phatfarmlines
Front-Door Pax Door On ATR- Where To Put Cargo?
Sun May 17, 2009 7:35 pm
Photo © Andrei Nesvetaev
Finnair uses the front door as a pax loading door on their ATRs, normally reserved for the cargo section. In lieu of the cargo section, does this configuration move the cargo section to another part of the aircraft, such that the volume of cargo space remain the same?
FlyASAGuy2005
RE: Front-Door Pax Door On ATR- Where To Put Cargo?
Sun May 17, 2009 9:38 pm
It's possible they only use the other cargo hold in the back behind the galley section but someone else familiar with this config. would have a better answer.
What gets measured gets done.
Okie
Mon May 18, 2009 2:25 am
I checked Wikipedia and Finnair ordered variant with front passenger door to allow use of jet bridge at front of aircraft. Although I have been on an ATR's where they used the jet bridge at the rear. I suspect you get to walk through a mountain of bags.
The ATR's have been from my experience one of few aircraft where moving passengers for CG issues is pretty common and carry a stinger to keep aircraft from tipping on its tail while loading at the rear. They have some cargo space at the rear but I am not sure how much weight that can be placed at the back with that much moment.
Okie
744rules
Mon May 18, 2009 4:33 pm
not 100pct sure, but if memory serves well, the std ATR takes cgo/bags behind the cockpit.
There are 2 net sections, so a small gangway is created.for acces between cockpit and cabin, but not for pax use. This is for the version with paxdoor in the rear. The -72 also uses a tailstand to avoid tipping during boarding/deboarding.
Tue May 19, 2009 6:14 pm
If not mistaken the ATR72 has a net on the RH side to hold the cargo towards the right,providing a space on the Left to walk through.
regds
MEL.
andaman
Tue May 26, 2009 10:45 am
Quoting Phatfarmlines (Thread starter):
finnair uses the front door as a pax loading door on their ATRs
Finnair don't fly ATR's anymore, also the 'front-door-ATR's are sold out. The OH-KRA in the picture above first went to Aero Airlines, then to Aer Arann.
Their partner FinnComm operate ATR-42/72 aircraft now in Finland, with more traditional doors.
Photo © Juha Kankkonen
[Edited 2009-05-26 03:54:04]
Chinese cookie in SFO: "You're doomed to a life of forever travelling abroad and to be able to afford it!"
EMBQA
Tue May 26, 2009 2:30 pm
Quoting 744rules (Reply 3):
That is the question the OP is asking. The standard ATR72 has a large cargo hold just aft of the cockpit... but with the forward pax door version where does the cargo go..? The area taken up by cargo is now pax seating......
super737
Wed May 27, 2009 8:56 am
Photo © Kevin M Bates
Good morning, folks having worked with this a/c several times I can tell you that the above picture, showing the starboard side, both doors are access to the holds believe it or not.
If its not a super tractor its not a plane
Users browsing this forum: VC10DC10 and 20 guests
