Plainplane
Kit planes- What is involved in making them?
Fri Sep 11, 2009 10:46 am
What does it take to self-build an aircraft from a kit? I'm really interested in knowing how this aircraft was put together.
Photo © Andre Klass
pilotpip
Fri Sep 11, 2009 11:27 am
A bit of time, and a whole lot of patience. Here's the company that makes this kit:
http://www.vansaircraft.com/
Vans is one of the best known and largest kit aircraft companies out there. They have a ton of finished aircraft flying and a really good support network established. I'm considering building an RV-8 myself.
DMI
KELPkid
Fri Sep 11, 2009 2:56 pm
Quoting Plainplane (Thread starter):
A good way to find out is to attend a meeting or two of the local EAA chapter and get to know some of the guys (and gals  Wink )... check out http://www.eaa.org/
Quoting Pilotpip (Reply 1):
They are literally in my back yard here in Oregon, at UAO  Smile Last I checked, they are, in fact, the largest kit manufacturer and have the highest kit completion rate of any aircraft kit manufacturer.
pilotpip
Fri Sep 11, 2009 3:21 pm
One of the biggest reasons Van's is so popular is because there isn't much "fabrication" to do. The pieces are all cut, formed and drilled for the most part so you just assemble it. KELP, you do realize that Van's is based in OR right?
These guys are based in Mexico, Mo (about two hours west of St. Louis) and I went there for a test ride. I really think their STOL aircraft is neat. http://www.zenair.com
Their kit is about as straight forward as the Van's kits. Of course "kit" could be simply buying blueprints from a supplier, or designing your own. I've also seen some impressive rebuilds of vintage aircraft. The craftsmanship and painstaking detail are incredibly astounding. What's even more amazing is that many of these are built by complete novices in their garage.
http://www.wicksaircraft.com and http://www.aircraftspruce.com are two of the better known materials suppliers. Both have tool kits specifically tailored for the more popular experimental aircraft out there.
If you can't tell, I've been doing a bit of research on this...
DMI
KELPkid
RE: Kit Planes- What Is Involved In Making Them?
Fri Sep 11, 2009 5:34 pm
Quoting Pilotpip (Reply 3):
As am I, at the moment...I seem to have grown roots here, as I just started a family here  Smile
Users browsing this forum: bennator, trav110 and 1 guest
