N701AA
ERJ 190 Angle Of Attack On Landing
Thu Mar 05, 2009 7:25 am
I have noticed that the angle of attack of the ERJ190 on landing is very nose up. Today I flew the aircraft for the first time and from way back of the plane, where I was seating, the nose seem to come way up during flare. I was wondering how well this aircraft maneuvers at low speeds? Any issues with wing design?
David L
RE: ERJ 190 Angle Of Attack On Landing
Thu Mar 05, 2009 1:23 pm
Quoting N701AA (Thread starter):
As long as there's no danger of a tail-strike and the crew have a good view of the runway, I'm not sure there would be any "issues".
I'm guessing the answer will centre on "leading edge devices". That's often the reason given for a nose-high approach.
longhauler
Thu Mar 05, 2009 1:53 pm
While not AOA, pitch is normally about 5 degrees on touch down, maximum is 10 degrees. Any greater than that, and "tail strike protection" takes over. The fly by wire system controlling the pitch/elevators will reduce pitch on touchdown if it is too high.
The E190 is more "over winged" than "under winged". That is, the wings are quite a bit larger than they need to be, allowing higher cruise altitudes. That is why the heavier E195 uses the same wing, the growth was planned from the start.
If the flaps/slats were working properly and in correct position for landing, a high nose up landing is not necessary, and usually more the result of an incorrectly applied landing technique. Stretching the landing flare, to get a smooth touchdown, is rarely a good idea.
FlyASAGuy2005
Thu Mar 05, 2009 2:52 pm
I had noticed this a while back when I was brousing photos of Jet Blue's first E-190s. I was always curious about it. N701AA, thanks for the post!
Photo © Trent R Sellers
Photo © Justin Stephenson
And this is only Jet Blue. I saw it also on KLM Citty Hopper, etc.
What gets measured gets done.
globeex
Thu Mar 05, 2009 2:57 pm
Quoting FlyASAGuy2005 (Reply 3):
Well, looking at the second picture, it rather seems like a take off.
GlobeEx
As you may presently yourself be fully made aware of, my grammar sucks.
UAL747
Thu Mar 05, 2009 3:58 pm
What is it about wing design that causes an aircraft to have a higher AOA? The MD-11, DC-10, L-1011's, 747's, and most airbii have higher angles of attacks on landing than Boeing twins. I know that because the tri-jets have an aft 2nd engine, they are heavier behind, therefore, it moves the wingbox aft due to the shift in weight, thus making higher AOA approaches and take-offs easier because of the shorter fuselage behind the main gear, but still, it's interesting to note these differences...
UAL
pilotpip
Thu Mar 05, 2009 5:04 pm
You guys are confusing pitch with AOA. They aren't necessarily tied together.
As for the 190, on the 170, the max PITCH on landing is about 12 degrees. The 175 is about 11.5 (six feet longer). I would imagine than the 190, which is the same aircraft with another fuselage plug, will be the same as the 175 or perhaps less.
I have a four day starting Saturday. I'll try to pay attention to the PFD for you guys when on final and tell you my findings. It's honestly something I ever pay much attention to.
DMI
Bellerophon
Thu Mar 05, 2009 9:26 pm
N701AA
I suspect you may have inadvertently used the wrong term in asking your question, the terms Angle of Attack and Pitch Angle are frequently confused by many.
Put very simply:
Angle of Attack (Alpha / Incidence)
The angle between the airflow and the wing.
Pitch Angle (Pitch Attitude / PA)
The angle between the wing and the horizontal.
Pitch Angle or Attitude - which is what I suspect you meant to ask about - can be estimated reasonably accurately by a spectator, ask any USN pilot who has worked as a LSO on an aircraft carrier.
Angle of Attack - can only be known from looking at an alpha-meter, trying to estimate it from a still photo can be very misleading.
Best Regards
Bellerophon
LY744
Fri Mar 06, 2009 4:40 pm
Quoting UAL747 (Reply 5):
If you mean having the ability (but not the necessity) to fly at a higher angle of attack, then it's a multitude of things. Slats are one example that is applicable to transport aircraft. A prominent one on modern fighter jets is leading edge root extensions (LERXs), or having a delta wing.
LY744.
airbuster
Fri Mar 06, 2009 9:20 pm
Thread already exists as posted by myself 5 months ago:
http://www.airliners.net/aviation-fo...chid=238483&s=E-190+pitch#ID238483
And the actual designation is not ERJ 190 but just E-190, nothing regional about a 4000nm range...
rgds
AB
FLY FOKKER JET LINE!
2H4
Fri Mar 06, 2009 9:30 pm
Quoting Airbuster (Reply 9):
Tell that to the legacies...
2H4
Intentionally Left Blank
pilotpip
Sat Mar 07, 2009 11:18 pm
To answer the question: It varies with weight but I was seeing a pitch angle of about 3 degrees on Final. I don't like to flare much past about 6 degrees because this plane likes to float. Again, these are numbers for a 170.
My type rating says ERJ-170/190.
DMI
airbuster
Sun Mar 08, 2009 1:58 pm
Quoting Pilotpip (Reply 11):
Ey pips! I believe you but don't know where they got that from...is it maybe the officailly registered type designation and they use E-JETS as their marketing name?
Like my Fokker 70 and 100 are officially F28 Mk0070 / Mk 0100..
Here's the link to Embraer anyways...
http://www.embraercommercialjets.com/english/content/home/
UAL747
Sun Mar 08, 2009 2:24 pm
Wow, so this thing could fly BOS-LHR? I'm astounded! I didn't know it had that much range!
UAL
longhauler
Sun Mar 08, 2009 3:35 pm
Quoting UAL747 (Reply 13):
 Smile
Full fuel gives you about 2200 miles. The longest route we have flown the E190 is YYZ-SAN.
pilotpip
Sun Mar 08, 2009 4:38 pm
Quoting Airbuster (Reply 12):
Oddly enough, the 145 type here in the US is EMB-145
DMI
airbuster
Mon Mar 09, 2009 7:43 am
Quoting LongHauler (Reply 14):
Hey, you're correcto about that, i should have said, it has a 4000 KM range not NM...a bit over enthusiastic that was...
Still, you can doe transcons with the 190 or Paris-Middle East....
rgds
Ab
mrocktor
Wed Mar 11, 2009 2:35 pm
Official designations are:
ERJ 170-100 (E-170)
ERJ 170-200 (E-175)
ERJ 190-100 (E-190)
ERJ 190-200 (E-195)
WildcatYXU
Fri Mar 13, 2009 12:33 pm
Quoting GlobeEx (Reply 4):
Indeed. The flaps and slats on the first picture are much lower.
Quoting 2H4 (Reply 10):
AC seems to know...
310, 319, 320, 321, 333, 343, 345, 346, 732, 735, 73G, 738, 744, 752, 762, 763, 77L, 77W, 788, AT4, AT7, BEH, CR2, CRA, CR9, DH1, DH3, DH4, E45, E75, E90, E95, F28, F50, F100, MD82, Saab 340, YAK40
tinpusher007
Sun Mar 15, 2009 5:39 pm
To further add to this discussion, the CRJ-900 that i fly which is equipped with slats still has a slight nose low pitch on final. It isn't until the flare that pitch increases to about 5 degrees nose up. Ive always been curious as to why this is. After flying it for a year Im still not sure.
"Flying isn't inherently dangerous...but very unforgiving of carelessness, incapacity or neglect."
Users browsing this forum: jakubz and 17 guests
