JAGflyer
Cabin Service Elevators
Tue Jul 28, 2009 12:52 am
I would like to learn more about the elevators that were used by F/As to move meals and carts between the upper and lower levels of some aircraft. Which aircraft, other than the L1011 had these elevators and do you have any pictures of them?
If you flew today, thank a Flight Dispatcher!
474218
RE: Cabin Service Elevators
Tue Jul 28, 2009 1:07 am
Quoting JAGflyer (Thread starter):
On the L-1011 they are called "galley lifts".
The elevators are found on the trailing edge of the horizontal stabilizers
Here are a couple of pictures of the L-1011 lifts:
Photo © Jeff Bigelow
Cabin
Photo © AirNikon Collection-Pima Air and Space Museum
Galley
JAGflyer
Tue Jul 28, 2009 1:11 am
I am familiar with the elevator control surface. I was refering to the "galley lift" as you said.
EMBQA
Tue Jul 28, 2009 1:50 am
DC-10 would be the only other I can think of........
nws2002
Tue Jul 28, 2009 2:37 am
I vaguely remember reading that the A330/A340 had a lower galley option, but I've never seen one.
m11stephen
Tue Jul 28, 2009 3:35 am
Quoting Nws2002 (Reply 4):
LH has lower galleys on their A340-600s.
Didn't some early 747s have lower galleys as well?
My opinions, statements, etc. are my own and do not have any association with those of any employer.
DL_Mech
Tue Jul 28, 2009 11:11 am
Quoting M11Stephen (Reply 5):
Yes, AA, UA and QF.
This plane is built to withstand anything... except a bad pilot.
Tod
Thu Jul 30, 2009 7:04 pm
All 744 have a cart lift from the G2 galley area to the aft u/d galley.
XaraB
Fri Jul 31, 2009 8:37 am
Quoting 474218 (Reply 1):
The use of "elevator" for lifts is accepted in US English:
http://www.english-dictionary.us/meaning/elevator.asp¨
I immediately understood the subject title, even if the OP didn't use the most common name for these devices.
An open mind is not an empty one
speedmarque
Sat Aug 01, 2009 2:11 pm
At VS
747-100 G-VMIA had two from the main deck to lower galleys.
747-200 G-VPUF, VIBE, VSSS, VZZZ, VBEE, VRUM and VCAT from lower to upper deck
All 744
Oh and A380s have them too.
B747FE
Sat Aug 01, 2009 4:12 pm
We used to have them as well in two of our 747SR.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
Viscount724
Sat Aug 01, 2009 8:17 pm
Quoting XaraB (Reply 8):
Not only "accepted", but virtually the only word used in the U.S. (and Canada). If you ask where the "lift" is, it's unlikely anyone will know what you're talking about.
DL_Mech
Sat Aug 01, 2009 10:27 pm
Quoting Speedmarque (Reply 9):
At VS
G-VMIA was a -123 built for AA.
Tod
Mon Aug 03, 2009 2:56 pm
Quoting Viscount724 (Reply 11):
Correct, except for this business.
Boeing nomenclature for the device on 744 is "cart lift"
Tod
474218
Mon Aug 03, 2009 6:21 pm
Quoting Tod (Reply 13):
It doesn't matter what is correct, there are people that call the "vertical stabilizer" the 'fin'.
speedmarque
Mon Aug 03, 2009 7:09 pm
Quoting DL_Mech (Reply 12):
er............thank you?
DL_Mech
Mon Aug 03, 2009 11:45 pm
Quoting Speedmarque (Reply 15):
Just clarifying the 747's built with lower galleys. Some people around here actually think that a 741 was built for VS.
longhauler
Tue Aug 04, 2009 1:37 pm
I remember flying on an AA B747 from ORD-PHX in the early 1970s. That aircraft was equipped with a lower deck galley with galley lifts. I recall thinking to myself that it was a triple deck aircraft!
At AC, we were not allowed to refer to the galley lifts on the L1011 as "elevators", as it caused too much confusion when writing snags for maintenance.
One L1011 was removed for extensive flight control maintenance when a Second Officer wrote in the maintenance log that "The left elevator intermittently sticks in the full UP position". he was, of course referring to the left galley lift.
DocLightning
Tue Aug 04, 2009 11:18 pm
Quoting Tod (Reply 7):
So I think the L-1011 was the only one to have a lift that could hold a person (barring special equipment, like Presidential aircraft). However, the 747 has a dumbwaiter lift that could, conceivably, accommodate someone inside it, although not comfortably. Not sure about the DC-10. What about on the A340? Some of them have lower-level galleys. How do they move the food up and down? Surely not by a ladder...
-Doc Lightning-
-Carl Sagan
longhauler
Wed Aug 05, 2009 12:32 am
Quoting DocLightning (Reply 18):
The DC-10-10s CP operated on a lease from UA had lower deck galleys as well, with a galley lift system similar to the L1011.
DL_Mech
Fri Aug 07, 2009 1:15 am
The 747 Classic and DC-10 had similar setups, One Man-Sized Lift and One Cart Lift beside each other for each lower galley (AA and UA had forward and aft galleys).
blueflyer
Fri Aug 07, 2009 3:11 am
So how does LH get someone to the lower galley of the A346 if the lift isn't an option ?
MAGag
Viscount724
Fri Aug 07, 2009 6:31 pm
Quoting LongHauler (Reply 19):
All UA (and AA) DC-10-10s had lower-deck galleys. I don't think very many DC-10-10s were built with main deck galleys.
edina
Sat Aug 08, 2009 1:17 pm
Quoting BlueFlyer (Reply 21):
Here's how.....
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
edina
Sat Aug 08, 2009 1:21 pm
For some reason the image didn't appear above, but this is what I meant to show....
http://www.airliners.net/photo/Lufthansa/Airbus-A340-642/0686097/L/
