WROORD
Traffic Tower Lingo
Fri Oct 16, 2009 10:34 pm
When the traffic control tells the pilot to cross the river, does it mean cross runnway R?
I listened to ch 9 on UA to ORD and they used to tell pilots somethng about college and crossing the river.....
Fly2HMO
RE: Traffic Tower Lingo
Fri Oct 16, 2009 10:47 pm
Quoting WROORD (Thread starter):
No such thing as runway "R", all runways are numbered, and are either left center or right.
You were probably hearing them doing position reports regarding common ground reference points. Every airport out there has them in one form or another.
IE when taking off to the west in LAX in VFR conditions a lot of times tower will say something like "no turns before the beach", meaning to not start their turn until they are over the water.
When I would fly around Vegas VFR approach would tell me to proceed "direct to the stratosphere", which sets you up nicely for an arrival into VGT.
Mir
Fri Oct 16, 2009 11:05 pm
Quoting FLY2HMO (Reply 1):
And you'd know the non-local pilots because they would come back with "umm, my service ceiling is only about 14,000....."  Wink
-Mir
IAHFLYR
Sat Oct 17, 2009 11:19 am
Quoting Mir (Reply 2):
Only if they were witty enough as yourself Mir to come up with that comment!  Big grin
Hey WROORD, could you provide a little more detail such as where you were when you heard these transmissions, etc, like on departure for ORD or on approach to ORD?
WROORD
Sat Oct 17, 2009 8:29 pm
Quoting IAHFLYR (Reply 3):
It was on approach to ORD from LGA right after Cleveland said to contact Chicago Center. Chicago was telling pilots to go to 210 speed lower to 4K feet and somethin about crossing the river (unless it is a local jargon for Lake Michigan)?
IAHFLYR
Sat Oct 17, 2009 8:33 pm
Quoting WROORD (Reply 4):
Some on here much more aware of the ORD area may know of an intersection or approach fix with a name that sounds like or is RIVER, that may be what you heard as the controller was issuing a clearance to cross RIVER or whatever the fix is, at an assigned altitude or speed.
ThePinnacleKid
Sat Oct 17, 2009 8:57 pm
Well... not knowing who your aircraft was actually talking to... it's hard to say.
But, to assume (dangerous as that is)... They we're on with Chicago Approach since they were handed off from Cleveland Center. There are two things that I see it could have been:
27L ILS has a fix called "RIPPR" (ripper) with a note on the approach plate "When assigned by ATC, intercept glidepath at 4000' or 5000' or 6000 ft"
On the STAR "Paitn One Arrival" there is a fix called "RHIVR" (river) with a note to "Expect clearance to cross at FL200"
as for the VFR "landmarks" with the airlines GENERALLY we only get those when there are published procedure JEPP plates for certain visuals like at LGA, DCA, etc... As such, my carrier has no published JEPP plates for visual anything at ORD that would indicate to cross a physical river at any particular alt.
"Sonny, did we land? or were we shot down?"
mmedford
I noticed our controllers use the term sequence alot...
eg; "blue 622, follow company from left, he is your sequence tower @ 119.1"
ILS = It'll Land Somewhere
jetmatt777
Crew
Sat Oct 17, 2009 10:55 pm
Quoting Mmedford (Reply 7):
Meaning he will depart after the company traffic.... I presume it is so the pilot knows to remain behind him for the entire taxi, and to expect to depart right after he does.
That term is not in the dot sixty-five for controller -> aircraft comms, so it must be a JFK thing. Normally the most something similar is used is when sequencing arrivals. I.E.
" [Pilot reports traffic to follow in sight] Follow that traffic, cleared visual approach runway 31R"
"[...] you are 5 miles in trail behind a company 737"
etc..
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
P3Orion
Sun Oct 18, 2009 2:44 am
Quoting IAHFLYR (Reply 5):
I work in the ATCT, but I wouldn't say I'm aware of what's going on.  Smile
I will have a Manhattan.
Fly2HMO
Sun Oct 18, 2009 2:55 am
Quoting ThePinnacleKid (Reply 6):
You gotta love the guys at the charting office, they seem to have a sense of humor, there's lots of interesting sounding fixes out there.
I remember reading an approach chart for some random airport, don't remember the spelling of the fixes but the phonetic pronunciation for the IAF/FAF/MAP sounded like meeny, miny, moe
[Edited 2009-10-17 19:56:05]
[Edited 2009-10-17 20:29:53]
[Edited 2009-10-17 20:30:09]
jetmatt777
Crew
Sun Oct 18, 2009 3:11 am
Quoting FLY2HMO (Reply 10):
Yeah, they do have a good sense of humor. I can think of a few that are funny. One that comes to mind is SEXXY also in Chicago.
[Edited 2009-10-17 20:48:09]
Fly2HMO
Sun Oct 18, 2009 3:28 am
Quoting Jetmatt777 (Reply 11):
GRR260/035
GRR 260 Radial, 35 DME.
O woooooow I must be blind
I'm a freaking CFII and I missed that. How embarrassing
EDITED the post to hopefully make me seem less stupid  dopey
[Edited 2009-10-17 20:31:32]
jetmatt777
Crew
Sun Oct 18, 2009 3:48 am
Quoting FLY2HMO (Reply 12):
I'll let you off the hook with a favor. I also edited my post.  Wink
mmedford
Sun Oct 18, 2009 3:51 am
Quoting Jetmatt777 (Reply 8):
"[...] you are 5 miles in trail behind a company 737" etc..
Oh I know what they mean, just adding to the content of the thread....
chuchamadre
Mon Oct 19, 2009 6:51 am
Silly question perhaps, but why do they sometimes call planes "heavy" after their call sign?
I hear that a lot in plane to tower conversations in episodes of Air Crash investigation etc.
Chucha M.
Maverick623
Mon Oct 19, 2009 8:28 am
Quoting Chuchamadre (Reply 15):
"Heavy" is a designator used for airplanes with a max gross takeoff weight of 255K pounds or greater. It's used to help ensure proper separation, as heavier planes generate larger wakes, and smaller airplanes need to keep a greater distance so they don't get flipped over.
"PHX is Phoenix, PDX is the other city" -777Way
WROORD
Mon Oct 19, 2009 3:36 pm
Thank you. This makes sense especially considering the speed and altitude given. Now is there something souding like "college"which I heard was given to pilots on the same approach to ORD?
Certainly the quality of sound on some communication is not clear so what seems like "college" to me miay be some abbreviated instruction.
PGNCS
Mon Oct 19, 2009 5:19 pm
Quoting WROORD (Reply 17):
I have no clue about "College", but think that almost certainly you were hearing "RIPPR" in the context you provided as ThePinnacleKid surmised... See the chart below.
http://204.108.4.16/d-tpp/0910/00166IL27L.PDF
IAHFLYR
Mon Oct 19, 2009 5:23 pm
Quoting Maverick623 (Reply 16):
Respectfully, that is just a pound incorrect!
By FAAO 7110.65S, "Heavy. Aircraft capable of takeoff weights of more than 255,000 pounds, whether or not they are operating at this weight during a particular phase of flight".
KLASM83
Mon Oct 19, 2009 6:56 pm
Lmao  rotfl
And if the controller asks and finds out your are local, they then vector you in via the outlying casinos. M to the Red Rock to Three Fingers Lake wold probably have the non local pilots in AZ.  conehead
Don't you want to hang out and waste your life with us?
FX772LRF
Mon Oct 19, 2009 9:54 pm
Thought I'd throw this in there, the Airbus A380 is designated Super because of it's combination of weight and large wake turbulence, and requires a larger spacing deficit than say, a 744 or 773.
-Noah  wave
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
KELPkid
Mon Oct 19, 2009 10:01 pm
Quoting FX772LRF (Reply 21):
-Noah
Only in the US. As I recall, "Heavy" isn't even an ICAO designation, but many countries outside the US choose to use the "Heavy" callsign suffix...
FX772LRF
Mon Oct 19, 2009 10:04 pm
Quoting KELPkid (Reply 22):
Only in the US.
Really? That doesn't make sense, unless regular heavies are spaced out enough anyway that the A380's requirements are met.
-Noah  wave
DaBuzzard
Mon Oct 19, 2009 10:33 pm
They must - my personal favorite:
ITAWT
ITAWA
PUDDY
TAATT
IDEED
IIRC it describes an approach into Portsmouth NH
PGNCS
Tue Oct 20, 2009 12:57 am
Quoting DaBuzzard (Reply 24):
ITAWT
ITAWA
PUDDY
TAATT
IDEED
I liked KATL's YABBA, DABBA, and DOOOH for ILS 27L, but wondered how they get by with YABBA and DABBA sounding so similar in such proximity. (It's not good to go to YABBA when ATC clears you direct DABBA!) Sure enough, a short while later DABBA had its name changed; a positive for safety but not as much fun!
http://204.108.4.16/d-tpp/0910/00026IL27L.PDF
Fly2HMO
Tue Oct 20, 2009 2:52 am
ITAWT
ITAWA
PUDDY
TAATT
IDEED
Yeah I remember reading that one too!
There's many sports inspired ones too. Like in PHX, you got the SUNSS 6 arrival. Some of the waypoints are BBALL, HOOPS, SLAMN
My favorite one in the PHX area was BRUSR (bruiser). I still remember hearing ZABQ always telling arrivals to cross BRUSR at 12000 and 250kias.
[Edited 2009-10-19 19:57:14]
glen
Tue Oct 20, 2009 6:14 pm
Just to clarify: The categories like "Heavy" and "Super" etc. are ICAO, but they don't have to be mentioned in ATC-communication in many countries. In these cases it is the controllers duty to know the wake categories based on the type in the ATC-flightplan.
More and more countries however are asking for the suffix in communication - makes it easier.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
wilkes
Thu Oct 22, 2009 5:26 pm
Quoting FLY2HMO (Reply 26):
MDW and ORD both have Chicago-sports themed arrivals.
HALAS, BEARZ in honor of Da Bears
OZZEY, FISSK, VEECK in honor of the White Sox.
lrdc9
Fri Oct 30, 2009 1:59 am
BWI has TERPS for University of Maryland, although I always love hearing PALEO on the scanner.
Just say NO to scabs.
KELPkid
Fri Oct 30, 2009 4:19 am
Quoting Lrdc9 (Reply 29):
I thought every airport has published TERPS  duck  , at least that's what the FAA's TERPS would lead you believe Big grin
IAHFLYR
Tue Nov 03, 2009 5:46 pm
I kind of take a liking to the RIICE Arrival into IAH and the name of
Quoting KELPkid (Reply 30):
Nope, there are many airports as you know that don't have Terminal Instrument Procedures (TERPS)!!!  bouncy
the FAA's TERPS
There must be some connection here with turtles.  Smile
Houston also has sports theme arrivals after the professional and college area teams. ROKIT, TEXNN, RIICE, AGGEE, and formerly a STROS Arrival.
There is also a CLMBA RNAV Arrival in memory of the Space Shuttle Columbia with names of the astronauts.
Tiger119
Wed Nov 04, 2009 4:23 am
Quoting PGNCS (Reply 18):
Quoting PGNCS (Reply 25):
- I don't know why but those will not open up for me,
http://204.108.4.16/d-tpp/0911/00203RACYR.PDF
http://204.108.4.16/d-tpp/0911/00203INDY.PDF
Racyr One Arrival and Indy Two Departure for IND but I don't know where this name came from:
http://204.108.4.16/d-tpp/0911/00203ROCKY.PDF
David
Flying is the second greatest thrill known to mankind, landing is the first!
B727LVR
Wed Nov 04, 2009 5:14 pm
I would agree with the above that it's likely a point in an approach procedure to follow.
A good one I heard before is GIZMO going into Pope AFB.
Also the Airport in Farmington NM, is referred to as Rattlesnak (KRSK/RSK).
There are some good ones out there tho.
I'm like a kid in a candy store when it comes to planes!
Users browsing this forum: AndyCigi and 15 guests
