flybaurlax
Tornado Wing Sweep With Stores
Thu Oct 15, 2009 10:04 pm
I searched both military and technical forums, but couldn't find anything on this. I'm hoping this is the right place for this post.
I was wondering how the Tornado can swing it's wings back with stores on it, yet keep the stores aligned with the free stream airflow. I know the F-14 does not have any stores pods or mounts on the actual wing, and so the wing can move freely without any problems. How does the Tornado do it while having things attached to the wing? Is there a mechanism that pivots the mounts to keep the angle always parallel with the free stream airflow? I'd really like to know, as the Tornado is my favorite foreign fighter. Thanks
Boilerup! Go Purdue!
RE: Tornado Wing Sweep With Stores
Thu Oct 15, 2009 11:27 pm
The Tornado is unusual in this way. If I recall correctly the stores also swing as you have guessed.
wingscrubber
Fri Oct 16, 2009 12:01 am
I'm curious about this too - searched but couldn't find anything on the pylon/hardpoint rotation, but I imagine they rotate either with their own mini-jackscrews like the main one which sweeps the wing, or with another kind of mechanical linkage and pivot. As an engineer I'd love to see drawings of how that design works...
Anyhow, one thing I did manage to turn up was a website with a little gallery of the actual wing-sweep jackscrew. Wikipedia has a nice pic of the pivot too.
http://www.tornado-data.com/Tid/galleries/wing_sweep.htm
http://en.wikipedia.org/wiki/File:To...o_variable_sweep_wing_Manching.JPG
Resident TechOps Troll
474218
Fri Oct 16, 2009 12:18 am
Quoting FlybaurLAX (Thread starter):
Quoting Starlionblue (Reply 1):
Just like the external stores (and fuel tanks) did on the FB-111.
flybaurlax
Fri Oct 16, 2009 12:51 am
Cool! Thanks for the replies. I had a feeling it was something like that, just wanted to hear it from the experts.
Quoting Wingscrubber (Reply 2):
I completely agree.
rwessel
Fri Oct 16, 2009 3:49 am
It could be as simple as a single push rod attached to the front of the hardpoint pivot and to a point on the fixed part of the aircraft the same distance forward from the wing pivot’s center as the hardpoint connection. Very crudely:
Big version: Width: 442 Height: 421 File size: 5kb
flybaurlax
Fri Oct 16, 2009 4:04 am
Quoting Rwessel (Reply 5):
That makes complete sense, I was wondering if it was something that simple. I think this picture here shows possibly how it can pivot, sort of like a horizontal stab trim mechanism. If you look on the right wing of the aircraft (the left one in the pic as it's inverted) you can see a little arc towards the front of he pylon, which I believe would be a slit to allow the pylon to pivot.
http://archive.cs.uu.nl/pub/AIRCRAFT-IMAGES/Tornado.jpg
GST
Fri Oct 16, 2009 9:02 am
This brings me back, havent thought about it since being a kid making a squadron of Airfix tornados, and wondering why the weapons looked silly when you pulled the wings back (the kits had the wings movable).
wingscrubber
Sat Oct 17, 2009 6:22 am
That's got to be it, now I feel kind of stupid...  banghead  So it just swings like a parallelogram, simple!  idea  It'd work with two linkages as easily as one, that'd add redundancy - and thinking about it, the mechanism wouldn't have to be anything robust as a mini-jackscrew as I suggested because so long as the aircraft isn't side-slipping hard at Mach 2 those stores probably don't see much of a side load!
I've just been brain washed by working on the Citation X... nothing's simple on that bird, seems my basic geometry's gone out the window.  headache
Aesma
Tue Dec 15, 2009 10:07 am
I was wondering that too, and the push-rod thing is a good possibility. There are Tornados with two wing mounts so a screw rotating them with a motor or a pump could also work. Thinking of it, there are far more complex engineering problems when designing a sweeping wing, like how the cables, hydraulics, controls, work with the sweeping, how the change in sweep changes the center of gravity and the center of lift, etc.
Users browsing this forum: Horstroad and 15 guests
