan 16, 2009 6:00 am
Quoting Legoguy (Reply 7):
To qualify that a little bit, they're usually designed by the aircraft manufacturer but often built by somebody else. There are a few companies with major expertise in this area: Middle River, Goodrich, Nordam (part of Goodrich now, I think), and Spirit.
Spirit used to be Boeing Wichita, so Boeing used to do some of their own, but I don't think Boeing has any in-house anymore.
The engine companies often want to stop their responsibility at the engine and let the airframer be responsible for integrating the engine with the airframe. The frequent exception is Rolls Royce, who has the entire engine/nacelle package on several airliners, but they typically subcontract the nacelle out.
Tom.
OPNLguy
Wed May 27, 2009 9:05 pm
I appreciate this thread, as I was kind of wondering about them, having recently received this picture:
http://i34.photobucket.com/albums/d143/OPNLguy/ScreenShot110.jpg
Anyone happen to know the significance of some wiring bundles being in red, and others in white?
brendows
Wed May 27, 2009 9:35 pm
Quoting OPNLguy (Reply 9):
IIRC the red wiring is part of the flight test equipment.
FTOHIST
Wed May 27, 2009 10:56 pm
The wires pictured are orange and are for flight test instrumentation--and there's not a whole lot of them if those bundles are in fact going inboard into the cabin. I'd expect more than that for engine flight tests (I'm assuming the airplane pictured is the RR 747 engine testbed).
JoeCanuck
Thu May 28, 2009 6:13 am
Is there any specific data about the fuel burn penalty of the chevrons?
What the...?
dynamicsguy
Thu May 28, 2009 7:19 am
Quoting FTOHIST (Reply 11):
I believe that is ZA001. The leading edge devices are definitely wrong for a 747.
OPNLguy
Thu May 28, 2009 12:02 pm
Another pix in the group that I received showed it as a RR engine on the 787..
http://i34.photobucket.com/albums/d143/OPNLguy/ScreenShot113-1.jpg
FTOHIST
Thu May 28, 2009 10:21 pm
Quoting Dynamicsguy (Reply 13):
OK, thanks. That explains the limited engine instrumentation....
tdscanuck
Fri May 29, 2009 3:59 am
It's orange, actually, the photograph is just a little off in colour. Orange = flight test.
Tom.
Users browsing this forum: Chris77M, Google [Bot], jarheadk5 and 1 guest
