A342
No ETOPS For GEnx And Trent 1000?
Sun Apr 26, 2009 4:31 pm
From the GEnx TCDS:
"NOTE 20.
EXTENDED TWIN ENGINE OPERATIONS (ETOPS)
The GEnx-lB54/1B58/1B64/lB67/1B70 engine models are not ETOPS eligible. They do not meet the requirements of 14 CFR Part 33 amendment 33-21, section 33.201."
And from the Trent 1000 TCDS:
"NOTE 13. These engines are not ETOPS eligible according to provisions in FAR 33.201"
I do know that engine/airframe combinations must be certified for ETOPS. However, the fact that an engine is not "eligible" for ETOPS sounds starnge. Can anyone explain?
A342
Exceptions confirm the rule.
oly720man
RE: No Etops For GEnx And Trent 1000?
Sun Apr 26, 2009 5:36 pm
I'm no expert, but looking at FAR 33.201 which is
Design and test requirements for Early ETOPS eligibility (my emphasis)
http://rgl.faa.gov/Regulatory_and_Gu...0A6B2862572960077090F?OpenDocument
I presume that the respective engines probably haven't run up enough hours to satisfy the various testing requirements.
A342
Sun Apr 26, 2009 7:01 pm
Quoting Oly720man (Reply 1):
Ah, that explains it. Thank you!
Users browsing this forum: deceshon85, FGITD and 2 guests
