Jawed
757 Can Land At Maximum Takeoff Weight?
Wed Oct 28, 2009 2:03 am
Why can the 757 land at MTOW (i.e. land immediately after takeoff without dumping fuel), but other planes can't? Which other large airliners can?
Quoting NWA757boy (Reply 6):
The 757 can land at MTOW....she's a beast.
From another thread: UAL 177 Emergency At Boston (by FrequentFlyKid Oct 27 2009 in Civil Aviation)
[Edited 2009-10-27 19:04:21 by jawed]
Transpac787
RE: 757 Can Land At Maximum Takeoff Weight?
Wed Oct 28, 2009 2:12 am
Other large airliners *can* land above max landing weight. Of course, it's only to be done in an emergency.
The 767's, for example, also can land above maximum landing weight. The fuel-dump system, if an airline has it installed, only dumps from the center tank. Or, if an airline doesn't even have it installed, you'll of course have to land overweight.
PGNCS
Wed Oct 28, 2009 2:17 am
ANY airliner can land at max takeoff weight in an emergency. If landing above Max Landing Weight, there will be additional checklists and maintenance procedures to deal with. At some airports (think hot and high places) and in some aircraft in some situations there may be issues with Approach Climb Limiting Weight, but that is a very esoteric subject and is generally not terribly restrictive.
captseth
Wed Oct 28, 2009 2:37 am
Max LDG weight on the -200's I used to fly was 198.0, on the -300's it was 224.0, both considerably below the MGTOW. A landing above those numbers would result in an overweight landing inspection prior to further flight.
tdscanuck
Wed Oct 28, 2009 3:48 am
Quoting Jawed (Thread starter):
As others have noted, all airliners are physically capable of doing it. You just need to do the appropriate checks afterwards. Provided it's done at a suitably low sink rate, it can be done without damage. The different across airliners is how sensitive they're going to be to landing at high sink rate...a 747 or A340 at MTOW must be treated much more gingerly than a 757.
Quoting Transpac787 (Reply 1):
Is that 767 specific? Several other models can dump from all tanks.
Tom.
Western727
Wed Oct 28, 2009 8:09 pm
Quoting Tdscanuck (Reply 4):
Why is this so? Is it because their frames are designed for fewer cycles (thus, fewer fuselage "ribs", etc.)? Does this also mean the 747-100SR/400D can be treated less "gingerly" than their respective long-range equivalents?
Jack @ AUS
boeingfixer
Wed Oct 28, 2009 9:05 pm
Quoting Western727 (Reply 5):
Mainly because the mass and inertia are quite a bit higher as gross weight increases and imparts greater stresses on the landing gear. I would also place the 747-100SR/400D in the same category.
John
Cheers, John YYC
rwessel
Wed Oct 28, 2009 11:18 pm
No. For really long range aircraft the difference between MLW and MTOW can be very large.
For example, for the base 757-200, the MTOW of 220,000lbs is only 11% higher than the MLW of 198,000lbs.
But for the smallest 772, the 508,000lbs MTOW is 32% higher than the 441,000lbs MLW.
PGNCS
Wed Oct 28, 2009 11:22 pm
Tom:
Yes that is specific to the 767.
Users browsing this forum: RetiredWeasel and 1 guest
