YXD172
Helicopter "Dry Runs" Systems RE:S-92 Crash
Mon Apr 06, 2009 3:36 pm
I don't know much about helicopter operations, but he following article in the Globe and Mail prompted a few questions : http://www.theglobeandmail.com/servl...er06/EmailBNStory/National/home%5C
1) Could someone explain how some of these dry-run systems work?
2) Are they required for all operations, or is it just a further certification?
3) How does the S-92 still meet FAR29 with their "it's just not going to happen" exclusion, even after the crash a year ago?
A quick google search revealed this lively PPrune discussion (http://www.pprune.org/rotorheads/163206-sikorsky-s-92-design-operations-71.html) but it seems to be more of an argument than anything else.
Jon
Radial engines don't leak oil, they are just marking their territory!
Alessandro
RE: Helicopter "Dry Runs" Systems RE:S-92 Crash
Tue Apr 07, 2009 6:24 am
I read about Kamov helicopter which could do a longer dry run than this helicopter.
UH60FtRucker
Tue Apr 07, 2009 2:02 pm
Quoting YXD172 (Thread starter):
It's rather simple... the transmission(s) have oil to lubricate the gears, and in the event that the oil is depleted, the gearboxes are designed to run for at least 30 minutes. After which point, the manufacturer cannot guarantee that the gears will not seize.
Sikorsky gearboxes -- to include the main transmission, the accessory gear boxes, and the tail rotor gear boxes -- are advertised to be rated to a specific "dry run time".
Now... the design intent is to offer a safety window for the pilots, to get on the ground immediately, in the event of a massive oil leak. It is not the design intent to allow for the pilots to feel they can run for an additional 30 minutes and THEN land. The emergency procedure is a "land as soon as possible" - ie: land at the nearest suitable landing area without delay.
-UH60
I am not criticizing the pilots of this particular crash. I have no idea what went on in that cockpit, and I must defer to their judgment. I have no reason to believe they were to blame for this.
But as a PC of a Sikorsky helicopter - if I had a low transmission oil pressure, or any associated caution lights - my top priority would be find the nearest spot to land, and quickest route there. I've done numerous over-water missions, and I brief my crew and passengers about water ditching procedures. If I encountered an oil issue, and possibly had to ditch, I would instruct my crew to prepare for a water ditching.
But yeah... even though my manuals tell me I have X amount of minutes before the sh*t hits the fan, I've always preferred to not trust it, and always expect that helicopter is trying to kill me.
Your men have to follow your orders. They don't have to go to your funeral.
dragon6172
Tue Apr 07, 2009 7:44 pm
Quoting UH60FtRucker (Reply 2):
I am with you. In my opinion, that dry run time should be used to execute a "controlled" ditching. Something where you can get all your passengers out, in survival suits, and hopefully a raft. Then if you, as the pilot in command want to go and see if you can make it to a safe landing spot go ahead.
Phrogs Phorever
Users browsing this forum: Adispatcher, caverunner17, futuresdpdcop and 2 guests
