mozart
Boeing 707 On A 5,900ft Runway?
Mon Feb 16, 2009 11:18 am
In another thread I read about the Shah of Persia using his 707 into Samedan airport in Switzerland. That airport has a runway length of 5,900 ft (and on top of that difficult terrain, altitude of 5,600 ft).
I don't know which version of the 707 the Shah was using, but still this looks like a big bird for a small airport to me. How close does that get to the 707's performance limits? Maybe it only worked because this was a VIP version operating at less than MTOW? Maybe on the way out of Samedan the plane was severely range-restricted and had to make a fuel stop somewhere?
Any comments and explanation on how challenging such a flight must have been would be very welcomed.
zappbrannigan
RE: Boeing 707 On A 5,900ft Runway?
Mon Feb 16, 2009 11:44 am
Can't speak specifically for the 707, but that's plenty enough runway if the right conditions are met - not least of which being TOW. I've been up front on a B738 departure, exact same runway length, with a full pax load and a reasonable amount of fuel on board. I imagine that 707 wouldn't be anywhere near MTOW.
oldtimer
Mon Feb 16, 2009 1:27 pm
Lasham Airfield in UK is 4 foot less than 5900' and DanAir used it as its maintenance Base and brought in and took off the old ex PA B707-320 with the JT4 engines. There was no runway lighting or aids other than a very old radar control. Never had any problems taking off, though we had to line our cars up one evening, as it ran late out of maintenance, to enable it to get airborne in the dark. This had a number of galleys and had 184 seats. Some very interesting take offs from LGW when fully loaded on the way to Canada.
Oldtimer, I should have known better!
Soku39
Tue Feb 17, 2009 12:47 am
In 1967 a Boeing 707 landing at Ohio State (KOSU), longest runway 5004 feet, mistakenly thinking it was Port Columbus. They actually flew it out, furthering the saying "sumbitch flew in, sumbitch'll fly out". Theres pictures of the incident at the FBO down there.
The Ohio Player
RaginMav
Tue Feb 17, 2009 3:44 am
Quoting Soku39 (Reply 3):
LOL if only that were always true! I flew into Glenwood Springs CO once, 3300 feet long, 6000 feet high. You can land any piston single there... but getting out was downright scary for me!
Seriously though, United has landed at the Council Bluffs, IA airport twice in years past, mistaking it for OMA. Once in a DC-4(?) and the other in a 727. Back in those days, the runway was ~3400 feet long. And guess what: sumbitch flew in, sumbitch flew out.
iRISH251
Thu Feb 19, 2009 12:17 am
Quoting Mozart (Thread starter):
By definition a VIP aircraft would be carrying a small number of passengers and we don't know how distant a destination it would have been flying to. Wind strength and air temperature also have an effect on takeoff performance. Dublin's subsidiary runway 16/34 is 6,500 ft. and has hosted all types up to and including An-124s and 747s with no difficulty, though this is of course an airport only 200ft AMSL.
Viscount724
Thu Feb 19, 2009 2:50 am
Quoting Irish251 (Reply 5):
But almost certainly not on longhaul nonstop departures.
When large jets used the downtown airport (MKC) in Kansas City prior to scheduled service moving to MCI's much longer runways in 1972, the longest 7,000 ft. MKC runway was marginal for types like 707s, as CO discovered in 1965 when a landing 707 aquaplaned on the wet runway, overran, hit an embankment and broke up, fortunately with no fatalities.
roseflyer
Thu Feb 19, 2009 6:00 pm
Every 707 has taken off from a shorter runway than that. The 707s were made in Renton Washington and the airfield has a 5300ft runway. Now on a test flight with no payload and a small amount of fuel is not a good comparison, but every Boeing narrowbody is able to takeoff of a 5,000ft runway.
aeroweanie
Thu Feb 19, 2009 11:59 pm
Every 707 made its first flight at the Renton Municipal Airport (KRNT). The runway length there is 5382 feet.
411A
Fri Feb 20, 2009 1:41 am
Not all that difficult to operate a B707 from an airport with a shorter runway, even at a higher altitude...and obstacles, provided the weight is adjusted for ambient temperature, AND depending on the specific model.
-138B, not a problem.
-320B (advanced cowl), also not a problem.
-320 (limited leading edge devices and straight-pipe engines), forget it.
sunrisevalley
Sat Feb 21, 2009 12:18 am
I have taken a quick look at the load/range and runway takeoff length charts for the 707-120B and 707-320.
The -120B has a TOW of 230K lbs off a 6000ft runway. This translates into a 137 passenger load incl. baggage for about a 3000nm sector.
The 320 with JT4 -11,-12 is good for about 246K lb off 6000ft. translating into 141 passengers over a 1800nm sector.
iRISH251
Sat Feb 21, 2009 8:17 pm
Quoting Viscount724 (Reply 6):
You're right, though I recall hearing of an Egyptair 707 freighter departing for Cairo some years back which used this runway - almost all of it, in fact!
