propilot83
Cabin Width On 787
Tue Sep 15, 2009 9:46 pm
Does anyone know what the cabin width in terms of feet are on the Boeing 787 Dreamliner? I checked on the Boeing website, and it said that the "cross section" is 226 inches, I am not sure if this refers to the cabin width?
pianos101
RE: Cabin Width On 787
Wed Sep 16, 2009 3:09 am
That's the width of the fuselage (i.e., outside one window to the outside of the window on the other side). You can take off about 6 inches (diametrically) to get the cabin width, +/- maybe an inch.
astuteman
Wed Sep 16, 2009 12:38 pm
Quoting Propilot83 (Thread starter):
It will vary according to height above the floor, but it's typically quoted as being about 5" wider than the A330's cabin which is 208" across at the widest point (the fuselage is 222" diameter), so around 213" isn't going to be far away.
Stitch
Wed Sep 16, 2009 2:54 pm
Boeing's preliminary ACAP only shows the outer dimensions, however, using the seat and aisle dimensions, at it's widest point (the armrests), you are looking at a distance of 5.47m / 215 inches.
propilot83
Wed Sep 16, 2009 6:44 pm
Thanks for the info guys!  Wink
Users browsing this forum: Flow2706 and 1 guest
