seemyseems
A Few Questions About The A330
Sat Mar 28, 2009 3:57 pm
I'm sure this has been asked before, but I wanted to know which A330 (both -200/-300) has the most range or fly the furthest. I reckon the A330-343X has the most range but I heard the A330-200 can fly the most.
And one last question; could an A330 make LHR to NRT?
Thanks, Sam.
seemyseems
tdscanuck
RE: A Few Questions About The A330
Sat Mar 28, 2009 4:06 pm
Quoting Seemyseems (Thread starter):
It was sort of asked before here:
http://www.airliners.net/aviation-forums/tech_ops/read.main/228999/
The answer actually comes from the A330 ACAP, but the link from the above thread doesn't seem to be working now. However, from my saved copy:
Range with payload to MZFW:
A330-200: ~4200 nm
A333-300: ~3700 nm
Range with max fuel at MTOW:
A330-200: ~9100 nm *
A330-300: ~5500 nm
* - The A330-200's max fuel limit corresponds to almost zero payload, so this isn't really a practical value. At the same payload as an A330-300, a -200 will go about ~6200 nm.
A -200 could do it fairly easily with some payload restrictions. A -300 couldn't do it with an economical payload.
Tom.
PlymSpotter
Sat Mar 28, 2009 4:10 pm
Quoting Tdscanuck (Reply 1):
Is that including the A330-200HGW?
seemyseems
Sat Mar 28, 2009 4:18 pm
A330-200: ~4200 nm
A333-300: ~3700 nm
A330-300: ~5500 nm
Thanks for that! Would that be the RR powered models? I prefer the A330 with the GE/PW engines.
seemyseems
tdscanuck
Sat Mar 28, 2009 7:26 pm
Quoting PlymSpotter (Reply 2):
I'm not sure...that's for a MTOW of 233,000 kg. I can't tell from the ACAP if that's the HGW or not.
Quoting Seemyseems (Reply 3):
That happened to be for GE, but they're very very close (within 200 miles of each other) for all three engine types.
Tom.
FlySSC
Sat Mar 28, 2009 7:42 pm
AF is using an A330-200 to operate one of its 3 x Daily CDG-NRT-CDG (AF272/AF279), and without any restriction. So I guess LHR-NRT-LHR is no problem either for the A332.
AF used also its A332 on CDG-HKG-CDG and CDG-KIX-CDG.
seemyseems
Sat Mar 28, 2009 7:47 pm
Quoting FlySSC (Reply 5):
I remember seeing the pictures, I thought it was a bit odd. Thanks for that FlySSC!
seemyseems
UN_B732
Sat Mar 28, 2009 7:52 pm
Aeroflot was planning on flying it's A330 on SVO-LAX this summer; but those plans have changed.
What now?
astuteman
Sat Mar 28, 2009 8:04 pm
A330's have progressively been getting more capable (and heavier).
The ACAP document referred to by Tdscanuck shows the current 233 tonne version of the A330-200 to be capable of 6 750Nm with a payload of around 25 tonnes.
LHR-NRT is 5 200Nm, at which still-air range the 233t A330-200 will lift about 90 000lb (about 41 tonnes, which is a pretty good payload)
Of course air is never still, so I'm guessing about 6 000Nm would be representative of real-world LHR-NRT, at which air range, the payload is around 75000lb or 34 tonnes.
That would equate to around 250 pax plus about 11 tonnes of cargo.
Which I guess means "yes"..  Smile
Since the ACAP was published, Trent powered A330's have reduced their SFC by 1.3% and P+W powered ones by around 1%. The Trent improvement should add c. 1 tonne to the payload capability at those ranges.
Of course, next year, airlines will be able to take A330-200's rated to 238 tonnes MTOW, which should make a very useful addition to the already useful range/payload capability that I've described.
The A330-300's are seriously fuel volume limited compared to the A330-200 without the A330-200's centre fuel tank.
As Tdscanuck said, the A330-200 gets within a whisker of MTOW just by filling the tanks - the 1.3% Trent 700 SFC gain should give the A330-200 a ferry range of the order of 9 500Nm - the same as the 748i  faint   biggrin
