cotparampguy
Weather Effects On The Ramp
Wed May 13, 2009 8:10 am
What are your airport's procedures for closing the ramp during inclement weather? In TPA a loud horn sounds to warn of lightning detected within 5 miles and the ramp is closed.
Also I have been wondering, has there ever been a case of a ramper being hit by lightning?
Buyantukhaa
RE: Weather Effects On The Ramp
Wed May 13, 2009 10:11 am
Quoting COTPARampGuy (Thread starter):
Slightly off-topic, but when I visited the USS Intrepid museum some years ago, it started pouring down and I sheltered under the SR-71, then I saw lightning strike within a few hundred metres, in the Hudson river. I wonder if they had earthened the plane or not - either way, I guess I was very very lucky that lightning didn't strike "my" Blackbird...
Which brings me to the question, what if lightning strikes a parked plane?
I scratch my head, therefore I am.
FlyDeltaJets
Wed May 13, 2009 10:43 am
Planes when on the ground are earthened by thier tires. The lightning strikes the plane and goes into the gound through the tires or anything else that is touching the aircraft and ground at the same time.
The only valid opinions are those based in facts
Tristarsteve
Wed May 13, 2009 10:54 am
Quoting FlyDeltaJets (Reply 2):
Like the headset of the guy doing the pushback.
I am amazed that radio pushback headsets are not in common use yet. One day someone will get killed using one in a storm.
VirginFlyer
Wed May 13, 2009 3:02 pm
Quoting TristarSteve (Reply 3):
A number of years ago a bloke at Sydney did get zapped. Very lucky not to die, but sadly I believe he suffered serious and permanent disability as a result. I believe after that there was a change in procedures when storms were in the vicinity.
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
MD11Engineer
Wed May 13, 2009 7:34 pm
I have indirectly witnessed two incidents where people on the ramp got injured by lightning.
The first case was a former colleague of at a previous job. He was walking out a 727 while being on the headset when lightning struck nearby. He went down like a poleaxed ox and had to be brought to hospital. He recovered fully though and was back at work a fewdays later.
The second case happened at the airport I'm currently working on. While unloading a DC-10 a ramper, who was operating a high lifter, got struck by lightning. He also had to spend several days in hospital, but returned to work about a week later. This incident caused some sparks with the ramper's union and the health and safety people, because the ramp manager had insisted that his workers should be loading the aircraft while a thunderstorm was overhead , to make up for a delayed arrival of the aircraft, even though operations suggested that he'd stop loading while the storm was in progress.
For myself, as a shiftleader, none of my mechanics will be working outside if a thunderstorm is within 10km / 5 miles of the airport.
Jan
jetstar
Wed May 13, 2009 9:22 pm
Two years ago I was on an AA MD-80, we were headed for TPA, but because a line of thunderstorms was approaching TPA we diverted to MCO to wait it out, because of refueling delays the same line of thunderstorms came through MCO just before we were to be refueled.
Before the line of thunderstorms came through, I heard an announcement over the ramp PA system that the ramp was closed, so everyone headed indoors until the thunderstorms were well past.
JetStar
DaBuzzard
Wed May 13, 2009 9:53 pm
Quoting MD11Engineer (Reply 5):
That kind of thing has never made sense to me...if the storm is ON the field, nothing is going to be coming or going anyways! Not going to save anybody any time at all.
Would you land / take off in the teeth of a thunderstorm? Would any sane pilot?
Thu May 14, 2009 8:13 am
A Circular/Telephone call is issued to the Admin officer of the Airlines concerned.Also alert is flashed by the airports authority & monitored by the FDO of each airline.
Rains can be tough in Mumbai accompanied by Thunder & lightening.
I still remember the chilling nights in rain awaiting pushback & talking to the crew on the headset while they sipped away on their coffee in the dryness of the flight deck.
The coffee in our hands get diluted with rain water in minutes  Smile
regds
MEL
MD11Engineer
Thu May 14, 2009 9:04 am
Quoting HAWK21M (Reply 8):
Try this in a northern European winter at night. If there was a longer delay I would ask the pilots to let me disconnect to either sit in the van until they would flash the taxilights when they got their clearance or (on a 757 or bigger) would stand under the aircon pack heat exchanger exhaust vents until they would call me with the ground call horn.
Jan
EireRock
Fri May 15, 2009 12:10 am
Quoting MD11Engineer (Reply 9):
Always a nice place to stand on a cold morning/night!!
Good use of comedy here!
CFV2
Fri May 15, 2009 12:55 am
A number of the airports in the National Airports System in Canada use a lightning early-warning system built by Thorguard. Procedures are a bit different for each airport - In YYZ, when the system is activated a strobe light will begin to flash and the ramp guys all scurry inside. I think YYC just has a general call-out when the system indicates incoming lightning, and it's up to the airlines and ground handlers to get their people inside, usually through their crew radios.
I was told a few years ago that these systems became the norm after a couple of fuellers at YYZ were killed by lightning in separate incidents.
I just do what I'm told.
Fri May 15, 2009 10:17 am
Thats where it gets crowded on a rainy day/night,especially a B737.The ideal drier.As it even dries out the tarmac.
The B757 is much higher.so the ground is still not dried.
regds
MEL
josekmlb
Fri May 15, 2009 10:16 pm
Yes on the east coast out here in MLB we were pushing out a DL737-800 from the gate and Lightning hit the tail of the A/C went threw to the nose where we had to ramp agents taking off the tow bar and the lightning came out the tow bar and hit them both. They went to the ER with no Major problems, And one of them was like in his 60's and he is fine.
Quoting BuyantUkhaa (Reply 1):
During the push back on that 737-800 when the lightning hit the plane it fried everything in the cockpit.
Same flight the pushback driver had his headset grounded to the tug which saved his life since he got nothing from that strike.
josekmlb
Fri May 15, 2009 10:23 pm
Don't you just love that when its raining hard and your out in the rain waiting to push them out, and the pilots take there sweet ass time to say cleared to push. I know they are waiting on the F/As or push clearance but still it sucks to see them nice and dry while you are getting the flu waiting for them to tell you to push us out.
stratosphere
Sun May 17, 2009 12:00 am
It actually has happened...I can't remember how many years ago or the details but I believe it was a USAIR mechanic was killed when he was on a headset and lightning struck the a/c. Maybe someone on here has the particulars.
cloudyapple
Sun May 17, 2009 6:46 am
Every summer we have tropical storms that come with lightning. We had a number of fatalities in more than one occasions where maintenance crew were stuck. We had the lightning warning system installed since then and we have not had any more injuries or deaths. But that does mean the airport grinds to a complete halt for as long as the system thinks there may be a possibility of lightning strikes. The art has been to adjust its sensitivity to reduce the number of false alarms.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
FlyASAGuy2005
Sun May 17, 2009 2:36 pm
Wow! With us, when OPS makes the call that the ramp is closed, the ramp is closed. The ramp manager or supervisors has no say so.
What gets measured gets done.
wn676
Sun May 17, 2009 11:29 pm
They call out ramp closures over the radio and the PA system in the breakrooms here. The criteria for closing the ramp due to lightning is, IIRC, any strike within 7 miles. We re-open after 5 minutes of no activity. The thing that always gets me is that there can be cloud-to-cloud lightning directly overhead, but we'll all be out working. It's slightly unnerving.
I've seen some pretty wicked storms blow through. Last summer we had a cell pass overhead that managed to push an Aeromexico plane into a jetway. Winds were upwards of 70 mph as I recall.
I've never heard of a guy getting fried out here though.
Tiny, unreadable text leaves ample room for interpretation.
Tue May 19, 2009 6:17 pm
Quoting JoseKMLB (Reply 14):
The Flight/Cabin crew do offer us some warm coffee too,unfortunately its too heavy rain that reduces the enjoyment of that warm drink  Smile
At BOM the rains can get very heavy....It would start raining in a couple of weeks too.
regds
MEL.
WestJetForLife
Fri May 22, 2009 4:59 am
Quoting DaBuzzard (Reply 7):
Someone should have asked that question to the crews of DL191, EA66 and PA759.  Sad
In regards to the OP: when I was working on the ramp at YYC for Air Cadets (doing volunteer work washing planes, etc.), it was mid-June and a thunderstorm was coming in from the northwest. These types of "nor-westers" as I call 'em come with rain, thunder, lightning and hail.
Our Squadron Liaison Sgt. told us to book ass inside when he saw two flashes of lightning about 4-6km away from the field. The ramp supervisor at Shell Aerocenter called a "red alert" and got everyone inside the Aerocenter for about an hour. Coffee and refreshments were served to us poor Air Cadets who got soaked in the rain. Big grin
Nik
I need a drink.
josekmlb
Sun May 24, 2009 7:57 pm
Well all of Florida has been under the gun for about a week now from these storms. Anything other than the MCO fuel problems go on at any other stations?
dxing
Sun May 24, 2009 9:24 pm
Why use even those when tried and true hand signals will suffice?
Warm winds blowing, heating blue skies, a road that goes forever, I'm going to Texas!
Mon May 25, 2009 10:25 am
Quoting JoseKMLB (Reply 21):
Visibility can get really bad during heavy rains at BOM in minutes.
regds
MEL
josekmlb
Mon May 25, 2009 5:35 pm
Quoting HAWK21M (Reply 23):
regds
Its been like that all week here in Florida and I even think MCO was down to 1/4th of a mile yesterday 5/24, we got luck out here in MLB as the storm just by passed us.
wn676
Mon May 25, 2009 11:12 pm
Quoting DXing (Reply 22):
Well, at least where I work, we'd run into a staffing problem since most gates only have a lead and two assists.
josekmlb
Mon May 25, 2009 11:24 pm
Hand signals do just fine as long as you dont forget to tell the pilot, because we forgot to tell the capt of this one flight out here and he was pissed. He made the FA open the door and made one of us go up there tell him our headset was inop and go over hand signals for pushback. But I rather use the headset over the hand signals any day of the week, I think it is just better to have voice com than hand signals.
Tue May 26, 2009 8:11 am
Quoting JoseKMLB (Reply 26):
As long as the message is relayed properly,hand signs are adequate.We always use the Headset unless there is a last minute snag with the existing set.
regds
MEL.
Users browsing this forum: a36001, Mangs and 3 guests
