Blade Tieing Practice.
Tue Jul 28, 2009 5:03 pm
Is Fan Blade Tieing to a surface/chock via rope an acceptable method to prevent rotation in windy conditions,apart from use of Engine blanks.
Is it done for any engine type worldwide?
regds
MEL.
fr8mech
RE: Blade Tieing Practice.
Tue Jul 28, 2009 7:59 pm
Everywhere I've worked the practice has been discouraged if not completely deemed 'against the rules'.
wn700driver
Tue Jul 28, 2009 11:19 pm
I have only ever seen this done on the Dash, and that was a prop. We used to tie those blades down to a notch on the engine nacelle to keep it from turning in the wind while PAX boarded/disembarked.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
jetmech
Wed Jul 29, 2009 9:53 am
Quoting HAWK21M (Thread starter):
We always tied the fans of the RB211's (D4's) and JT9's, as the clanking was too annoying during windy conditions. Apparently, the impact between adjacent snubbers was not too good for the fan blade either.
Quoting Fr8Mech (Reply 1):
Fair enough. It was actually quite a common occurence at my first employer, whereby fan ties were accidentally left in when engines were spun up.
Regards, JetMech
Wed Jul 29, 2009 5:14 pm
Quoting JetMech (Reply 3):
What was used to assist the tying,Was this an approved company SOP & if so was there any ref doc reffered to.
regds
MEL.
jetmech
Thu Jul 30, 2009 6:22 am
Quoting HAWK21M (Reply 4):
For the RR's, there was a special fan tie. One end had a pin that fitted into one of the nose cowl lifting points. The other end had a plastic coated hook that went around the snubber. These two items were connected by a cord and bungee.
The bungee was tied into the cord such that it would stretch before the cord became fully taught, which cushioned any forces applied to the fan blade. For other engines, we used a length of light rope to tie the blades.
regds
I'd say so. For "A" checks, we had a folder detailing what inspections to carry out, and the appropriate MM references. Inserting fan ties would probably came under a general "A" check company procedure heading in this folder.
Regards, JetMech
Thu Jul 30, 2009 9:05 am
Quoting JetMech (Reply 5):
Any Pic......What type RR are you referring to?
regds
MEL.
AA737-823
Tue Aug 04, 2009 1:51 am
Why not just tie it to the stator blades behind?
jetmech
Tue Aug 04, 2009 4:06 am
Quoting HAWK21M (Reply 6):
Sorry, couldn't find any pictures. These fan ties were specifically for the D4. We did not use them for the G2.
Quoting AA737-823 (Reply 7):
That's what we did for the GE and P&W. I suppose that a purpose made tie is quicker and easier to remove and install, and less likely to be left in.
Regards, JetMech
[Edited 2009-08-03 21:07:21]
Tue Aug 04, 2009 10:22 am
Quoting JetMech (Reply 8):
Any tying used on the RB211-535s?
regds
MEL......
jetmech
Thu Aug 06, 2009 4:45 am
Quoting HAWK21M (Reply 9):
Not too sure about this one Mel, as unfortunately, I never got to work on a 757. Do the 535's have mid span shrouds? It was the presence or absence of mid span shrouds that generally established whether we tied the fans or not.
On the RR's and P&W's, we generally did tie the blades when we were working on the engines, as the noise of the clappers hitting was very annoying. The GE also had mid span shrouds, but for some reason, the blade set fitted together much more tightly on the CF-6 than either the RR or P&W, so we rarely if ever tied the blades.
Regards, JetMech
Thu Aug 06, 2009 8:00 am
Quoting JetMech (Reply 10):
On the -535C not on the -535E4.
regds
MEL.
boeing767mech
Thu Aug 06, 2009 6:38 pm
you can do like the Air Force and put a 2x2 in the fan blades like they do on the C-5's
David
Never under-estimate the predictably of stupidty
fr8mech
Thu Aug 06, 2009 8:02 pm
I seem to recall having a procedure in the B747 100/200 AMM to tie the fan blades and run the engine, with the cowls off, for leak check. Throttle manipulation was prohibited and there was a note to watch EGT carefully at start to avoid a hot start. Anyone starting a JT9 knows to watch for a hot start anyway.
Never performed the procedure. We just took the cowls off, and watched carefully for 'evidence' of leakage. If we really suspected a leak that we were having trouble finding due to the bypass air, we would pull the cowl, pop it in reverse and run the engine.
citationjet
Thu Aug 06, 2009 11:17 pm
What about using a passenger seat belt on the blades of a 747?
http://www.boreme.com/boreme/funny-2007/china-air-p1.php
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Fri Aug 07, 2009 9:05 am
Quoting CitationJet (Reply 14):
Thought of just that pic when this topic was started.
regds
MEL.
Users browsing this forum: ac190, Google [Bot], PHLapproach and 2 guests
