N62NA
Dispatch Reliability Of AA 777s
Thu Feb 05, 2009 7:04 pm
In the past week I've flown two AA 777s:
AA Flight 56 MIA-LHR
AA Flight 57 LHR-MIA
Flight 56 was delayed about 45 minutes due to some kind of mechanical issue.
Flight 57 was delayed about 2 hours due to no heat in the cockpit, which meant that a valve had to be "taken" from "zone 2" and moved to the cockpit heating system.
When the 777 first came out, I remember reading an article in Airliners magazine that stated that in it's first year, the 777 had a 99%+ dispatch reliability record.
Was I just unlucky, or are the AA 777s, heaven forbid, sinking to the level of the AA A300 reliability?
How come I can't upload an avatar photo to my profile?
tdscanuck
RE: Dispatch Reliability Of AA 777s
Fri Feb 06, 2009 2:30 am
Quoting N62NA (Thread starter):
AA has 47 777's, so they're flying about 100 flights per day with their fleet. That means they should have about 1 maintenance delay per day on their 777's (with 99% dispatch reliability). So I think you're just unlucky, absent other info.
Tom.
LAXintl
Fri Feb 06, 2009 3:58 am
Well for the 12months ending 9/08, AA's annual 777 fleet reliabilty stood at 98.25% with an average daily utilization of 11.25hrs.
This is somewhat on the lower end of user experiences, and utilization. Industry average for the 12mos on the -200ER was 99.06%.
nycbjr
Fri Feb 06, 2009 6:25 pm
Quoting LAXintl (Reply 2):
99.06%.
really astonishing when you think of all the parts that have to work in unison, its quite an achievement!
cheers
 wave
N62NA
Sat Feb 07, 2009 1:53 pm
Then I must have been extremely unlucky (or lucky depending on how you view it) to have incurred those two delays last week!  Smile
tdscanuck
Sat Feb 07, 2009 9:01 pm
Quoting Nycbjr (Reply 3):
99.06%.
Keep in mind that quite a bit can be not working and still allow dispatch. I'd wager that very few airliners dispatch with all the parts working at the same time.
Tom.
nycbjr
Sun Feb 08, 2009 8:43 am
Quoting Tdscanuck (Reply 5):
right Tom didn't even think about that.. any good resources (online) that lists the things that can be iNop on aircraft?
Tristarsteve
Sun Feb 08, 2009 10:50 am
You have to be careful with these figures, the word reliability can mean different things to different folks.
We measure delays for technical reasons. This includes all aircraft that are late (And one minute late is late) due maint. Some of these are just that the technician was busy somewhere else and arrived late to sign off the aircraft! It does not include aircraft that are damaged. Bird strikes and lightning inspections don't count. For main base the figure is around 98.5pc, and on the line about 99.2pc(operated on time). Main base is lower because the MEL is more restrictive, and more work is carried out that can delay the aircraft.
i.e. a major IFE failure would be worked at main base, and a delay taken to fix it., while a line stn with no spares would not work it.
Also weather can affect the numbers! A lot of systems, antice, pitot heat, windscreen heat etc are allowable in the MEL in warm climates but not in the cold.
Reliability can mean number of flights operated, i.e. 99pc reliability means that 1 flight in 100 is canx.
The industry standard for delay reporting is flights that are over 15mins late.
It is very difficult to compare if you don't know the exact criteria used.
LAXintl
Sun Feb 08, 2009 11:54 pm
Quoting TristarSteve (Reply 7):
Numbers are by Boeing and cover overall dispatch reliability, not on time performance.
doug_or
Mon Feb 09, 2009 12:16 am
Quoting LAXintl (Reply 8):
so does 99% mean it goes out on time 99% of the time or it completes the flight 99% of the time?
When in doubt, one B pump off
tdscanuck
Mon Feb 09, 2009 3:17 am
Quoting Nycbjr (Reply 6):
Indeed there is. The document you're after is the MMEL (Master Minimum Equipment List) and they're all online here (for FAA-certified aircraft):
http://fsims.faa.gov/PICResults.aspx?mode=Publication&doctype=MMEL
If you've never looked at one before, you should read the intro that explains what the columns and codes mean. Basically, the first column identifies the item by ATA code, the second column shows how many items are installed, the third shows how many need to be working, and the fourth provides notes.
Quoting Doug_or (Reply 9):
It means it leaves on time (within 15 minutes) 99% of the time. Completion percentage is a different measurement. Many airlines are shifting from dispatch reliability to availability, since that's a better measure of airplane reliability.
Tom.
Users browsing this forum: CrackInspector and 2 guests
