pilotboi
DL/NW Etops Overview
Thu Feb 26, 2009 1:39 am
Okay, I know there's been plenty of ETOPS posts (trust me, I've been searching through them). I've gathered as much info as I could find and I'm trying to recap it all, but I want to make sure I've got it right, and fill in a few missing blanks. If I've got it all right, these aircraft are approved for the following ETOPS...
Delta
757-200 (ex-AA only) [21 aircraft] - ETOPS-180
767-300 (Hawaii only) [4 aircraft] - ETOPS-180
767-300ER [57 aircraft] - ETOPS-180
767-400ER [21 aircraft] - ETOPS-180
777-200ER [8 aircraft] - ETOPS-180 (or is 207?)
777-200LR [2 aircraft] - ETOPS-180 (or is 207?)
Northwest
A330-200 [11 aircraft] - ETOPS-???
A330-300 [21 aircraft] - ETOPS-???
757-200 (Intl only) [16 aircraft] - [8x] ETOPS-90 and [8x] ETOPS-120
So unless anything needs to be corrected, the only things I need cleared up is if the 777s are 180 or 207, plus I'm not sure what the A330s are, since I know a lot of them do trans-Pacific and that only requires 90 in most cases, or 120. And 180 is needed for Hawaii. Any help on those few things would be great, thanks!
Edit: Also, is either airline certified for more then 180?
(And yes, I'm aware - an aircraft is approved, and the airline is certified, so please, we don't have to go over that again.)
[Edited 2009-02-25 17:41:25]
KingAir200
RE: DL/NW Etops Overview
Thu Feb 26, 2009 2:09 am
Quoting Pilotboi (Thread starter):
Both 180. Don't forget the 753s, which are also 180.
pilotboi
Thu Feb 26, 2009 5:42 am
Quoting KingAir200 (Reply 1):
Thanks. I guess I didn't even realize the 753s were ETOPS maintained, since I thought they mainly do domestic flying.
Also, I realize I made a typo in my OP. The NW 752s are half -90 and half -180 (not 120 like I typed).
So unless the 777s are different then what I said, the entire ETOPS fleet is 180, except for 8 of the NW752s which are 90. Correct?
roseflyer
Thu Feb 26, 2009 3:52 pm
Quoting Pilotboi (Reply 2):
They are very common on the routes to Hawaii from the west coast.
Transpac787
Fri Feb 27, 2009 3:10 am
All 777's are ETOPS-180. The FAA only grants ETOPS-207 on a route by route, as-needed basis. The last route to require (and allowed by FAA) ETOPS-207 flights were UA's LAX-AKL flights. Incidentally, it was on one of these flights that one of UA's 777's lost an engine at the ETOPS-207 equal-time-point and flew for 192 minutes on a single engine to their divert field of KOA.
90 minutes is not official ETOPS, rather it's "Extended Overwater". The NW 75A's are ETOPS-180, the NW 75X's are EOW-90.
Users browsing this forum: RetiredWeasel, Yahoo [Bot] and 14 guests
