RB211-535 Query.
Thu Jul 02, 2009 9:21 am
Presumingly there is a heavy tailwind prevailing at the time & the engine is windmilling but in the opposite direction.Will N1 or N2 register on the gauges?
regds
MEL.
tdscanuck
RE: RB211-535 Query.
Thu Jul 02, 2009 2:59 pm
Quoting HAWK21M (Thread starter):
If the EEC is off, probably not. Most FADEC engines don't report anything to the airplane unless the EEC is powered. If you've got the EEC on but aren't running a start, I'm not sure. Some RR engines have a threshold below which they won't show the spool rotation to prevent nuisances...this might cover up wind-driven windmilling, regardless of direction.
Tom.
PITingres
Thu Jul 02, 2009 11:20 pm
and if you were as puzzled as I was, "EEC" == "Electronic Engine Control" ...
Fly, you fools! Fly!
Tristarsteve
Fri Jul 03, 2009 8:01 am
Quoting Tdscanuck (Reply 1):
But the RB211-535 is not a FADEC engine!
This engine has steel cable throttle controls, a separate bleed valve controller, and an EEC. The EEC is in the aircraft fwd equip bay, and acts mainly as a overlimit controller, reducing the fuel flow to avoid exceedances.
Fri Jul 03, 2009 9:25 am
Quoting TristarSteve (Reply 3):
True.preventing overboost of EGT & N1 via the engine supervisory & Engine limiter controls respectively.
Just had this thought on the RPM indications query the other day when it was windy at pushback,awaiting another day so I can ask the crew what they observed.
regds
MEL.
Sat Jul 04, 2009 9:40 am
Practically checked the Indications tonight with tailwinds & aircraft parked with only APU power.No RPM was registered on EICAS.
regdss
MEL.
Users browsing this forum: BravoOne, dfwjim1, ZyreaxPlayz and 1 guest
