Tesko
Quick Question About The Taxi Stage Of Flight.
Fri Jul 31, 2009 9:11 am
Alright, when a pilot of a heavy is on a taxi does he manage all the throttles as separate throttles of which way he is turning or does he manage all the engines as one?
RE: Quick Question About The Taxi Stage Of Flight.
Fri Jul 31, 2009 9:56 am
As I understand it it is all as one with the possible exception of some very tight turns where you might want more power on the outside of the turn.
thebatman
Sun Aug 02, 2009 1:55 am
Quoting Starlionblue (Reply 1):
I'll have to kindly disagree. I'm not a pilot, but I do taxi every fleet type that my airline has (737,747,757,767,777,A319,A320). If you're on the taxi stage of flight, especially in a heavy airplane, the tendency to "die" in a turn is much higher than when you're arriving at your destination and have little fuel left. It is common practice to pull a little power on the corresponding engine to help you make a smooth turn. You could move all of the throttles at the same time, but this may cause you to speed up too rapidly, and then you'd have to hit the brakes. Again, it's much smoother to pull power only on the side you need.
Aircraft mechanics - because pilots need heroes too!
411A
Sun Aug 02, 2009 2:16 am
I depends on what the Captain decides...personally, when heavy (which is nearly always for us, for departure) I will use the outboard engine in turns.
Type, L1011.
CosmicCruiser
Sun Aug 02, 2009 2:19 am
Quoting Thebatman (Reply 2):
OOOOOOOKAY
In the MD-11 as well as the DC-10 I rarely use assymetrical thrust in a turn. The "feel" you get is to KNOW that the momentum you have will take you thru the turn. When I first checked out in the -10 years ago I remember bogging down in an uphill turn because I didn't have the feel of the inertia yet. Now almost never is it a factor, I see the turn, look at the GS and know what thrust I'll need to make the turn. If I use one side more than the other it's rare.
thebatman
Tue Aug 04, 2009 3:23 pm
Quoting CosmicCruiser (Reply 4):
OOOOOOOKAY
Questions??
Francoflier
Tue Aug 04, 2009 6:21 pm
The general practice is to accelerate all engines simultaneously for taxi. The use of asymetical thrust would only be used in case of an extremely tight turn at low speed. The steering system on modern airliners is more than able to turn the nosewheel to full lock at a standstill.
Whenever taxying around an airport with a heavy jet you need to try and apply as little thrust as possible to avoid FOD behind you, and in that way it is better to use more engines at less thrust than one at a higher thrust.
CosmicCruiser
Tue Aug 04, 2009 7:33 pm
Quoting Thebatman (Reply 5):
Questions??
My first thought was just MSFS but I see by your profile you're a line mech. Cool. Do they teach assymetrical thrust in the turns?
thebatman
Wed Aug 05, 2009 12:53 am
Quoting CosmicCruiser (Reply 7):
Yes, they do...if it's necessary. If you're taxiing an A320 with 8000 lbs of fuel on board, you're not going to touch the throttles (hardly) during the entire taxi ride. Now, if you're taxiing a 747-400 with 375,000 lbs of fuel, that's a different story.
Absolutely. That's hard to describe to someone who has never done it. You have to walk the fine line between carrying enough power to go through the turn, and not applying too much and blowing something or someone behind you away. Since UA is really pushing single-engine taxi, that makes turning even more challenging. But, with time comes experience, and with experience, "feel".
CosmicCruiser
Wed Aug 05, 2009 1:00 am
Like I said I rarely do it though I've had to do a 180 on the runway and used every available tool including assymetrical thrust. On the -11 if you're heavy you may find yourself at max thrust( 40%N1) for a ramp or congested area. We have had some cans blown into other things like planes and carts, etc. Y'all be careful now.
Thu Aug 06, 2009 8:14 am
Is the Taxi permit issued per Aircraft type or over entire fleet.Here its the former.
regds
MEL.
movingtin
Thu Aug 06, 2009 5:42 pm
Quoting HAWK21M (Reply 10):
regds
Per A/C Type, with recurrent check rides required where i have worked.
thebatman
Thu Aug 06, 2009 7:50 pm
You need to take two weeks of training for each A/C type (one week- systems training, and one week - engine run/taxi). Then you will need to go on a series of check rides for each A/C. Also, here at ORD you need to take a 150-question taxi exam for the city that tests you on all the runways, taxiways etc. You'd better know where you're going out there! That test gives you a special ID badge that allows you to taxi A/C.
Valkyrie01
Fri Aug 07, 2009 2:14 am
Quoting Thebatman (Reply 12):
Do you get pay extra to taxi airplanes i know alot of the guy i work with who are taxi qualify gave it up because they were not getting any additional money for it. ie more responsibility etc and no compensation.
The best there is the best there was the best there ever will be
Fri Aug 07, 2009 9:01 am
Quoting Valkyrie01 (Reply 13):
There is no Taxi check permit holder allowance out here...Its considered a part of the job.
regds
MEL.
thebatman
Fri Aug 07, 2009 3:53 pm
Some carriers (only regionals that I'm aware of) will give you something like 25 cents more an hour for being taxi-qualified. This is NOT the case at the airline I work for.
Users browsing this forum: Noris and 2 guests
GZIP: Off
