imiakhtar
Help Identifying Engines
Sat May 23, 2009 3:07 pm
Hello folks.
A few years ago on a trip to London, I took a few pics of aircraft engines at various museums. For the life of me, I can not remember the engine models. Pics are below:
Big version: Width: 448 Height: 336 File size: 30kb
Big version: Width: 448 Height: 336 File size: 33kb
Big version: Width: 448 Height: 336 File size: 28kb
Any help in identifying them would be much appreciated.
Whatever happened to Leon Trotsky?
David L
RE: Help Identifying Engines
Sat May 23, 2009 6:51 pm
The first one looks very RR Merlin-esque.
That is all.  Sad
EcuadorianMD11
Sun May 24, 2009 12:13 am
Is it possible to tell different jet engine brands apart from a distance? For instance: Pratt & Whitneys, Rolls Royce etc? Why would an airline go for a specific brand, is this just politics between companies (regular customers getting good prizes) or ar their specific characteristics for certain brands?
I'm thinking about consumption, performance at certain altitudes, maintenance costs etc etc.
Can airports that service jet engines (for instance AMS) service all brands?
One tool fits all?
Ecuadorian MD11.
A lot of people need to be offended on a regular basis I always felt, and I�´m the very boy to do it! - Billy Connolly
tdscanuck
Sun May 24, 2009 6:38 am
Quoting EcuadorianMD11 (Reply 2):
Sometimes. It depends on the distance, but nacelle shape (and knowing what aircraft it is) can be enough for certain engines/types.
It's not just politics. No two engines have exactly the same charachteristics...they fall on different points of the trade studies so some are better for some missions and some are better for others. Past experience in customer support and reliability goes a long way. Availability of maintenance and spares may be a deciding factor. Power-by-the-hour contracts are also a big factor. The engine purchase decision is almost as complicated as the aircraft purchase decision.
For line maintenance, generally yes. For heavy maintenance, it varies wildly by airport. A repair shop needs specific approval for each engine type, so it's just going to depend on what approvals the local shop has, or how many different local shops you've got.
One tool fits all?
For really simple line maintenance, yes. For everything else, generally no.
Tom.
oly720man
Tue May 26, 2009 11:48 am
The bottom photo shows the RB211 and Olympus 593 at the Science museum
http://www.scienceandsociety.co.uk/results.asp?image=10324137
TEAtheB
Thu Jun 11, 2009 10:15 pm
If the aircraft is on the ground, look at which way the fan rotates. For large civil turbofans... if the fan rotates clockwise, it's a Rolls-Royce. If it goes anti-clockwise, it's P&W or GE.
What Tdscanuck said!
KELPkid
Fri Jun 12, 2009 6:34 pm
Quoting David L (Reply 1):
That is all.
However, don't all Merlin variants (Packard license-built ones included) proudly proclaim "Rolls-Royce" on the valve covers  confused
The second one looks like an aero V-12 as well, it's obviously not a Daimler DB-601, as that was an inverted Vee engine...maybe an Allison V-1710?
http://en.wikipedia.org/wiki/Allison_V-1710
DocLightning
Fri Jun 12, 2009 11:49 pm
Quoting Tdscanuck (Reply 3):
An example: on the 744 the RR engines look like this:
Photo © Martin Aves
And GE and PW engines are externally identical and look like this:
Photo © Jonathan Simmons
Now, I know that in the second image they are GE engines because that is a QF bird. All QF 744's are powered by RR engines (AFAIK) UNLESS they are 744ER's. The 744ER is only available with GE powerplants (an odd decision by Boeing, IMHO, because QF was the only customer for that type). So if I see a QF bird with PW/GE-style nacelles, then I know it's a GE engine.
On the other hand, I have trouble remembering which manufacturer other airlines use. I know UA and NW use PW's and that SQ uses GE's. But I don't know who TK, VS, or LH use.
So it is SOMETIMES possible to pin down the engine type, and sometimes you need additional information. On the 787, both GE and RR engines will be externally indistinguishable, AFAIK.
-Doc Lightning-
-Carl Sagan
Viscount724
Sat Jun 13, 2009 12:29 am
Quoting DocLightning (Reply 7):
Close but not quite correct. QF also has two standard 744s (non-ER) acquired used from Asiana and Malaysian. They have GE engines. Those aircraft below. The ex-OZ aircraft is now in the oneworld livery..
Photo © Michael Carter
Photo © Werner Horvath
KELPkid
Sat Jun 13, 2009 1:19 am
And if Lightsaber were around in this discussion, he would slap you silly for saying that  Smile SQ is a Pratt customer on the 744...  Wink
VirginFlyer
Sun Jun 14, 2009 6:46 am
If you look carefully, there are some differences between the GE and PW engines. On the PW, aft of the cowl the engine body is less tapered, then becomes more tapered, while on the GE the taper is pretty much constant. I also *believe* (but stand to be corrected) that on the GE, there is some form of vent on the right hand side of the engine, while on the PW there is a similar vent but on the left. If you look at these pictures you'll see what I mean:
PW:
Photo © Phil Broad
Photo © Tim de Groot - AirTeamImages
Photo © Tim Perkins
Photo © Simon Wong
Photo © Satoshi Yamagishi
Photo © Yuxiaobin
Photo © K.H. Ng - HKAEC
Photo © Sam Chui
GE
Photo © Daniel Alaerts - AirTeamImages
Photo © Planecatcher
Photo © Kiskockas - SkyArts Aviation Photography
Photo © Bjoern Schmitt - world-of-aviation
Photo © Emmanuel Perez - LUX Plane Pictures
Photo © Ian Knight
Photo © Ander Aguirre - AirTeamImages
Quoting Viscount724 (Reply 8):
Actually there are 3 GE-powered 747-400s in the Qantas fleet. In addition to VH-OEB and -OED which you have shown, there is also -OEC.
-OEB, ex-Asiana
Photo © Ted Quackenbush
Photo © Thomas Loh Y. H.
-OEC, ex-Malaysia
Photo © Frank Schaefer
Photo © Jan Jorgensen
-OED, ex-Malaysia
Photo © Michael F. McLaughlin
Photo © Haik Nguyen
SQ uses GE's
I'm pretty sure you'll find SQ uses PW: http://www.singaporeair.com/saa/en_UK/content/exp/fleet/fleet.jsp
Photo © Gordon Gebert JR
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
Users browsing this forum: swafa and 1 guest
