Placekicker
Is It Possible For An Airline To Change
Mon Feb 16, 2009 4:42 am
an aircraft's engines if it believes there could be an advantage to do so? Assume that Delta Airlines had a 767-300 which it purchased with P&W PW4000-94 engines. Say two to four years have elapsed and Delta wants to consider replacing the worn engines with one of the three other engines suited for the 767-300, namely the P&W JT9D-7R4, GE CF6-80A, or the GE CF6-80C2. Could this be done with minimal expense (outside of the cost of the replacement engines (which would have to be replaced after their lifecycle anyways)? Do airlines ever do this? Or is it once an airline purchases an aircraft with a specific type of engine, that it must replace the worn engines with new engines of the same model?
Thanks to all who know and respond!
kiwiandrew
RE: Is It Possible For An Airline To Change
Mon Feb 16, 2009 4:53 am
Interesting question Placekicker ,
I believe that it in general it is very difficult and costly to do so, ( with the exception of the 787 where apparently airlines will be able to change from RR to GE or vv - but even then I believe that the originally targeted change of less than a single day has now been deemed over optimistic ) while I do not know much about the technical side of things I believe that on aircraft where more than one engine type is offered the engine pylons and pylon mountings may differ between engine types , and interfaces such as bleed air systems presumably also differ , so it is not simply a matter of taking one engine type off and bolting another one on in its place . I am sure that some of the maintenance types who are on the site will be able to give you much more detailed info on this than I can
WestWing
Mon Feb 16, 2009 5:19 am
Yes, it has been done. United re-engined a fleet of DC8s with CFM-56 engines.
The best time to plant a tree is 40 years ago. The second best time is today.
AA737-823
Mon Feb 16, 2009 5:21 am
It's possible, but very costly.
There are hardware issues- the connections for fuel, hydraulics, pneumatics, and sometimes even the physical motor mounts themselves, are in DIFFERENT places on different engines built for the same airplane.
This is very frustrating to amanufacturer and a leasing company, who can get stuck with an old 772A with Pratts (cough cough, Varig) and not be able to get rid of them. Hence, we've already seen a 772A scrapped. That's certainly not the only reason, but it's a part of it.
There are also software issues- the onboard FMC and such are configured for the engines that are on the wing. I don't really think this is THAT big a deal, because software is software.
Quoting Placekicker (Thread starter):
You're making a bad assumption here, namely that engines are replaced after a relatively short (compared to reality) life cycle.
There are some ANCIENT jet engines out there. Once they reach their cycle or hours limits, they're inspected. One some models, like the RR RB211, many repairs and parts replacements can be done with the engine still "on-wing". Hence American Airlines has the on-wing record for that engine of 36,000 hours (as of two years ago when I heard about it, anyway... indirectly from AA mx). Other engines, like the familiar old JT-8D, typically require removal from the wing more often.
BUT- all that to say, engines last a LONG, LONG time... Decades, even.
Now, your proposal HAS been done in the past. If the airline is going to benefit from fuel burn or reliability improvements, the balance starts to tilt more toward "feasible." Hence so many DC-8-60 series aircraft became DC-8-70's, with the changeover to CFM-56 engines from their original Pratts.
I hope that's all been helpful.
Viscount724
Mon Feb 16, 2009 5:24 am
Quoting Kiwiandrew (Reply 1):
I believe it is extremely rare apart from major conversion projects like the CFM56 conversion of 110 60-series DC-8s as mentioned above. However at least a couple of 747s were converted from their original P&W engines to GE. One of them below. Same aircraft in all photos.
P&W engines:
Photo © Howard Chaloner
Photo © Frank C. Duarte Jr.
GE engines:
Photo © Jordi Steeno
Photo © Tim Perkins
That aircraft was written off in a landing overrun accident at DUS in 2005.
[Edited 2009-02-15 21:40:06]
Viscount724
Mon Feb 16, 2009 6:45 am
The CFM56 conversion of the 60 series DC-8s reminds me of two earlier conversion projects in the 1960s involving the ConvairLiner series which had their original P&W R2800 piston engines replaced with turboprops.
170 Convair 340/440s were re-engined with Allison 501s, becoming Convair 580s, with major improvements in performance and about a 20% increase in gross weight as the Allisons are about 50% more powerful than the original P&Ws. Some structural changes were needed, mainly larger vertical and horizontal tail surfaces.
A less successful ConvairLiner conversion saw 38 Convair 240s and 27 Convair 340/440s re-engined with Rolls-Royce Darts, the 240s becoming Convair 600s and the 340/440s becoming 640s. (The Allison 501 was too powerful for the Convair 240 airframe so that project only involved the 340/440.)
Same aircraft as a 340 and 580:
Photo © Lynn L. Reigle
Same aircraft as a 440 and 640:
Photo © Mel Lawrence
Burkhard
Mon Feb 16, 2009 1:55 pm
This might get interesting if the GTF prooves to be much better than the CFM56 on a few thousand A320...
AA777223
Mon Feb 16, 2009 3:21 pm
If I remember correctly, the very first T7 was a 772A with Pratt engines. After testing was done, the original customer didnt' want it. It was then, after sitting on a Boeing lot somewhere for a very long time, finally sold to a chinese operator...I'm wanting to say China Southern. They would only accept the aircraft if Boeing, at their expense, switched the engines to GE90s. This supposedly was done "at great time and financial expense". I don't know if this aircraft was intended for UA or not. I can't find the photo or customer code on it, so I do not know for whom it was originally intended. Any information would be greatly appreciated.
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175, DH-8, ATR-72, DO-328, BAE-146
speedbirdegjj
Mon Feb 16, 2009 3:26 pm
Quoting AA777223 (Reply 7):
It was Cathay, they have line number 1, which was delivered couple of years or so after it was built.
Ryan
BMI727
Mon Feb 16, 2009 3:27 pm
It is costly and relatively rare, but possible.
Usually when engines are upgraded (like 5X 727-100s and DC-8-70s) the upgrade is usually part of a more comprehensive conversion. As far as changing from one type of engine to another comparable type, it is extremely rare. The 787 is designed to have a common interface, but I heard that there were problems it. I heard that it was mostly leasing companies pushing for this capability.
aamd11
Mon Feb 16, 2009 4:08 pm
WA001, the first 777 built was a 777-200. It was the principle test aircraft in the certification process. I don't think it was originally destined for any particular customer, but nonetheless when certification was complete, Boeing tried to get rid of it.
The aircraft did around 1,800 flying hours up until mid 1997 when testing was complete. They put the frame up for sale around that time and it found no buyers until CX came along in mid 2000 (around May or June). It appears it took around six months to finish modifying the aircraft for passenger service - installation of galleys, toilets and so on - and the plane was delivered to CX in December 2000, complete with RR Trent engines.
Photo © T.Y. Bob LEE
Photo © Mark Tang - HKAEC
They got it cheap... after all, Boeing had tried for three years to flog it.
airbuster
Mon Feb 16, 2009 5:09 pm
Not to forget that airlines make good deals for spares and overhaul/maintenance of the engines, more so, iirc there are also leasing contracts for engines.
I believe to have read somewhere that it takes the manufacturer about 15-20 years of leasing an engine before it begins to make a profit.
rgfs
AB
FLY FOKKER JET LINE!
cf6ppe
Tue Feb 17, 2009 3:45 am
In the early 1960's, a number of B707-100, B720(A), and DC8-10 frames were converted to JT3D-1 powerplants from JT3C powerplants. In some instances the JT3C-7, -12 were converted to JT3D-MC-7, -12 via a Major Conversion (i.e., MC) kit. The resulting frames were then known as B707-100B, B720B, and DC8-50. There were some work done on the airframes to accommodate the upgraded powerplants.
Note: B707-200 and B707-300 and DC8-20/-30 frames delivered with JT4A powerplants weren't able to be converted.
KC-135 tankers (762 each) were delivered with J57Pxx powerplants; early on some were converted to use TF33P3 (JT3D) powerplants when the frames were converted to other than tanker uses (usually at Martin-Baltimore).
The remaining KC-135 tanker fleet was converted to either JT3D or CFM56 power. Details of the tanker powerplant conversions have been discussed many times in A-net forums.
The so called Valsan (Partners) conversion replaces the outboard (JT8D) powerplants on B727-200 frames with JT8D-200 powerplants. The Valsan conversion/modification is done via an FAA STC (Special Type Certificate) Approval.
There has been at least one B707-300 frame converted to CFM56 powerplants and one B707 frame has JT8D-200 powerplants fitted.
Hopefully, I haven't munged up the above thoughts too much... anyway...
[Edited 2009-02-16 19:46:49]
AA777223
Tue Feb 17, 2009 2:34 pm
Quoting AAMD11 (Reply 10):
Boeing doesn't build prototype aircraft like Airbus does. So, surely they had a customer in mind when they first built that frame. What is its customer code, and to whom does it correspond?
474218
Tue Feb 17, 2009 9:29 pm
Quoting AA777223 (Reply 13):
Maybe not now but they did when they built the original Dash 80 and the 747?
KELPkid
Tue Feb 17, 2009 10:00 pm
Quoting Viscount724 (Reply 5):
Hehehe, one day at LRU we had a suprise visit from a Convair 680 (it was a RR Dart conversion). Well, when they taxied up, I noticed that an engine was feathered. Apparently, they had an in-flight engine fire and had to pull the fire bottle. A second 680 from the same company (a US freight operator) with a replacement engine, and to rescue the stranded cargo that was on-board the first one. It spent about two weeks on the ground. I have never heard more noisy engines before or since.
Viscount724
Tue Feb 17, 2009 11:50 pm
As far as I can tell, it had no customer code when it was built or during its years with Boeing. It was just a generic 777-200. When it was refurbished, re-engined and delivered to CX 6 years later it was assigned the CX customer code and became a 767-267.
Photo © John Yu
The first 757-200 which was never delivered to a customer but has been used for various test programs (most recently for the F-22 fighter) is also just a generic 757-200 with no customer code.
Photo © John Kelley
Photo © Brian Lockett
As a sidenote, that aircraft made the 757's first flight 27 years ago tomorrow (or the day after tomorrow depending where you are) -- February 19,1982.
tdscanuck
Wed Feb 18, 2009 6:02 am
Boeing built "prototypes" for everything up to the 777. The 777 was the first one where the first airframe was basically production-standard, but I don't think they intended to deliver it to anyone at the time.
Tom.
Derik737
Sat Mar 07, 2009 3:05 am
Can't forget the UPS 727-100 Rolls Royce Tay Turbofan Conversion!
Viscount724
Sat Mar 07, 2009 3:30 am
Quoting Tdscanuck (Reply 17):
The first 727-100, line #1, which made the type's first flight in February 1963, was registered N7001U and was delivered to UA in October 1964 and spent almost 27 years with UA. So it must have been built to production standards.
Line #2 was also used in the flight test program but it stayed with Boeing. Many people think it was the first 727 since it was registered N72700 and both aircraft originally had the yellow and brown Boeing livery. But UA's N7001U was the first one built and the first to fly.
tdscanuck
Sat Mar 07, 2009 5:31 am
Quoting Viscount724 (Reply 19):
Not necessarily. Although I have no hard evidence one way or the other, there's no requirement that it have been built to the same production process as later airplanes (that's what I meant by "production standard"). As long as it could be issued an airworthiness certificate (which it obviously was), how it got that way is somewhat secondary.
Tom.
ex52tech
Sat Mar 07, 2009 10:44 pm
On thing that I did not see in any postings was the need to re-certify the airplane with the new engine. All the paper work and cost to do that is another item that makes it undesirable.
Many of the airplanes are at a point in their life/cycle that it would not allow the carrier to even break even on the modification. That was exactly the situation with the NW DC10-40 fleet, they were offered the JT9-7R4 to replace the JT9-20/-20J, but decided against the idea due to the retirement plan at the time and cost to re-engine and re-certify. JAL went ahead and re-engined their -40s, and as it turned out NW ended up keeping it's -40 fleet until their retirement.
"Saddest thing I ever witnessed....an airplane being scrapped"
Users browsing this forum: 69bug, HighBypass and 1 guest
