2H4
New Video Of Spiroids Emerges-What's Their Status?
Wed May 13, 2009 8:13 pm
John Croft of FlightGlobal just shot a video of a video playing at Aviation Partners' booth at the European Business Aviation Association's annual exhibition in Geneva this week:
http://www.flightglobal.com/blogs/as-the-croft-flies/2009/05/gratzers-spiroids-in-flight.html
So it seems that Aviation Partners is actively promoting spiroids....yet it's virtually impossible to find any additional information about the program or its status. Their website simply says "Stay tuned for more developments on this promising technology".
Has anyone seen any additional news and/or updates on their progress with spiroids?
2H4
Intentionally Left Blank
Part147
RE: New Video Of Spiroids Emerges-What's Their Status?
Wed May 13, 2009 8:34 pm
Looks like an interesting technology...
http://www.flightglobal.com/blogs/fl...piroid-wingtip-technology-the.html
http://www.patentstorm.us/patents/5102068.html
If it's so good though, why hasn't it been included on any of the newer designs? After all it's been around for 15 years now!
It's better to ask a stupid question during training, rather than make a REALLY stupid mistake later on!
2H4
Wed May 13, 2009 8:49 pm
Quoting Part147 (Reply 1):
I suppose because 1) they own the patent, and 2) it hasn't been their top priority.
2H4
Fly2HMO
Wed May 13, 2009 8:57 pm
Yeah really. you'd think the massive 10% improvement would certainly justify any additional costs over normal winglets/wing fence/blended winglets.
2H4
Wed May 13, 2009 9:08 pm
Quoting FLY2HMO (Reply 3):
Perhaps they offer huge improvements in certain (ie:cruise) segments of flight, but produce huge problems in others. In which case, they would have presumably been working on minimizing the problem areas.
2H4
Francoflier
Thu May 14, 2009 12:31 am
Quoting 2H4 (Reply 4):
I'm guessing structural strenght problems, weight, and maybe icing. It looks like a pretty frail structure exposed to a lot of aerodynamic stress...
Faro
Fri May 22, 2009 11:01 am
Quoting Francoflier (Reply 5):
Perhaps if it were make of CFRP the structural issues would largely be put to rest. Would such a CFRP structure easily be de-iced however?
Faro
The chalice not my son
tdscanuck
Sat May 23, 2009 2:22 am
Quoting Faro (Reply 6):
Why would you need to? We generally don't deice winglets today.
Tom.
Faro
Sat May 23, 2009 5:46 pm
Quoting Tdscanuck (Reply 7):
You're abosolutely right, never thought about that! Is it because of the thinness of the head-on airfoil section? Too little head-on surface & too great a curvature for the droplets to adhere to?
I'm guessing that one of the problems with these devices may be the behaviour of the air inside the closed loop section, caught between closely-spaced aerodynamic surfaces. Perhaps leading to a resonance of sorts at certain airspeed/AOA/sideslip combinations.
Faro
Sat May 23, 2009 6:55 pm
Quoting 2H4 (Reply 2):
My experience with patents was that the validity period for exclusivity for the patent was 15 years, which would have expired in 2007 if it was obtained in 1992. I am assuming then they have come up with a novel change to the device.
Quoting Faro (Reply 8):
Two reasons I can think of, the angle they have o the vertical would not normally allow slow to rest on them, and no fuel being inside them, so in a humid place, unlike a wing with super cooled fuel, frost should not form on them.
Faro
Sat May 23, 2009 8:24 pm
Quoting Zeke (Reply 9):
Indeed that takes care of snow and frost; what about supercooled water droplets in the atmosphere?
Faro
Sat May 23, 2009 8:55 pm
Quoting Faro (Reply 10):
That is not a trivial observation, and it would require testing/validation. I would think due to the size of them compared to the wing it would not be significant enough, and one would need to assume it is a symmetrical effect.
tdscanuck
Sun May 24, 2009 6:42 am
I strongly suspect they'd ice, I just don't think it would matter. You would have to prove this as part of the flight test program, of course. Most of the lift on a commercial airliner wing is generated well inboard. The impact on lift, and the amount of ice weight you can gain, would be pretty limited out on the wingtip. Even on airplanes without winglets, the anti-ice usually doesn't extend all the way to the tip.
Tom.
Faro
Sun May 24, 2009 1:35 pm
Quoting Tdscanuck (Reply 12):
What about the flutter characteristics of the wingtip/winglet with a mass of ice parasiting their surfaces? Would certification testing also include that scenario or do the authorities assume that icing is always temporary?
Faro
tdscanuck
Sun May 24, 2009 3:27 pm
Quoting Faro (Reply 13):
That's a really good question. My immediate suspicion is that wingtip icing isn't a critical flutte condition because of two factors:
1) Icing tends to reduce lift, which tends to reduce the force on the wingtip, making flutter less likely
2) The mass of ice a wingtip could accumulate is, I suspect, much lower than the mass change associated with full vs. empty fuel tanks.
However, that's just wild guesses...I've never come anywhere close to doing a flutter-in-icing analysis, so I really don't know. Empirically, it doesn't seem to be a big deal with winglets because we don't anti-ice them now, but that might be different for spiroids.
You need to be able to maintain safe fight and landing in known icing conditions. However, I don't believe there's a requirement that, if you're in bad icing, you stay in it. You have to remain safe long enough to land or climb back above the icing conditions.
Tom.
2H4
Wed May 27, 2009 2:25 pm
New info, courtesy of John Croft at FlightGlobal:
Aviation Partners plans to fly its second-generation spiroid winglets on a company Dassault Falcon 50 in the third quarter. The flight is part of the $2 million earmark the company received last year to further investigate the novel devices, in part to analyse the potential for reducing aircraft separation distances.
API founder and president Joe Clark says the new spiroids, now in design, are likely to eliminate wingtip vortices in the near field region, although the effects in the far-field, roughly 4.6-5.6km (2.5-3nm) behind the aircraft, will have to be determined by test. API plans to equip its Dassault Falcon 50 with the devices as part of the research programme, which is being managed by the US Department of Transportation's Research and Innovative Technology Administration (Rita).
Aside from aerodynamic performance, Thompson says there remain "significant" manufacturing challenges in building a structure that will be stiff enough to be aerodynamically correct through all flight regimes, but also economical to manufacture.
Engineers are investigating a variety of materials, from composites to metal, from which the looping wingtips might be constructed. A vendor has not yet been selected to build the devices for flight tests that are expected to begin in the summer or early autumn, says Thompson.
Full article here
Does anyone know where that Falcon will be based? A shot of it with spiroids fitted would be one heck of a catch!
2H4
Faro
Wed May 27, 2009 5:55 pm
Quoting 2H4 (Reply 15):
Wow, thanx for the feedback!! Looks like we may well be looking at operational spiroidesque wings sometime in the (perhaps distant) future.
Faro
DocLightning
Thu May 28, 2009 11:51 pm
The articles say that a spiroid wing combined with a new-gen engine like the GTF or LEAP could knock 22-25% off fuel burn without even considering other advances like changes to the airframe.
Ka-wow.
-Doc Lightning-
-Carl Sagan
2H4
Sat Jul 17, 2010 2:50 pm
Well well well....look what's listed on the list of visiting aircraft at Oshkosh Airventure 2010:
- Falcon with spiroid winglets
Part147
Thu Jul 29, 2010 9:13 pm
Well caught 2H4!!!
And here they are on A.net...
Photo © Melvin Pereira
Impressive!
[Edited 2010-07-29 14:15:30]
Users browsing this forum: Bing [Bot], CPierre, DouglasDC9 and 16 guests
