PhilSquares
A350XWB Weight Issues
Wed May 13, 2009 1:56 pm
Looks like Airbus is having some weight issues with the 350XWB.
http://www.flightglobal.com/articles...hrust-values-following-weight.html
Fly fast, live slow
Stitch
RE: A350XWB Weight Issues
Wed May 13, 2009 5:26 pm
We've known for almost a year that the A350XWB was heavier then originally planned when they announced the 2t MWE overage and 3t MTOW increase to cover it last June. In May of that yeay, Germany’s Handelsblatt newspaper claimed in a report that the MWE overage was in excess of 8t which Airbus denied and subsequently reported the 2t/3t numbers. However, they did not announce a thrust increase would be required to compensate until now. The original thrust reductions were announced in September 2007.
This brings the A350-800XWB back to the original thrust spec, though the A350-900XWB remains 3000lbs less and the A350-1000XWB remains 2000lbs less then the original specification Airbus announced at Paris 2007.
It appears that the claimed superior wing design (which itself was extended close to 1m from the Paris 2007 specs) of the A350-800XWB could not alone compensate for the MWE/TOW increases and Airbus needed to increase the thrust back to 75,000lbs, matching the 245t MTOW 787-9.
Which I personally find mildly intriguing because many have put forward the opinion that the A350-800XWB is "overwinged" for it's size and should therefore have the best aerodynamic performance of the family, yet Airbus could not lower the thrust ratings for it's engines...
jambrain
Thu May 14, 2009 6:44 pm
Quoting Stitch (Reply 1):
I'm sure RR would say as the TrentXWB for A358 and A359 are identical except for rating plug, it's not exactly the biggest deal in engineering history to add thrust to 800 vesion!
Jambrain
Stitch
Fri May 15, 2009 2:17 pm
Quoting Jambrain (Reply 2):
I understand it's not a problem for Rolls.
I'm just interested in why, while the larger and heavier A350-900XWB and A350-1000XWB don't need as much thrust as Airbus originally planned for, the A350-800XWB does, and it's supposed to be the most aerodynamically efficient model of the family because the wing is said to be larger then it needs to be for the plane, so it generates additional lift which should reduce the thrust needs.
osiris30
Fri May 15, 2009 2:29 pm
Not true. This is the second thrust bump on the 350XWB. From the article:
This is the second thrust adjustment for the A350. In 2007, Airbus revealed reductions in nominal thrust values of between 1,000lb and 4,000lb for each variant.
(edit) Forget I said anything.. Misread what Stitch said and somehow managed to confuse myself in the process. Thanks for the correction below (/edit)
[Edited 2009-05-15 07:41:15]
I don't care what you think of my opinion. It's my opinion, so have a nice day :)
A342
Fri May 15, 2009 2:35 pm
Quoting Osiris30 (Reply 4):
Read closely. They previously REDUCED the thrust targets.
Exceptions confirm the rule.
astuteman
Fri May 15, 2009 4:17 pm
Quoting PhilSquares (Thread starter):
Thanks for the link.
The thrust bump is news.
The weight "issues" are very old news, and not "issues".
Airbus responded to a 2.2t growth on OEW with a 3t growth in MTOW and 5t growth in MZFW, to resolve the "issue".
These thrust levels are still either below or the same as the thrust levels originally declared 2 years ago.
nomadd22
Fri May 15, 2009 4:31 pm
Can't we just copy and paste the last 6 years of A380/B787 comments with the names changed and save time?
Anon
Pellegrine
Fri May 15, 2009 5:06 pm
Quoting Stitch (Reply 3):
Possibly because it is supposed to have the highest range of the family.
oh boy, here we go!!!
osiris30
Fri May 15, 2009 7:13 pm
Quoting Astuteman (Reply 6):
See my edit comment... I was still half asleep responding and my brain took a hard right into 'moron mode'.
Stitch
Fri May 15, 2009 10:29 pm
Quoting Pellegrine (Reply 8):
Well the A350-800XWB's MTOW is now 3t higher then the 787-9, so that it only needs the same thrust might be due to the better aerodynamics of the wing.
With identical wings on the 777-200 and 777-300, the 777-300 needed 20,000 pounds more thrust to support 115,000 pounds more TOW, which is a ratio of 5.75:1.
With identical wings on the A350-800XWB and the A350-900XWB, the A350-900XWB needs 9,000 pounds more thrust to support 44,100 pounds more TOW for a ratio of 4.9:1. And for the A350-1000XWB, it needs 19,000 pounds more thrust to support 110,300 pounds more TOW for a ratio of 5.8:1.
Caryjack
Sat May 16, 2009 12:13 am
Quoting Nomadd22 (Reply 7):
What?? and miss all this???
Quoting Osiris30 (Reply 9):
Please pass the popcorn.  laughing
Cary
Users browsing this forum: Balerit, vhqpa and 14 guests
