A342
A320 Family Service Ceiling
Mon Apr 13, 2009 6:27 pm
This question has been on my mind for quite some time, so I'll finally ask.
The A320 family has a certified service ceiling of 39,800 feet (39,100ft for aircraft not equipped with modification 30748, which seems to apply mostly to early aircraft). As aircraft use flight levels which are spaced 1,000ft apart (in RVSM airspace), this seems odd. Wouldn't it be useful to at least gain permission for FL400? Two hundred feet can't be an issue, especially when we consider that the ACJ and A318 Elite (maybe also the A320 Prestige) are in fact certified for 41,000ft.
Same with the A380, B777 etc.: Why are they certified for 43,100ft and not simply 43,000ft?
I'm really wondering, but I'm sure you can help me.
Thanks in advance,
A342
Exceptions confirm the rule.
mandala499
RE: A320 Family Service Ceiling
Mon Apr 13, 2009 9:00 pm
Quoting A342 (Thread starter):
In Russian airspace, your flight levels near the ceiling are:
11600m (FL381) for westbound and 12100m (FL397) eastbound... so 39800 gives U a 100ft cushion for that...
If the aircraft is restricted to 39100... in Russian airspace U'd be limited to 11100m (FL364) eastbound.
And if you're restricted to FL431... well, doesn't matter much coz westbound FL430 is available (13100m) and eastbound U're going to be at FL397 anyways, unless you want 14100m (FL463)...
If you're certified for 43,100, you have that 100ft cushion... if you're restricted to FL430 as your ceiling, you'd be busting your certification of you find your plane at 43,001ft...
Mandala499
A342
Mon Apr 13, 2009 10:24 pm
Quoting Mandala499 (Reply 1):
Thanks, that makes sense.
But regarding the A320, I rather doubt that it was designed primarily for the Russian market.  Smile Does China use the same altitudes (metric with 500m separation)?
PhilSquares
Tue Apr 14, 2009 3:26 am
In the VNAV function, the altitude hold function is soft. The aircraft will accept slight deviations in altitude to maintain a smoother ride for passengers. In the ALT mode, it is a "hard" level hold. If you select FLXXX it will hold that, where as in VNAV you will see slight deviations to allow a smoother ride with fewer throttle inputs and smaller airspeed changes.
Fly fast, live slow
rwessel
Tue Apr 14, 2009 9:37 am
Quoting A342 (Reply 2):
But regarding the A320, I rather doubt that it was designed primarily for the Russian market. Does China use the same altitudes (metric with 500m separation)?
But as you pointed out in your original post, 700ft of ceiling was added to the later models. Presumably there were customers (or potential customers), who were running into the Russian flight levels, and a modest altitude increase could be accommodated with minor modifications (perhaps little more than paperwork, given that the ACJs are certified to more than that).
And yes, China, Mongolia, and many of the countries that were formerly part of the Soviet Union use the metric flight levels.
A342
Tue Apr 14, 2009 10:09 am
Quoting PhilSquares (Reply 3):
So what about an aircraft that is certified for exactly 41,000ft and cruises at FL410, for example a 737NG? Don't they have VNAV?
Quoting Rwessel (Reply 4):
Well, now the question is why they don't add another 200 or 300ft for customers operating primarily in western airspace? I believe it is relatively common (at least for the A318 and A319) to cruise at FL390. While I don't have any data to back this up, I feel that another 1000ft would make sense for quite a few flights.
PhilSquares
Tue Apr 14, 2009 2:01 pm
Quoting A342 (Reply 5):
I have never flown the 73 series, however on the 747-400, it's certified for 45100. It has VNAV and at FL 450 it will be a soft cruise in VNAV. I suspect the 73NG is the same in that it's certified for FLXX100.
Fly fast, live slow
mandala499
Tue Apr 14, 2009 4:38 pm
In China the flight level allocation is different than in Russia... now they use metric RVSM aswell... 300m separation.
Interestingly, if the A320 is restricted to 39,000 max cert alt, then they loose out of 11,900m (FL391)...
Well, I'm told that Air Asia's new A320s are certified to FL400/410 in line with the ACJs...
I'm guessing that the FL397 ceiling was a progressive improvement introduced and later increased again...
Quoting PhilSquares (Reply 6):
I just checked the manuals, it says 41,000ft as the NG's max operating altitude, the 744 does have 45,100. Odd... perhaps it has got to do with the wording and certification????
Mandala499
roseflyer
Tue Apr 14, 2009 4:45 pm
It might be very expensive to do that. Can the packs take the additional load and still meet the safety requirements? Does the plane have the capability to descend fast enough in an emergency in all configurations in the event of a decompression? Is the skin thickness and structural strength capable of repeatedly taking the higher load within required safety factors? Will increased fatigue occur? Are the seals capable of that pressure differential? Do the engines have enough capability to economically cruise at that altitude with realistic payload?
All of those can be factors. I don't know A320 design, but there is probably something that would be very costly to change that would be required to certify it for a higher altitude. Obviously they can get around it on an ACJ, but that plane does have structural and capacity modifications and is a lower cycle airplane.
200 ft might not seem like much, but it can push some components beyond their required safety factors. It was a massive amount of work to get the 737NG capable of 41,000ft. Boeing went through the cost though so that they could make their plane fly higher than Airbus.
A342
Tue Apr 14, 2009 6:00 pm
I checked again, it is 41,000ft. See here (page 22):
http://rgl.faa.gov/Regulatory_and_Gu...ae86257479004d1e57/$FILE/A16WE.pdf
And the A310 is also certified for 41,000, the 737 classic to 37,000, the 757 to 42,000 etc.
Another aircraft to have a FLXXX+100 ft ceiling is the A330/340, 41,100ft, with an optional 41,450ft.
Quoting Mandala499 (Reply 7):
That's odd. Can't find any reference...
mandala499
Tue Apr 14, 2009 8:50 pm
Quoting A342 (Reply 9):
Hence the "I'm told..." as I haven't seen reference to it before apart from claims by crew to be at FL400 (on one occassion they were about to be bumped to 340 by 2 NGs at 360 and 380... how and why that's another story)... if I see reference to it... I'll let you know (if I remember)...  Smile
PGNCS
Mon Apr 20, 2009 9:52 pm
Here is a very interesting (although old) discussion of this subject that may be enlightening. Please note the discussion of the 737NG in the future tense!  Smile
http://yarchive.net/air/airliners/cruise_altitude.html
My understanding of the 757 limitation of 42,000' (versus the 43,000' on the 767) was due to the extra time to descend in the 757 in a decompression incident. Perhaps somebody with applicable knowledge can comment.
Here is yet another discussion of related topics that are germane to this thread:
http://forums.jetcareers.com/technic...ing-vs-max-operating-altitude.html
Users browsing this forum: flyDTW1992 and 18 guests
