JoePatroni
Strange Noise In A320 On Climbout
Wed Apr 22, 2009 9:42 pm
Hi!
So, as a disclaimer, I fly very often and average about 130,000 miles a year. I also work in the airline industry and know quite a bit about these beasts I fly on. That being said, I'm pretty tuned into the "sounds" that airplanes make throughout the different phases of flight especially the A320 which seems to be the aircraft I fly the most.
Yesterday, I was on UA519 from PHX to SFO on N339UA- a TED configured A320 now in UA mainline paint:
Photo © Agustin Anaya
So just after we lifted off there was a fairly high pitched sound and a distinct vibration which kept getting louder and stronger. The noise and vibration dissipated for a little while and then started even stronger than before as soon as we started to bank to the right. The vibration was really remarkable especially during this turn and then seemed to get less and less the higher we went. It was so remarkable that it was louder than the sound of the engines (which I was sitting next to in 6A) and the vibration was so distinct that it was almost hard to see clearly.
I was listening to Channel 9 the whole time and nothing was mentioned and the crew carried on as completely normal so I knew that this was probably no big deal (actually, Thank Goodness for Channel 9 because I'm sure my anxiety level would have gone through the roof!) but I was wondering if anyone has experienced this before or if any of you have any insight as to what the heck this was.
Some of my thoughts as to what was going on was perhaps an open panel (i.e. cargo door control panel or maybe the ground power panel) or something wrong with the engine- but obviously that was not the case.
Anyway, any insight would be greatly appreciated!
JP
Oh Stewardess, I speak Jive.
Sasha
RE: Strange Noise In A320 On Climbout
Thu Apr 23, 2009 3:58 am
Weather conditions? Probably some significant turbulence area... also thinking if there could've wing and stab config that would cause that? I hope anyone with an actual piloting background could comment on this.
BTW, what does Channel 9 transmit? Is it what I think it is - crew to ATC comms? Wow...
An2/24/28,Yak42,Tu154/134,IL18/62/96,B737/757/767,A310/320/319,F100,BAe146,EMB-145,CRJ,A340-600,B747-400,A-330-300,A-340
jetmech
Thu Apr 23, 2009 4:09 am
Quoting JoePatroni (Thread starter):
Sound anything like this?
http://www.youtube.com/watch?v=VbmQhUNFeFU
Regards, JetMech
Thu Apr 23, 2009 4:52 am
Could be some interior part close to you vibrating. Maybe a big panel or something. If the engines hit the right frequency for a part, it will vibrate. Not uncommon.
Thu Apr 23, 2009 5:12 pm
Did the vibration & sound reoccur on Descent or was this only with climb thrust?
regds
MEL.
JoePatroni
Thu Apr 23, 2009 10:46 pm
Quoting JetMech (Reply 2):
It was definitely not that. I'm quite familiar with that sound on the Airbus'. It's the hydraulics, right?
Quoting Starlionblue (Reply 3):
I thought about that, but the vibration was a lot heavier sounding that a big piece of thin plastic if that makes sense. It definitely felt heavier and more dense that that.
Quoting HAWK21M (Reply 4):
No, the vibration and sound only occurred during climb. I guess what was remarkable was that it really got stronger as we banked to the right and lessened as we leveled. The flaps/slats were still down at that point. I really thought the fuselage was going to split in two during that turn but there really wasn't that much turbulence.
JP
474218
Thu Apr 23, 2009 11:39 pm
Since you were in fairly far forward (Row 6) my guess (that's all any one can do) is that it was the nose wheels spinning in the wheel well. There are pads in the nose gear wheel well that stop the spinning wheels. However, operation with the spin brake pads removed is allowed by the MMEL. The spinning wheels would resonate throughout the fwd cabin.
ex52tech
Fri Apr 24, 2009 2:45 am
Had a similar experience while flying on an MD 80 some years back.
Loud, almost squealing sound and an accompanying vibration. It was so loud that the passengers around me were getting freaked out. The noise changed with airplane banking. I went up front and identified myself to the flight crew, we discussed the noise, and the first officer and I went back to listen. We continued on to our destination, and it was annoying.
I went out on the ramp with the crew when we got to the gate, and there was about two feet of gear door seal left on the door, the area around the gear door was fairly beat up, and some small dents. What was causing all the trouble must have torn away when the gear door opened.
You may have experienced a fairing seal that had come loose, or a panel that had come loose.  scratchchin  Just an idea.
"Saddest thing I ever witnessed....an airplane being scrapped"
JoePatroni
Fri Apr 24, 2009 4:12 am
Thanks all, for the feedback.
Quoting Ex52tech (Reply 7):
You may have experienced a fairing seal that had come loose, or a panel that had come loose.    Just an idea
Quoting 474218 (Reply 6):
These two ideas definitely sound more like it. I wish I had the chance to go out on the ramp to check out the bottom of this aircraft because it was my definite gut feeling that whatever was making this sound/vibration was on the lower side of the fuselage.
JP
pilotaydin
Fri Apr 24, 2009 6:34 am
I fly the A340 a/c, and well...although i havent been a pax on my airplane yet, depending on the temperature for the day, and the pressure altitude, the selected flex temp or toga, the a/c will make a different pitch noise depending on the N1 speed...
there have been times where we've sounded like 4 horizontal washing machines, whining through the sky  Smile
The only time there is too much fuel onboard, is when you're on fire!
Fri Apr 24, 2009 8:31 am
would that NW spin continue for so long.....
Very unlikely.
The sound would have reappeared on descent...it did not.
I feel its some thing to do with the engine on high thrust.Just a guess.
regds
MEL.
ex52tech
Sun Apr 26, 2009 2:32 pm
Quoting HAWK21M (Reply 10):
Unless whatever was causing the noise was no longer with the airplane at that phase in the flight.
I have been trying to think of what on a engine could have caused that much transitional vibration, and not have caused the crew to notice, (from the sound of the Chan.9 conversations, they did not). I have balanced a few high vibe fans over the years, and you could barley feel the worst ones, and we knew there was going to be vibrations.
Maybe a pneumatic duct that had broken loose in the fuselage, and was rattling against a frame.
474218
Sun Apr 26, 2009 4:03 pm
How long do you think a 100 lb wheel, mounted on a roller bearing, spinning at 170 mph would take to stop spinning? I would guess a couple of minutes minimum.
Sun Apr 26, 2009 8:03 pm
Quoting 474218 (Reply 12):
Firstly what are the chances that both NLG snubbers are not touching the wheels on retraction due to wear,and presuming one is.....Then wouldn't the gyroscopic loads be significant to be noticed in the Flight deck?
regds
MEL.
474218
Sun Apr 26, 2009 10:21 pm
Quoting HAWK21M (Reply 13):
You didn't read what I said in reply 6 did you?
Spin brakes are a MMEL item and as I stated that if they were removed (as required by the the MMEL) the nose wheels would have to spin down, after takeoff.
If the spin brakes were removed (as per the MMEL) the crew would know. So they would not be alarmed by the vibration the spinning nose wheels would cause.
I don't know what the noise was, I presented a plausible scenario, if you have a better one present it.
Mon Apr 27, 2009 10:15 am
Quoting 474218 (Reply 14):
Whats the MMEL for inop snubber,do both have to be removed?
Would need to check that out.
Reply 10.
I guess its tough,unless we had access to the next flight report after this one.How does one explain the noise from the RH side & increasing with bank.
regds
MEL
474218
Mon Apr 27, 2009 2:27 pm
Quoting HAWK21M (Reply 15):
MMEL Item 32-42-06 Nose Wheel Brake Pads, Installed 2, Required for Dispatch 0. Note reads: Maybe inoperative provide pads are removed.
I am not trying to explain anything. Like I originally stated in reply 6, all I or anyone else that was not there can do is, guess.
EireRock
Tue May 05, 2009 12:14 am
Quoting 474218 (Reply 16):
Actually alot of A320 operators don't even have them installed. I don't think it was NW spin however because it was felt more on a right bank, by that stage (considering a straight ahead departure) the wheels would have been retracted and have stopped spinning.
But i do agree about the idea, i was recently in a 737NG and the nose wheel vibration on T/O (with pads installed) was pretty bad.
I dont have much of an idea as to the noise myself, but i know CFM56-5's can make a lot of noise/vibration at T/O thrust, although from the picture it seems UA/Ted have V2500's on their 320's.
474218
Tue May 05, 2009 1:55 am
Quoting EireRock (Reply 17):
I highly doubt that any operator has removed the NW spin brake pads. Because, if they did they would be operating illegally.
The MMEL lists the NW spin brake pads as a "C" item and "C" items must reinstalled within 10 days (240 hours) of their removal.
EireRock
Tue May 05, 2009 3:13 pm
Quoting 474218 (Reply 18):
I have seen various LH A320's and BD A320's without such pads.
474218
Tue May 05, 2009 3:25 pm
Quoting EireRock (Reply 19):
I have read the MMEL. Maybe LH and DB should?
EireRock
Fri Jun 05, 2009 2:05 pm
Quoting 474218 (Reply 20):
Can anybody else shed some light on this? I have been looking into A320 Nose Gear bays for quite a while and have seen some airlines with the braking pads and some without. As far as i know the wheels don't actually spin against the nose wheel well structure, there is a gap to allow the wheels to spin without rubbing on anything.
474218
Fri Jun 05, 2009 3:20 pm
Quoting EireRock (Reply 21):
You can look at the MMEL like I did. If you have access to the NWW you should must have access to the MMEL. Additionally all the MMEL's are on the web you just have to do a search.
roseflyer
Fri Jun 05, 2009 3:58 pm
On the plane I work on, about 2-5 minutes. Usually closer to 2.
wirelock
Sun Jun 07, 2009 8:03 pm
the A320 from time to time can suffer from fuselage vibrations. these can be caused by various things.
vibrations from the front can be caused by (amogst other things) nlg wheels imbalance, or nlg door seal wear or nlg aft door vibration due to wear of the attach lugs.
the engines are a common source of vibration. there is a possibility that one of the engines was experiencing a N1 or N2 vibration with an associated rumble or noise in the cabin. these vibrations are common enough. the crew have a vibration monitor in the cockpit. if the vibration goes above 6.0mils then the a/c must be grounded. anything between 4 and 6 is acceptable for flight but maybe the passengers will worry about the noise of this.
in the rear area vibrations can occur from the elevator, rudder or ths. the a320 has big issues with wear in the elevator hinge bearings that cause big vibrations and costs operators lots of money due to trouble shooting and grounding the aircraft.
my advise is if you are a frequent flyer and are unsure about the noises that you are hearing is to inform the cabin crew. they might be aware of the problem and might be able to tell you what it is. if not then you should tell them to inform the crew.... chances are though that if you can hear these noises , sitting in 6A, then your flight crew can as well
AirframeAS
Mon Jun 08, 2009 2:22 am
The A320 aircraft has a industry wide problem with nose gear vibrations and it continues to be a problem. Airbus knows about the situation and is trying to fix the problem.
I work in the NLG and MLG bays of our Airbus aircraft a lot and the NLG does not have those pads like the 737's do.
EireRock
Mon Jun 08, 2009 3:30 pm
Quoting AirframeAS (Reply 25):
Thanks for confirming this.
Users browsing this forum: Bing [Bot] and 3 guests
