OHLHD
What Is This On The Wing? ( OS A319)
Wed Jul 22, 2009 1:43 pm
Hi guys,
On a boring flight from HEL to VIE I noticed this 2 little parts of the wing and until the landing I could not figure out what it is good for. Honestly I never noticed it before.
Can anyone tell me what it is and what for.
Many thanks!
See below:
Additional question: Is the marking of the flap position usual?
rampkontroler
RE: What Is This On The Wing? ( OS A319)
Wed Jul 22, 2009 1:51 pm
The yellow loops are for anchoring the life rafts after a ditching. After the raft was full of passengers, you would cut yourself away with the knife that comes with the raft.
I'm sure they were utilized in the Hudson ditching. (Would that be a first?)
flymia
Quoting OHLHD (Thread starter):
Well I have no idea what those things are for, maybe for mechanic checks? A D check where they take everything apart maybe that's how they hold the wings? As for the flap markings I have seen them before. I am guessing they are for MX and pilots to know where the flaps are in case there is a malfunction with the indicator.
(just a guess)
EMBQA
Wed Jul 22, 2009 2:40 pm
No... it very-very common
wirelock
Wed Jul 22, 2009 3:46 pm
I think that the these yellow anchor point is used for an escape rope. there is an escape rope located a small overhead bin above the overwing exits. When the overwing exit is removed there is an anchor point on the structure, the other end been on the wing.
ex52tech
Wed Jul 22, 2009 3:48 pm
Quoting FlyMIA (Reply 2):
Life rafts mainly, but I have seen them used as anchor points for mechanics safety harness, when you are working close to the trailing or leading edge with some or all of the flight controls removed. For the most part they are there for the mechanics to trip over when working on the wing.  Big grin
The airplane is usually on jacks during heavy checks, and if there is major structural work being done usually the fuselage is jigged, and jacks in place so nothing moves.
"Saddest thing I ever witnessed....an airplane being scrapped"
113312
Wed Jul 22, 2009 3:57 pm
The number marks are to verify wing flap position visually should there be some problem with the electronic position indicator. Most planes have something like this as well as the anchor rings for the ditching ropes.
EcuadorianMD11
Thu Jul 23, 2009 2:20 am
This has been discussed recently as I had the same question you had OHLHD.........
A320 Wing Design And Detailed Questions. (by EcuadorianMD11 Jun 8 2009 in Tech Ops)
Ecuadorian MD11
A lot of people need to be offended on a regular basis I always felt, and I�´m the very boy to do it! - Billy Connolly
OHLHD
Thu Jul 23, 2009 7:05 am
Thanks for all the info!  Smile
Quoting EcuadorianMD11 (Reply 7):
Thank you. I read it but I can´t see most of the pics so I was not sure if it was about the same.
 thumbsup   thumbsup   Smile
Thu Jul 23, 2009 8:56 am
The Lift raft anchor point is common.But is the TE Flap marking in units common too on all aircraft of the same type.
regds
MEL
AirframeAS
Thu Jul 23, 2009 9:22 am
Quoting Wirelock (Reply 4):
Wirelock is correct.
bwaflyer
Thu Jul 23, 2009 8:24 pm
I fly on the 319/320 and none in our fleet have escape ropes at the over wings. The hooks are actually used if the overwing exit slide deflates during an evacuation. There is a clasp on the slide which is hooked into the attaching point on the wing. This holds the horizontal part of the slide that sits on on the wing taught, and four passengers on the ground hold out the sloping part of the slide allowing the slide to still be used to evacuate passengers.
AirframeAS
Fri Jul 24, 2009 9:10 am
Quoting Bwaflyer (Reply 11):
Really? Then why does F9 have an escape rope on the A319's?!  scratchchin
Fri Jul 24, 2009 1:23 pm
Hand hold helps even during Mx work  Smile But its a tough time restoring them.
regds
MEL
Users browsing this forum: Google [Bot] and 15 guests
