Faro
Ring From Helicopter Rotor Blade/glove
Mon Nov 02, 2009 9:12 am
I am searching for (a small chunk of) a used helicopter rotor blade or rotor blade glove from which the intention is to hew a set of wedding rings. It’s a long story, but that’s the gist of it for the purpose of this thread.
Can anyone help out on this one? Metal is important, don’t know how much metallic-bladed or -gloved rotors get rubbished these days. Cost is important too, don’t know what scrap value these items may have.
Many thanx!!
Faro
The chalice not my son
tdscanuck
RE: Ring From Helicopter Rotor Blade/glove
Tue Nov 03, 2009 1:43 am
Quoting Faro (Thread starter):
Does it have to be a helicopter, or is a propellor blade acceptable?
Tom.
Faro
Tue Nov 03, 2009 10:22 am
Quoting Tdscanuck (Reply 1):
A helicopter blade if at all possible; failing that, a helicopter tail rotor blade or blade glove if it's got sufficient thickness.
Thanx in advance!
Faro
HaveBlue
Tue Nov 03, 2009 3:35 pm
I've got 2' sections of Huey rotor blades, but I'm not parting with em. When they take a D or H model Huey and chop the rotor blade to fit on the smaller B or C model (or take a 205 blade and put it on a 204) they have to lop 2' off of each side, and that's what I got. You would be amazed how heavy it is.
Good luck with your quest though, cool idea.  Smile
Here Here for Severe Clear!
jarheadk5
Tue Nov 03, 2009 10:23 pm
Interesting idea.
Cost depends on the spar material. A titanium-sparred blade will have significant scrap value; even an aluminum-sparred blade will have a decent scrap value.
I'd be pretty surprised if any operator simply threw those sorts of things away. I know when I worked for Carson Helicopters, they kept every S-61 main rotor blade they had ever flown. They probably still have all their old metal blades, even though they've been flying their all-composite blades on all their aircraft for several years now.
Good luck with your search!
-Boom stowed, leaving position.
2H4
Tue Nov 03, 2009 10:42 pm
Quoting Faro (Reply 2):
Here's one.
Here's another.
Edit - Just found a main rotor tip assembly
2H4
[Edited 2009-11-03 14:49:04]
Intentionally Left Blank
Faro
Wed Nov 04, 2009 8:34 am
Quoting 2H4 (Reply 5):
Here's one.
Here's another.
2H4
Thanx a million, never occured to me to look at Ebay, but there ya go!
Faro
DocLightning
Thu Nov 05, 2009 8:18 am
I can't help you, but it looks like 2H4 did a fantastic job of it.
But that's a beautiful idea, whatever the story behind it is. Are you going to have a stone set in hers? If so, consider sapphire, an allusion to a clear, blue sky, as an alternative to diamond (and often cheaper, too).
-Doc Lightning-
-Carl Sagan
Faro
Fri Nov 06, 2009 10:54 am
Quoting DocLightning (Reply 7):
Funny that the idea was actually hers, and she's anything but an aviation-person. Still not set on the stone but we have to figure out how to tranform a chunk of tail rotor into a ring first (machining, melting, etc). The rotor itself is aluminium but the glove attachment should be steelesque. Sapphire is certainly a very pleasing sky blue, will think about it.
For information, the item is 1.95 meters long and 41 cm wide and prolly over 30 kg in weight: in tail rotor terms it's a whopper. The vendor is not sure of the helicopter model but there's a fair chance it was intended for the CH-37 Sikorsky Mojave, the biggest helicopter in the West when it came out in the 50's.
Photo © Reinhardt Rolf
Faro
Users browsing this forum: ferpe, fortytwoeyes, gloom, Starlionblue and 3 guests
