PMN1
De Havilland Comet
Sun Jun 14, 2009 4:23 pm
Did de Havilland ever look at the possibility of 6 Ghost engines for the Comet?
What would the extra power enable de Havilland to have done?
metroliner
RE: De Havilland Comet
Sun Jun 14, 2009 10:53 pm
Quoting PMN1 (Thread starter):
Consume 50% more fuel?  Smile
The earlier Comets were no hotrods, by all accounts, and the four Ghosts were about adequate for the early, short-fuselage Comets.
The beefed-up Comet 4 introduced Avon engines with a whole lot more thrust. I read an article in Flight Illustrated YEARS ago on the last flying Comet in the RAF - 'Canopus' - which had a fantastic pull-out poster with the bird sustaining a 45-degree climb. Lightly loaded, and even not, the Comet 4s were powerful airliners even by modern standards.
The bigger question is why DH chose to go against the Boeing ethos of podded engines - the Comet 5 was to have possed engines - but it was already too late by then. Traditional story of British aviation!  Sad
Set the controls for the heart of the Sun
VirginFlyer
Mon Jun 15, 2009 3:10 am
Quoting Metroliner (Reply 1):
In fact the Comet 2 was the first to use the Avon. If I recall correctly, the intention had always been that the Comet would eventually be powered by the Avon, but the Ghost allowed them to have an aircraft in operation sooner.
I believe arguments in favour of the buried engines included allowing them to be placed closer to the centreline, which allowed a smaller fin and rudder, and keeping them further away from the ground, which reduced the risk of FOD. Obviously in the scheme of things the disadvantages of the buried engines outweighed these advantages.
As for the traditional story of British aviation, I recall reading a comment by the great man himself that even if his Comet had not suffered from the fatigue cracks, and had had have been technically equivalent to the 707 or the DC-8, manufacturing of aircraft in the UK was a cottage industry compared to the USA, and it was always destined to be eclipsed by the Americans. I think rather than bemoaning the passing of the British airliner (and trust me I've done my fair share of moaning about it!), we should be thankful that, in spite of the hindrances, they achieved as much as they did...
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
longhauler
Mon Jun 15, 2009 4:07 am
The pictures (drawings) I have of the Comet 5 have the four RR Conways in the wing root like all the other Comets. The wing sweep does appear to be greater, and the tail is swept as well. The same lean elegant look of the earlier Comets, with a more modern twist.
metroliner
Mon Jun 15, 2009 11:31 am
Quoting LongHauler (Reply 3):
Any chance we could get a look at those?  Smile
Quoting VirginFlyer (Reply 2):
Not disagreeing with you at all there.  Smile
(Though I do reserve the right to be forever grumpy about the ending of the Avro RJ programme.)
PMN1
Mon Jun 15, 2009 12:29 pm
Interesting section from Tony Buttler’s 'British Secret Projects: Jet Bombers since 1949' reagarding engine installations.
The Short SA4 was a 1945 bomber design with either 4 or 6 buried engines.
'Agreement for ordering two S.A.4’s was reached in late February 1947 at which point it was planned to house the four AJ65’s side by side in two underwing nacelles. However, in mid-February 1949, after tunnel tests at RAE Farnborough. Keith-Lucas confirmed that two engines in a single vertical nacelle above and below each wing had been adopted instead of the previous arrangement or an alternative four single underwing nacelles. Rolls experience on a design with twin engines mounted side by s side had indicated that the aerodynamic forces on the cowl were very large and needed a heavy structure. Engines arranged horizontally in a nacelle suspended below the wing by a slim faired strut were also suggested (and favoured at RAE), but Shorts rejected this because it presented several structural problems and would be difficult to accommodate without extensive redesign of the wing. Prototype construction had just begun.'
Viscount724
Mon Jun 15, 2009 8:39 pm
As did the first two Russian commercial jets, the Tu-104 (based on the Tu-16 bomber), and smaller Tu-124.
Photo © Erik Frikke
Photo © Kjell Nilsson
Users browsing this forum: pugman211 and 1 guest
