Faro
Loss Of All VHF Comms On MS Flight
Tue May 19, 2009 2:27 pm
ACARS message copied today at www.acarsd.org:
ACARS mode: 2 Aircraft reg: SU-GCJ [Airbus A332]
Message label: SA Block id: 8 Msg no: S59A
Flight id: MS0799 [CAI-CDG] [Egyptair]
Message content:-
LOST VHF AT 112318 ACTIVE COMMS SATCOM+HF
What kind of hitch can lose you all your VHF transceivers at the same time and leave SATCOM and HF intact?
Also, are all airfields equipped with SATCOM/HF installations? From what I recall for HF stations in particular, you need huge, outstretched rhombic antennas to maximise signal quality and big open spaces all around them to avoid interference.
Faro
[Edited 2009-05-19 07:38:00]
The chalice not my son
ManuCH
Crew
RE: Loss Of All VHF Comms
Tue May 19, 2009 2:31 pm
I have no idea what could have caused this. But what I can tell you is that most airfields will *not* have HF for sure. AFAIK HF is only used for trans-oceanic communications. And SATCOM isn't usually used to communicate with airports either.
This could become interesting. How is the airplane communicating, for example, with the tower? Via company on ACARS?
Edit: actually ACARS has ATC datalink messages. But are there any airports supporting them, or are they only thought for oceanic clearances?
[Edited 2009-05-19 07:33:44]
Never trust a statistic you didn't fake yourself
DescendVia
RE: Loss Of All VHF Comms On MS Flight
Tue May 19, 2009 2:46 pm
Quoting ManuCH (Reply 1):
While this is true there is a lot of towers which has a military channel that is HF.
I'm sure this plane has CPDLC so no big fuss for so equipped FIRs. Other then that they probably either are using the available HF channels or have SAT tied into each FIR. A lot ACARS systems don't actually have a feed to ATC just the company.
Worst comes to worst, they would just land as soon as practicable and get light gun signals from the tower (if so equipped in this region) in VMC.
[Edited 2009-05-19 07:48:03]
PhilSquares
Tue May 19, 2009 3:03 pm
Quoting DescendVia (Reply 2):
Don't think so.....
Fly fast, live slow
KELPkid
Tue May 19, 2009 3:11 pm
Time to squawk 7600 and hold until your arrival time?  eyebrow  Wonder if the captain and/or FO carry a handheld transceiver with them...  Wink
DaBuzzard
Tue May 19, 2009 3:47 pm
We use hf quite a bit in the far north, pretty common to not be able to reach anyone on the vhf. Our flight crews also carry a sat phone, guess you could call the tower's landline in a pinch  Smile
Quoting Faro (Thread starter):
Only common point I can think of on our (much smaller) aircraft would be the audio selector panel. No idea how the 'Bus is configured but it must have some way of selecting what nav/comm audio gets routed to/from the headset/mic.
DescendVia
Tue May 19, 2009 5:30 pm
Quoting PhilSquares (Reply 3):
Don't think so..
MLS23
ILS05
Whatcha call 291.1 for Pope tower or 257.7 for MBS tower  Wink
Pihero
Tue May 19, 2009 5:36 pm
Quoting DescendVia (Reply 6):
UHF frequencies.
Contrail designer
PhilSquares
Tue May 19, 2009 5:41 pm
As has been pointed out by Pihero, those are UHF frequencies. Every commercial aircraft I have flown has VHF only! They are a far cry from HF frequencies!  banghead
Fly fast, live slow
spudsmac
Tue May 19, 2009 7:57 pm
HF is actually lower than VHF and of course UHF here is a table that goes over that from my avionics course:
0-30 KHz, Extremely Low Frequency (ELF)
3-30 KHz, Very Low Frequency (VLF)
30-300 KHz, Low Frequency (LF)
300 KHz-3 MHz, Medium Frequency (MF)
3-30 MHz, High Frequency (HF)
30-300 MHz, Very High Frequency (VHF)
300-3 GHz, Ultra High Frequency (UHF)
3-30 GHz, Super High Frequency (SHF)
30-300 GHz, Extremely High Frequency (EHF)
zappbrannigan
Tue May 19, 2009 9:11 pm
Quoting KELPkid (Reply 4):
Yep, can't speak for the problem itself, but there are very specific procedures for loss of comms in controlled airspace - there's not a lot of "gee what do we do now, I suppose we should hold for a bit then land".
Here, in a nutshell, the procedures are basically squawk 7600, then continue flight and descent as per flight plan/SOPs, descend as appropriate for "the most suitable approach" (straight out of the book), and in many cases wait for the green light from the tower, as mentioned.
In the aircraft I fly (i.e. not big jets), when our VHF goes bang (as has happened to me twice before), we listen out on specific NDB frequencies for instructions as well.
The last time this happened to me on arrival, we got our clearance to enter controlled airspace, and our visual approach clearance, via cell phone from the tower. About one mile out - green light, all good. Ahhh, the wonders of GA.
DescendVia
Tue May 19, 2009 10:47 pm
Quoting Pihero (Reply 7):
Quoting PhilSquares (Reply 8):
Boy I sure dropped that ball  Embarrassment
As I trued off my computer to go flying, I was like I bet those are actually UHF freqs  Smile O well......
Faro
Wed May 20, 2009 8:12 am
Quoting Zappbrannigan (Reply 10):
Interesting, is this a green flare or a directed light source like VASI's and the like? Is it visible in full sunlight? Anyone know of any pix in the database of this "greenlight"?
Faro
KELPkid
Wed May 20, 2009 8:06 pm
Quoting Faro (Reply 12):
Faro
In the US at least, it's a "light gun", which is a very bright incandescent lamp which can be triggered on and off (blinked) or the color changed from white to green or red, or both. The gun has a Fresnel lens, so that when it's pointed at your aircraft, you know it...it works great in daylight, too.
Similar to this: http://www.atiavionics.com/products.html
except that in most US air traffic control towers, the light gun is permanently mounted in the tower cab window (but is free to swivel around...).
Faro
Wed May 20, 2009 11:02 pm
To get back to the initial question, what sort of redundancy is typically afforded by the VHF comms set-up? Are all transceivers located separately from one another? Are antennae distributed about the fuselage? Can a problem with the Audio Selector Panel really lose you all your VHF's?
Faro
KELPkid
Wed May 20, 2009 11:33 pm
Quoting Faro (Reply 14):
Faro
You know, a thought just sprung to mind here: doesn't ACARS work over VHF radio? (I thought it did-someone can correct me if I'm wrong here....). How do you get an ACARS message out if your COMM stack is kaput?  scratchchin  I guess you could have a company aircraft that you're on frequency with on HF relay something for you...  Wink
PhilSquares
Thu May 21, 2009 6:07 am
Quoting KELPkid (Reply 15):
Yea, ACARS works over VHF. However, depending on the carrier, it can also work over HF or SATCOM. For most long haul carriers, the ACARS set up is VHF as the default, then either ACARS or HF as a back up. Or in some cases, both SATCOM and HF would be tried.
Generally the transceivers are located in the lower E&E compartment. The antennae are located in various places. The VHF1 and 3 are normally located on the lower fuselage while VHF 2 is located on the top of the fuselage. And, I suppose the ACP could take out all the VHF but it would most likely take out the intercom and all other radios with it. Anything is possible.
Fly fast, live slow
ThirtyEcho
Thu May 21, 2009 8:04 am
Interesting that we have been ready for lost com since about 1935: "Airspiffy 123 is cleared to Bugtoe as filed, climb and maintain 6000, expect FL190 10 minutes after departure..."
Some winter's night, curl up in a chair by the fire and read the AIM on lost com and be amazed. You can get from A to B in total silence and total safety, even in IMC.
A10WARTHOG
Thu May 21, 2009 9:23 pm
If your ACP goes out, you will lose all comm (VHF, HF, SATCOM, PA, etc) I would doubt it that it was an ACP, Plus you would have the other ACP that you could use to TX.
I would need wiring diagrams to see if you had anything common between the three systems. Your wiring is different, between the three system. The only thing i could see common with what little info I could find on the web is the Audio management unit (I think that is what airbus calls it). Maybe part of the box failed.
PhilSquares
Thu May 21, 2009 9:35 pm
In doing a little research, the ACARS message is a ACARS generated msg that indicates it has lost the VHF link and will now send via SATCOM or HF. There was no complete loss of VHF radios.
Fly fast, live slow
Faro
Fri May 22, 2009 9:35 am
Quoting PhilSquares (Reply 19):
Thanx, that settles the matter. Was myself surprised that this indication can be found so easily in an ACARS message. A full VHF comms failure must, happily, be a much rarer occurence.
Faro
CosmicCruiser
Fri May 22, 2009 1:26 pm
That's interesting since our ACARS has a priority selection. It picks VHF first then depending on whether an HF radio is in data mode will select it next then SATCOM. We do not run any HF in data if SATCOM equipped therefore HF isn't a player. All of our -11s are so equipped. I would assumme most all jets are so packaged.
Loss of all comms would be rare since the VHF radios are on different busses. I did have a mike stick one night right on T/O that disabled all radios until we found the culprit. It took several minutes since we could still hear ATC and THOUGHT we were transmitting for a moment or two. When we realized the problem we started searching for the stuck button but considering there are 8 between the capt & f/o it took a few more min. We started unplugging all mikes that could be unplugged and finally found the f/os yoke switch as the bad one.
KELPkid
Fri May 22, 2009 3:18 pm
Quoting CosmicCruiser (Reply 21):
 rotfl  Glad to hear that it's not just us GA drivers who deal with stuck mic switches. Don't your audio panels have a light that comes on, though, when you're transmitting?
PhilSquares
Fri May 22, 2009 3:23 pm
Ours do too. But if you get a VHF No Comm, it will sent a test message via either SATCOM of HF date burst that checks the comm in that mode. Ours are set for VHF, SATCOM and then HF Data Burst.
Fly fast, live slow
CosmicCruiser
Fri May 22, 2009 3:55 pm
Quoting KELPkid (Reply 22):
No but if the mike is keyed for a certain number of seconds you hear a tone beep which we heard right as the power was being pushed up and I didn't think much about it. We didn't hear it again but there was lots of radio activity and we may not of heard it.
Quoting PhilSquares (Reply 23):
Sounds like ours. We actually don't put any HF in data mode if there's SATCOM because of something to do with HF and FANS.
PhilSquares
Fri May 22, 2009 4:21 pm
Quoting CosmicCruiser (Reply 24):
Ours is the same way. I don't recall ever having it default to the HF mode since SATCOM is extremely reliable. But, we do see SATCOM all the time.
Fly fast, live slow
CosmicCruiser
Fri May 22, 2009 5:15 pm
Quoting PhilSquares (Reply 25):
Next best thing since sliced bread!! Even the SATCOM radio calls are like talking to your next door neighbor. I heard about a pilot that turned his bid in via SATCOM! I'm sure he visited the Chief pilot the next day. LOL
ManuCH
Crew
Mon May 25, 2009 2:28 pm
Quoting ThirtyEcho (Reply 17):
All this IMHO still leaves the question open on what an *airliner* would do without VHF. Let's assume a 747 flying into JFK. I know about GA procedures, I'm a PPL myself, but I can't imagine a 747 circling above the tower waiting for a green light, or just shooting the "most suitable approach" at an airport like JFK. This would disrupt operations while the tower figures what the 747 might do next, and would put everyone on hold, wouldn't it?
Any airline pilots who would like to share what they would do with no voice VHF, but with a working ACARS, regarding to approach and landing? Would you ask the company for the tower's phone number and use a sat phone to obtain clearance? Would the clearance be obtained via company ACARS? Is there an SOP for something like this?
PhilSquares
Mon May 25, 2009 3:14 pm
Quoting ManuCH (Reply 27):
First of all, the odds are extremely remote that this would ever happen. But, all you have to do is send a ACARS message to dispatch, they will then contact ATC and advise them you are NORDO and proceeding via XXX. As you get closer you can get the ATIS via ACARS and then just send a message to dispatch advising them you have info X and will do the XXX approach. They can then pass that info along to tower. Then you can also coordinate a company tug or follow me to take you to the gate. Not a big deal.
Fly fast, live slow
zappbrannigan
Tue May 26, 2009 3:43 am
Phil has obviously answered your question - but I thought I'd make the point that these aren't "GA procedures" - they're required procedures for all IFR traffic in controlled airspace here, and are specified on every SID/STAR plate as well as in the emergency procedure sections. The basic procedures don't change - the methods of communication do, and the traffic is probably lots easier to manage with a GA aircraft arriving at a low-capacity airport than a 747 into a very high capacity one.
Of course I'm quoting Australian stuff here, but I assume it doesn't change much around the world.
DescendVia
Tue May 26, 2009 12:52 pm
No need to figure what he "might" do, the stuff is there for a reason. Emergencies tend to disrupt operations and this is why the EFC or ETA is so important to be follow if you have 7600. Those figures give the controller time to "clear" the airspace.
I do think some of the newer published lost comm procedures that are showing up on STARs are great though. No need to hold anymore, just go and shoot the approach.
Users browsing this forum: 747classic, Google [Bot], Majestic-12 [Bot], parapente, StereoTechque and 2 guests
