LH526
Crew
B707 JT3C JT4A Noise Compressors
Thu Oct 15, 2009 6:06 pm
Guys, another in depth B707/B720 question:
I'm in bit of a trouble here: Below is a Boeing doc about the cowl dimensions of the Boeing 707/720 JT3C & JT4A
Big version: Width: 599 Height: 800 File size: 77kb
Apperently both cowls are different in size and length (the dimension differences are nearly unnoticeable on photos) However my question is more exhaust oriented as I would need some information on the exhaus pipes / noise compressor pipes:
The photo below shows the JT3C engine on a B720. The noise compressors clearly consists of 8 pipes in 2 rings each.
Photo © Frank C. Duarte Jr.
Whereas this one below possibly is a JT4A engine with 10 noise compression pipes in the outer ring.
However, on "the other site" I came across pics of a JT3C equipped B720 with 10 noise compressor tubes.
My research revealed that earlier noise compressor design has 10, later has only 8 noise compressor tubes.
Is anybody out there able to heklp my with these questions? is there a doc or further info on the noise compression pipes??
Any help is highly appreciated!
Thanks a million!
Mario
LH526
The707project@googlemail.com
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
timz
RE: B707 JT3C JT4A Noise Compressors
Thu Oct 15, 2009 9:21 pm
Quoting LH526 (Thread starter):
I forget... which engines had the daisy exhausts-- like a flower, instead of a cluster of pipes? That's what the 720 looks like to me.
Looking at the wing trailing edge, I'm guessing that's a 707-120.
Aaron747
Thu Oct 15, 2009 10:47 pm
For added fun, there's also the 7-nozzle starburst pattern on the Rolls Royce Conway-powered -420s:
http://www.rrec.de/uploads/pics/1957_Gil_707_Rolls-Royce_Conway_01.JPG
LH526
Crew
Fri Oct 16, 2009 12:44 am
Quoting Aaron747 (Reply 2):
Thanks, I got the B704 (RR Conways) and the JT3D engines all covered, Im still getting confused on the JT3C and JT4A exhausts
Quoting Timz (Reply 1):
You're right, the B707 and B720 share the JT3C engine
The 'single-flower' was the RR Conway, than you have the early JT3C with three radial layers of pipes and the JT4 engine with a flower-style inner exhaust encompassed by pipes.
The point is that there are 8-pipe and 10-pipe exhausts and (from photos) i can't figure out wich engine had what noise compressor configuration.
Aaron747
Fri Oct 16, 2009 1:22 pm
Quoting Lh526 (Reply 3):
I recall seeing pictures in the 1962 World Book encyclopedia (my grandparents kept them for ages) of a typical airline flight featuring Pan Am. The aircraft pictured was one of the early build 707-123s with JT3Cs. In one of the pictures, the Captain was doing an underwing walkaround and there were clearly 10 nozzles. However, in another picture, probably taken later (who knows?) there were only 8. I am now thoroughly confused.
This website may be FS-related, but a lot of the posters are old 707 hands with mountains of knowledge - I highly suggest inquiring there:
http://tonymadgehjg.proboards.com/index.cgi?
[Edited 2009-10-16 06:24:37]
timz
RE: B707 Silencers
Fri Oct 16, 2009 5:37 pm
Quoting Aaron747 (Reply 4):
I.e. 21 total?
LH526
Crew
Sat Oct 17, 2009 2:42 am
Thanks Aaron747. Your're right, that's exactly my confusion as well. My guess is that the earlier design consisted of 10, wich was later improved to only 8 on the JT3C engines
Quoting Timz (Reply 5):
I.e. 21 total?
Correct! For the 10 tube version it's two 10 tube rings and the center tube adding up to 21, for the 8 tube noise canceller it's 8+"compressor flower"
[Edited 2009-10-16 20:29:36 by LH526]
474218
Sat Oct 17, 2009 3:23 am
I am a little confused about this entire thread: I think what you are calling "Noise Compressors" are really "Noise Suppressors". They were the first attempt to quite jet engines on civilian airliner.
LH526
Crew
Sat Oct 17, 2009 3:32 am
Quoting 474218 (Reply 7):
Correct, some documents call them noise compressor, guess that's where I got the wrong term from.
Off course I'm inquiring about the noise suppressors ... hard to find any information about them whatsoever .... hence I'm moreso highly appreciating your input!
[Edited 2009-10-16 20:39:13 by LH526]
timz
Sat Oct 17, 2009 6:38 pm
My notes from Airlift/American Aviation (the magazine) say the JT3C on the 707-120 used 21 tubes, but the 720 and 707-320 both used 9 total. That must mean one centered with eight around it? Seems like we ought to be able to find a pic.
Viscount724
Sun Oct 18, 2009 12:31 am
Quoting Timz (Reply 9):
These photos not very clear but it does look like the -120 (left) has more tubes than the the -320 (right).
Photo © Robert Sieloff
Photo © Chartrain Didier
Also found following clearer 1985 photo of an ex-Pan Am -320 being used as a testbed by GE (CFM56 in #2 position).
http://www.air-and-space.com/19850509%20Mojave/85161%20707-321%20N37681%20Batch%20Air%20left%20engines%20rear%20l.jpg
And a very clear photo of an original Qantas -138 (the shorter-fuselage version of the -120 built only for QF), also showing a spare engine in a 5th pod. 21 tubes counting the one in the middle.
http://www.adastron.com/707/gallery/vh-ebg-2.jpg
[Edited 2009-10-17 17:44:46]
[Edited 2009-10-17 17:58:09]
[Edited 2009-10-17 18:00:15]
ex52tech
Sun Nov 01, 2009 2:31 am
On another note.
Those suppressors could not have held up well. We had some cracking trouble with the tail pipes on the J-57-P-43WB on the B-52G, which had some wedges added to help suppress the noise.
These things must have had cracks everywhere, especially with water injection being used. I know that there was some thrust loss associated with them. Which made a bad situation worse I'm sure.
"Saddest thing I ever witnessed....an airplane being scrapped"
Users browsing this forum: Vinka and 2 guests
