WestJetForLife
Packs, Bleeds And Engine Starts, Oh My!
Tue May 19, 2009 9:56 pm
Hi, everyone. If there are any current/former 737 drivers that can help me with these questions.
1. During start up, does the 737 have to have its AC packs OFF for start, or can you have them running in the "AUTO" position? As well, do you usually turn your APU bleed off immediately after start or do you leave it on for a while?
2. What is a "bleeds-off" takeoff, and how does it benefit the aircraft during takeoff/initial departure? For those who aren't savvy, the bleeds are used for air conditioning and pressurization.
3. Between the two start switches on the forward overhead panel, there is a switch that is marked "left, both, right" for the engine start. What exactly is that for?
I hope WILCO737 and AAR90 (I think that's him) can help me on this one. Any other 737 pilots that are currently or formerly type-rated in the 737 can help as well.
Thank you,
Nik
I need a drink.
Part147
RE: Packs, Bleeds And Engine Starts, Oh My!
Tue May 19, 2009 10:09 pm
Hmmm?
Are you doing your homework?
1, Normally off for many aircraft
2.
Quoting WestJetForLife (Thread starter):
for those who aren't savvy, t
That sounds a little bit condecending there a 'lil whippersnapper!  Wink
Bleeds off means that all compressed air is used during takeoff, giving max thrust for a given rpm, hence no losses
3. I'm sorry but I gotta to say it - the 'left, both right' switch refers to the 'magnetos', you know, when doing a mag-check - making sure the rpm rpm doesn't drop more than a few hundred rpm  Wink  Wink
PS - Don't use these answers - you'll get an 'F' for sure
Why not look at this site instead? http://www.b737.org.uk/
It's better to ask a stupid question during training, rather than make a REALLY stupid mistake later on!
DashTrash
Tue May 19, 2009 10:43 pm
Are you looking at a MS Flight Sim 737 panel by chance?
Tue May 19, 2009 11:33 pm
1.Since you want max bleed pressure to crank the Engine,hence Packs are switched off to achieve that.
2.Bleeds off T/O,implies no bleeds used from the Engines for T/O,thus no loss in thrust.APU Bleed could be available.Both APU & Engine bleed on will cause a "dual bleed" alert,you don't want engine bleed striking a running APU in case the Apu check valve malfunctions {winks]
3.Left,right or Left&Right ignitors [Both].Normally on one sector LH is used & on the return leg RH.
In case of Ignitor malfunction leading to no light up,then the next start is carried out with the Ignitors to both.
If both was selected first one would never know if LH or RH ignitor was not working until the other working one went u/s too leading to an AOG Situation.
regds
MEL
WestJetForLife
Wed May 20, 2009 4:26 am
Quoting Part147 (Reply 1):
Not really, I just know a little bit about what the bleeds are, thanks to A.Net and b737.org.uk.
Quoting DashTrash (Reply 2):
No. The default panel has no AC/Pressurization panel. I'm just curious about how the 737 pneumatics and engine start procedures are, just because I'm bored and it was bugging me.
I need a drink.
wilco737
Wed May 20, 2009 5:44 am
I am not on the 737 anymore, but I try to remember  Smile
Packs OFF. The 737 is not automated that the packs would automatically swtich to off and the APU is not strong enough to supply air to the starter and to the packs. After starting one engine you can do a "single pack operation during engine start". Then you suplly air from the running engine to the aircondition pack and the APU air to start the other engine.
Packs off during take off. That means you do not need to take air from the engine which increases its performance and you maybe can carry more passengers, cargo etc out of an airport if you are performance limited.
It is for the engine ignition, there are 2 systems. They are used alteratly daily (at my airline).
I hope that explains it  Smile
wilco737
Wed May 20, 2009 2:02 pm
Quoting WILCO737 (Reply 5):
So as air from the APU is required to start the engines, how does the APU get started in the first place? As it is itself a (very small) jet engine, does it not also require air for start? And what role exactly does the air play in starting the engines?
wilco737
Wed May 20, 2009 2:08 pm
Quoting Luke (Reply 6):
The APU is pretty much a small jet engine, but does not require external air to be started, electric and fuel is enough.
Air will be blown into the engine until a certain RPM and then fuel will be ignited and then the engine can stabilize on its own and doesn't need external air anymore.
wilco737
Mir
Wed May 20, 2009 2:32 pm
A battery and an electric starter.
The air spins the N2 section of the turbine up to a certain speed to get some air moving through the engine core, then the igniters go on and fuel is added, and the engine lights off and accelerates to idle from there.
You don't really need air to start an engine - you just need something to turn the N2 section. And in smaller engines, like the ones found on some business jets, electrical power is enough. But the size of the motor that would be required to start an engine the size of those found on an airliner is impractical, and since you have the APU there anyway, you might as well just use its bleed air to do the job.
-Mir
EireRock
Wed May 20, 2009 4:24 pm
Quoting Mir (Reply 8):
On the 737NG you can start an engine off the battery if you have external air, may be the same on most boeings actually, not 100% sure on that.
wilco737
Wed May 20, 2009 10:42 pm
Quoting EireRock (Reply 9):
Yes you can, but the battery needs to be fully charged After that start the battery will be pretty empty. Some kind of an air source is mandatory for the 737.
wilco737
[Edited 2009-05-20 15:44:35]
osiris30
Thu May 21, 2009 12:25 am
* excluding the power plants on the 787, which AFAIK are electric start engines. I believe on the 787 the generators attached to the engine are also motors for start though.
I don't care what you think of my opinion. It's my opinion, so have a nice day :)
ArmitageShanks
Thu May 21, 2009 3:12 am
How much more thrust would you have with packs off compared to packs on? Is it noticeable?
DescendVia
Thu May 21, 2009 3:27 am
Quoting ArmitageShanks (Reply 12):
Is it noticeable?
Its noticeable to the people that didn't get bumped  Smile
tdscanuck
Thu May 21, 2009 5:02 am
Quoting WILCO737 (Reply 7):
Just to clarify, on modern engines you don't actually blow the air directly into the core...the air drives a starter motor (a small pneumatic turbine) on the gearbox. This backdrives the gearbox shaft to spin the N2 spool (not sure if RR spins the N2 or N3). Unless it's a 787, in which case you just run the generators backwards.
Except the 787, yes, anything that will provide adequate pneumatic duct pressure and volume can be used to start the engine. The airplane doesn't really care where the air is coming from, it just needs air to run the starter.
Quoting WILCO737 (Reply 10):
Not on an engine start...an engine start with pneumatic ground power isn't particularly hard on the battery. You may be thinking of APU start on battery...that's a tough one to do more than once or twice.
Tom.
wilco737
Thu May 21, 2009 6:34 am
Not really no. It is just the little bit more you get, but not really noticeable.
Quoting Tdscanuck (Reply 14):
Yeah, I know. Didn't want to go too deep into detail  Smile
Two APU starts on the battery can be indeed tough. Our book says though that even an battery start for the engine the battery should have a certain amount of voltage.
wilco737
jetstar
Fri May 22, 2009 8:00 pm
I’m not nitpicking, but just to clarify this, an APU is not a jet engine, but a gas turbine engine and produces a negligible amount of thrust.
To make a gas turbine engine into a jet engine, an exhaust nozzle or tailpipe has to be added aft of the engine, the aft end of the tailpipe is smaller than the inlet end which forces the exhaust gas to accelerate out of the tail pipe creating the thrust needed for propulsion.
I do not know of any jet engine that used air directly into the engine to start, air pressure or in some early jet engines a shotgun type cartridge which used the expanding gases is directed into a small air turbine motor which turned the engine for starting.
As an A&P mechanic, we always used a pneumatic drill using air from an air compressor, instead of an electric drill motor for sheet metal work. These drills were very light and powerful and almost torque free and use the same principal as a pneumatic starter.
Almost all small biz jets up to, but not including jets like the large Gulfstreams and Challengers use electric starter/generators. These starter/generators are DC motors and product 24 volts DC for aircraft electrical power. The have one armature with 2 sets of brushes, one for starting and one for generating. I am sure out there are some different systems used, but starter/generators are the most common because they can do 2 different applications using 1 component.
JetStar
DL
Sat May 23, 2009 8:18 am
The ECS packs impact on fuel burn consumption is about 2.5% so I imagine this is also the impact on the thrust.
DL
Mender
Sat May 23, 2009 12:32 pm
I've only scan read this thread and no-one seems to have clarified this.
Only piston engines use magnitos. This might be a figure of speech but it could be misleading. The engines have two separate ignition systems. If you always started using both systems you wouldn't detect a failure so it is normal to start with just one. If the engine doesn't light off using the selected system then you select the other one. The igniter plug will wear out just like a spark plug on a piston engine so it is normal to alternately use each ignition system to even out the wear.
in our airline they use system one on the outbound sector and system two on the inbound sector.
The reason you can select BOTH ignitors is for in-flight restart. You really don't want to find a faulty ignition system during in-flight re-start!
cptspeaking
Mon May 25, 2009 5:10 am
Quoting Mender (Reply 18):
He's joking...
I'm nerdy enough I actually found it amusing too  biggrin
I spent some time in the US training center in the B734 full-motion sims. The IP ran us through the engine start procedures and we did single-pack ops after one start.
Basically, procedure was to turn all pack switches off, including the isolation valve. Once we had one engine up and running, we'd establish electrical power, then put the bleed isolation valve switch to "on", then whichever side we had started, the pack to "auto". After starting the other engine, all switches to auto and you're good to go.
I believe US uses L ignition on odd days and R on even days, both for really cold starts or in-flight restart attempts. Continuous below 10' (I think...could be remembering wrong though...).
Jonathan
...and don't call me Shirley!!
