797
Garmin 1000 & Aero Commander 1000
Tue Feb 17, 2009 7:15 pm
Hello everyone,
Photo © Hidemi Bustamante Prudente - Aerolmagenes De Mexico
Since the Garmin family have decided to be a practical protagonist in the corporate aviation environment by adding full glass cockpits to planes such as the King 350, Caravan, Mustang and so forth, I was wondering if there's any version available for the Aero Commander 1000 series.
Avydine introduced their systems to the AC1000 in 2003, giving wonderful results:
Avydine Systems
Old systems
It would be great to see this amazing plane equipped with either the G1000 or G600 equipment. Is there any possibilities of integrating any of these systems into this plane? I would be very interested in doing so.
If any of you guys could provide some info I would really appreciate it.
[Edited 2009-02-17 11:20:42]
KELPkid
RE: Garmin 1000 & Aero Commander 1000
Tue Feb 17, 2009 9:53 pm
I'm sure that once a rich owner of one decides that they must have a Garmin 1000 flight deck in their Commander, then Garmin (or someone else  Wink ) will go through the work to produce an STC for it's installation.
Also, if there's an STC for another similar Aero Commander model (let's say, for example, Shrike Commander), it is possible that whoever produced the STC could be prodded to do the additional work to get it certified for the 1000 series.
I know that full flight deck replacement STC's are expensive, as it cuts across many certified redunant systems (like vacuum, electrical, pitot, static, etc.). Electronic flight deck certifications are based upon the applicant showing that their system has the same level of reliability and redundancy, or greater, than the original factory flight instrument and avionics installation... twocents
Unfortuntely, for these reasons, it's not as simple as, say, STC'ing adding a GPS receiver to the existing avionics stack  sigh
Mir
Tue Feb 17, 2009 11:39 pm
Quoting 797 (Thread starter):
Actually, that looks like a Meggitt Magic setup, like the one that was in the Meridian before Piper fitted the Avidyne Entegra to it.
http://www.s-tec.com/magic/
-Mir
9VSIO
Wed Feb 18, 2009 5:26 am
What I want to see is a warbird with glass cockpit. Heck, why not put one in a B-17!
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
NBGSkyGod
Wed Feb 18, 2009 11:02 am
Quoting 9VSIO (Reply 3):
 thumbsdown
Now that I believe is blaspheme.
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
cptspeaking
Thu Feb 19, 2009 4:09 am
You're much more likely to see the Garmin G600 installed...it's a baby version of the 1000 that is meant for uses such as this.
Much cooler in my opinion is the Aspen Avionics EFD1000 system. I've only used the PFD, but it can be paired with one or two MFD units to provide all the information the Garmin does in a very similar layout. I've used it in a Turbo Arrow, and it is a phenomenal system. It's connected to the 430W and it works almost exactly the same as the G1000 in terms of switchology.
The best thing about the Aspen? It is all contained in two cylinders extending from the back of the unit, which lets it slip nice and easy without any* panel modification into the standard 3 inch holes where your old AI and HSI were. Includes an AHRS, ADC, backup reversionary GPS, and a 30 minute backup battery in case of electrical failure.
http://aspenavionics.com/
...and don't call me Shirley!!
dw747400
Fri Feb 20, 2009 3:33 am
Quoting Cptspeaking (Reply 5):
I agree. To my knowledge, the King Air is the only aircraft with an after market STC for the G1000. All other STCs are for the G600. If you want a G1000 in a 172, for example, you need to buy it new.
CFI--Certfied Freakin Idiot
797
Sat Feb 21, 2009 2:47 am
I thought so! I had never seen this set of Garmins installed in any plane but now that I went into their website I understand a bit better.
What I didn't see available on this G600 is the Garmin Engine Airframe (GEA) that show all the engine information. That is a very important feature of the G1000. Is there any chance of putting 3 G600s into one cockpit in which all the information that the G1000 shows is also available?
Thanks for the input guys
Users browsing this forum: Apprentice, dragon6172 and 1 guest
