propilot83
Swiss Air Flight 111
Thu Jun 18, 2009 1:41 am
When Swiss Air Flight 111 an MD-11 aircraft crashed near Nova Scotia in 1998, the Canadian version of the NTSB found that faulty electrical wiring near the cockpit section caused an arc, that caused smoke in the cabin and caused the plane to crash into the water. Now the Swiss Air MD-11 was equipped with Kapton wiring. Now many of you say "well if TWA-800 was a faulty electrical wire that was Poly X in the center fuel tank explosion, why didnt the FAA ground all Boeing 747's that time?" Well my question is, why didnt the FAA ground all MD-11's when Swiss Air Flight 111 crashed because of a similar electrical problem with wiring in regards to TWA-800? This concludes that not only Swiss Air Flight 111 crashed because of faulty electrical wiring, but also TWA-800.
EMBQA
RE: Swiss Air Flight 111
Thu Jun 18, 2009 1:45 am
Quoting Propilot83 (Thread starter):
If I remember correctly the wiring was not part of the airframe wiring, but added later as part of an entertainment system unique to Swisair
tdscanuck
Thu Jun 18, 2009 2:38 am
Well, for starters, it wasn't really the same kind of electrical problem. But the short answer is that, had Swiss Air Flight 111 been wired properly (i.e. as the flight crew thought it was) they could have extinguished the fire and survived.
Tom.
Thu Jun 18, 2009 6:00 am
Quoting EMBQA (Reply 1):
Anyone have the name of the company of the IFE?
regds
MEL.
Thu Jun 18, 2009 6:48 am
Quoting HAWK21M (Reply 3):
Who are you and what have you done with HAWK21M?  Wink
IFixPlanes
Thu Jun 18, 2009 6:49 am
Maybe you find it in the final report:
http://www.bfu.admin.ch/common/pdf/1762_en.pdf
never tell an engineer he is wrong ;-)
ZRH
Fri Jun 26, 2009 1:59 pm
To be a little picky: the name of this airline was Swissair and not Swiss Air. The name of the new airline is SWISS International Airlines.
VMCA
Fri Jun 26, 2009 2:54 pm
The short answer is the IFE was a non-approved addition. Had the approval process been followed, the deficiencies in the wiring and the inability to disconnect the IFE from the power supply would have certainly been noticed. The other MD-11s that had not had that particular IFE installed had no reason to be suspect.
If we weren't all crazy, we'd all go insane....
SEPilot
Fri Jun 26, 2009 6:06 pm
The problem was that they could not identify what could have caused the TWA 800 center fuel tank to explode (that is of course assuming that it did.) Not having a specific cause makes it hard to ground an entire fleet that had been flying for nearly 20 years without a similar case. And there are many (myself included) that strongly doubt the exploding tank theory, anyway.
EcuadorianMD11
Sun Jun 28, 2009 3:02 am
At the risk of going slightly off topic:
The amount of MD-11´s flying around the world is under 200 units only.
The majority are cargo planes, with the major operator being Fed-Ex.
KLM is one of the few reputable arlines that operate them for pax.
I have been told that the MD-11 is an underperfoming plane!
My question is: why are they mainly used for cargo?
Why is KLM different?
I love the design, hence my user name..........
Ecuadorian MD-11
A lot of people need to be offended on a regular basis I always felt, and I�´m the very boy to do it! - Billy Connolly
Sun Jun 28, 2009 4:35 am
"Underperforming" is rather subjective. It is true that at entry into service, the MD-11 failed to meet performance guarantees. A rigorous program of improvements fixed that. But the damage was done.
Cargo: I think it is mostly because the aircraft has been surpassed by other designs. It has gone where older designs tend to end up: cargo.
KLM: They probably feel it still fits well for them. No airline has a route network like any other, so what fits for one may not fit for another.
EcuadorianMD11
Tue Jun 30, 2009 11:09 pm
Quoting Starlionblue (Reply 10):
Hence the limited production?
Or was that all to do with Boeing running the show by then?
May I be obnoxious and ask you to develop that point please?
To give you an example: KLM uses them for AMS-BON-GYE-UIO-BON-AMS; it´s like a bit of a merry-go-round, would this be a specific route for the MD11? And then there´s the backwards and forth Montreal route as well.....and I don´t see any similarities.
But then they don´t seem to go to Africa for instance, that´s mainly a 777 area, or so it seems. I wonder why........is it all to do with number of seats?
I realize I should actually start a new thread on this perhaps, but then I wouldn´t want to waste everybody´s time with such personal (dumb) questions.
But who decides what plane goes where at major airlines? I realize 1 route is normally covered by 1 type of aircraft, but which? They are all in different conditions.
You have 2 MD-11´s available, and 2 flights due soon.....(for argument´s sake): Does the manager on duty decide which one is going where? I mean, that decision could have major consequences if something was to go wrong maintenance wise in some "rural" part of the world (aviation wise I mean).
Please bear with the off topic angle.............
Ecuadorian MD11.
Wed Jul 01, 2009 12:28 am
Quoting EcuadorianMD11 (Reply 11):
It means that no two airlines are the same.  Wink Disregarding that for a moment, one needs to look at the "big picture", not just route economics. The cost of the aircraft includes startup costs (purchase/lease, training, setting up maintenance etc...), operating costs and finally disposal costs (may be disposal revenues). It is quite possible KLM got a good deal on the MD-11. So there's one factor. Another factor to consider is the cost of replacement. Is it cheaper to keep the MD-11 than to replace it? I assume yes. And if KLM wishes to replace the aircraft, when will the replacement enter service? If that's in 5 years given delivery slots, the MD-11 will be around even if it is not, right now, theoretically the cheapest.
EcuadorianMD11
Wed Jul 01, 2009 2:37 am
Quoting Starlionblue (Reply 12):
It´s good to know that I wasn´t the one being obnoxious........
Well stated.......
I suppose this explains a lot, and I happen to know KLM invested in their interior recently so the MD-11´s will stay for quite a while yet.
I still wonder why KLM is one of the very few though...........one of the very VERY few airlines that has a considerable pax fleet of MD-11.
And may I ask, why are under-performing (or shall we say "less" performing) planes more suitable for cargo than pax. Aren´t cargo ops even more intensive and $$$-sensative than pax ops are?
Ecuadorian MD-11
SEPilot
Wed Jul 01, 2009 1:44 pm
Quoting EcuadorianMD11 (Reply 13):
pax fleet of MD-11.
I believe that cargo operations in general spend less time in the air than passenger ops, and hence fuel costs are less important, and capital costs more important. That is why most freight operators use older planes. The MD11, therefore, since it has been largely rejected by passenger operators can be purchased for much less than any other aircraft of similar age and capacity, so that is why so many of them are flying freight.
Thu Jul 02, 2009 9:16 am
The Age of the Aircraft does not contribute to Flight safety but rather the quality of Maintenance & Flying does.
regds
MEL.
EcuadorianMD11
Sat Jul 04, 2009 4:54 am
Quoting SEPilot (Reply 14):
Really? Do cargo planes generally spend more time on the ground than pax planes?
Interesting! I mean, it´s common sense that it takes longer to completely fill up a freighter from scratch than to take in a few hundred passengers + luggage + grub, but what I see here at my "local" international airport is that freighters only pick up the odd couple of "items" (big items) and they are airborne before you can drive home to get your camera!
I may be exaggerating a bit, but I think you´ll get my drift.
The freighters do no stay on the apron for long!
Obviously they´ll stay longer at their main hubs, but still...............interesting!
Well, I´m personally a big fan of the MD-11, I think the winglets really made it stand out from the DC-10 and I hope to enjoy them for quite some yet!
Do you agree?
Ecuadorian MD11.
AirframeAS
Sat Jul 04, 2009 6:04 am
Quoting Tdscanuck (Reply 2):
Not only that, it was also determined that the aircraft in question was using the wrong type of insulation blankets that was flammable. I found this out in a mx video in A&P school.
Sat Jul 04, 2009 9:44 am
Quoting EcuadorianMD11 (Reply 16):
Yes.Out here Freighters have a longer halt than Pax aircraft depending on the type anything between 45mins-1hr & upto 2hrs is possible.
regds
MEL.
Woosie
Tue Jul 07, 2009 5:20 am
One of the results of this accident is that metalized mylar was found to be flammable, so the liners were changed. Wiring was at issue...that's all I can say (I helped the TSB with their investigation and report). The changes we did for Swissair, called the Mods Plus program, was really neat. Too bad the changes were removed when the airplanes changed hands.
Quoting EcuadorianMD11 (Reply 9):
The airplane is a bit more expensive to operate than 777; not so sure when compared to A340. Twins had one less engine to contend with, which is a saving in maintenance costs.
The MD-11 is a stellar cargo airplane - one that's primarily volume limited as opposed to weight limited. This means you can really fill one up and go fly, which makes them better money makers than the competition. The 777F may be a better freighter airplane I don't know the specifics) but it certainly is newer, which is attractive to certain operators. Fedex has invested heavily into the trijet, both MD-11's and MD-10's (and a few DC-10-30's), so they'll use them for a long time to come. The airplanes are operated a bit less than pax versions, primarily because of Fedex's route structure (to/from the main hub in Memphis), as opposed to a typical pax route structure (hub to spoke to spoke to spoke then to a hub); the pax route structure allows for more time in the air.
EcuadorianMD11
Thu Jul 09, 2009 11:00 pm
Quoting Woosie (Reply 19):
Okay, so what I understand is that the MD11 has plenty of grunt on board to do the job.
Overkill perhaps for a mere 300 pax with their sunglasses, swimming trunks and their tax free bottle of Scotch on board?
Overkill = waste = expensive?
Do I smell what you´re cooking, Woosie?
Ecuadorian MD11
(Hugely over-powered as well).
keesje
Thu Jul 09, 2009 11:19 pm
IFT. An odd firm from Las Vegas if I remember well. Talked to them. Big screens and real AVOD. Very heavy, expensive. I enjoyed it once in Alitalia Magnifica, also a MD11. IFT went out of business soon after the disaster. I think the system was connected to a bus also used for primairy systems.
http://www.highbeam.com/doc/1G1-19055442.html
Fri Jul 10, 2009 8:24 am
Quoting Keesje (Reply 21):
Normally the case in such matters....as loss of business & compensation cases take its toll.
regds
MEL.
Users browsing this forum: Faro, mat66 and 13 guests
