Reggaebird
Initial Climb Angle Of The Airbus A380
Tue Nov 03, 2009 12:54 pm
I recently observed two Emirates A380s departing Sydney airport and noticed that the initial climb angle seemed less steep than other aircraft. I then flew on an Emirates A380 out of Auckland and got the distinct sensation of a lower climb angle than when I fly on other aircraft. Is the lower angle a reality? Is it a design feature? If so, what benefit does it provide?
Here are videos of the two Sydney departures that I mentioned:
http://www.youtube.com/watch?v=KTAoeh83kuU
http://www.youtube.com/watch?v=LHO9F_gZmPw
And here are examples of a 747 and an A330 taking off at the same airport:
http://www.youtube.com/watch?v=24kqlvxzHBA
http://www.youtube.com/watch?v=IH8cu-EawjU
[Edited 2009-11-03 05:03:04]
cloudyapple
RE: Initial Climb Angle Of The Airbus A380
Tue Nov 03, 2009 1:46 pm
Are you referring to the angle of attack of the aircraft or the rate of climb of the aircraft?
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
Reggaebird
Tue Nov 03, 2009 2:04 pm
Quoting Cloudyapple (Reply 1):
I am referring to the angle of attack on departure.
affirmative
Tue Nov 03, 2009 2:18 pm
I'm not sure if I agree.. I've seen the A380 taking off from DXB now a couple of times and compared to EK 744 cargo I'd say it's pretty much the same. The A380 seem to have a higher initial pitch (AOA) on rotation but once it settles they seem to have pretty much the same as the 744.. The rate of climb on the other hand is way better than the 744, quite similar to the A332 actually..
I know the 744 tends to look like it has a higher AOA because of the hump but from my experience you can't spot the difference, maybe if you had them taking off side by side.
just my 2ç
I love the smell of Jet-A1 in the morning...
khobar
Tue Nov 03, 2009 2:29 pm
One of the reasons the A380 has a smaller noise footprint than the 747 is because it can outclimb the 747. Of course it also has larger, slower turning fans which also contributes to its smaller noise footprint.
scbriml
Tue Nov 03, 2009 5:01 pm
It's certainly not a limitation of the plane:
Photo © Steve Brimley
 wink
khobar
Tue Nov 03, 2009 5:53 pm
Quoting Scbriml (Reply 5):
In this video it "appears" to be flying almost vertical. LOL.
http://www.youtube.com/watch?v=tuFRM_G50Nc
Where's the jet that's making all the noise?
SimProgrammer
Tue Nov 03, 2009 10:29 pm
The A34x is also a slow climber when full, becasue the wing design is optimised for cruise economy. The airshow 380 is an empty plane & very easy to do at low alt.
Drive a bus, an Airbus, easier than a London bus!
Aeroflot001
Tue Nov 03, 2009 11:46 pm
Quoting Khobar (Reply 6):
http://www.youtube.com/watch?v=tuFRM...G50Nc
That vid sure shows that the extra power is there when its needed although it may not be fully loaded there.
7673mech
Tue Nov 03, 2009 11:57 pm
That one is empty!  Wink
ogre727
Wed Nov 04, 2009 12:03 am
I flew it from SIN to LHR... it struck me as a very slow climber....
cpd
Wed Nov 04, 2009 1:27 am
Quoting Ogre727 (Reply 10):
I think they often run reduced power take-offs, at least out of Sydney - the near silence suggests that.
But, you definitely know when they use more power - the noise is much louder and very distinctive (Trent 900 anyway - I can pick it immediately from any other plane just by the sound). That's all quite unscientific, but I see 2 or 3 A380's just about every day, so you get to know them well enough.
They can climb quite quickly otherwise.
[Edited 2009-11-03 17:30:26 by cpd]
9MMPD
Wed Nov 04, 2009 3:44 am
Both my A380 flights (SIN - LHR - SIN) felt like they had a shallow climb. What also led to this feeling was how quiet the cabin as during departure maybe that has something to do with it?
vikkyvik
Wed Nov 04, 2009 4:16 am
Quoting Reggaebird (Reply 2):
Not to be nitpicky (  Wink ), but you can't tell the angle of attack of an airplane just from watching it fly by. Angle of attack refers to the angle of the wing relative to the freestream flow.
swallow
Wed Nov 04, 2009 4:20 am
I've read on this board that the 380 can go straight to cruise altitude without having to do a "step climb".
Is this because of its optimized wing?
The grass is greener where you water it
Reggaebird
Wed Nov 04, 2009 4:54 am
Quoting Swallow (Reply 15):
Well, I read that it can climb to FL350 without a step climb but requires a step to get to normal cruise around FL400.
astuteman
Wed Nov 04, 2009 5:27 am
Quoting Reggaebird (Thread starter):
Whether the angle-of-attack is any different, I don't know, but that HUGE wing generates a phenomenal amount of lift - enough in fact to give a 600 tonne to 625 tonne A380 variant (if there ever is one), decent field and climb performance.
Hence the "cooking" 560 tonners we have today have an abundance of lift, even at MTOW.
So they will have absolutely no problem whatsoever gaining altitude in a VERY timely manner  Smile
Quoting Affirmative (Reply 3):
 checkmark
413X3
Wed Nov 04, 2009 5:34 am
I am sure the slower climb has more to do with fuel savings with such a heavy load on board than any missing power it may or may not have.
astuteman
Wed Nov 04, 2009 5:40 am
Quoting 413x3 (Reply 17):
Slower thatn it's capable of? Or slower than other planes?
It isn't
Funnily enough, when you look at the field performance charts, if I read them right, the only other widebody that matches the A380 for take-off distance capability is the A330 - according to their charts, these planes will take off at MTOW, at 0 ft and ISA +15c in 2 900m (for comparison, the 773ER chart shows 3 100m for the same evolution..)
Francoflier
Wed Nov 04, 2009 5:46 am
There is no single cruise altitude that an airliner will always climb to on every flight.
Optimum cruise altitude depends on the weight of the aircraft and atmospheric conditions and changes as the aircraft gets lighter.
What the A380 can probably do better than other very heavy aircrafts is climb to a higher cruise altitude earlier in the cruise, probably maintaining a faster rate of climb throughout.
This is due to its huge wing (designed for a much heavier aircraft still) and power to weight ratio.
A maxed out 744 will typically climb to an initial optimum cruise altitude of 30,000 ft, while an A380 can probably go higher under the same conditions, although I don't know how much higher. It will still do step climbs further on after it loses some weight.
Climbing higher sooner has a few advantages. The longer you stay higher, the less fuel you burn, and by being able to go higher sooner you can avoid having to fight for flight levels and get your optimum FL more easily.
speedbird128
Wed Nov 04, 2009 9:55 am
Quoting SimProgrammer (Reply 7):
Having been involved in the hot weather trials (and also taking photos at that same airshow), I can assure you that even at high gross weights the A380 can climb really well...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
joakims
Wed Nov 04, 2009 10:23 am
Quoting Swallow (Reply 14):
I remember then my wife and I flew SQ A380 from LHR to SIN. We went up to 35.000 feet directly after takeoff The last climb up to 38.000-39.000 came near Nicobar and Andaman Islands in the Bay of Bengal. I think it was due to the usual turbulence in that area.
Joakims
rcair1
Crew
Wed Nov 04, 2009 2:45 pm
Quoting Francoflier (Reply 19):
I've seen references to the "huge" wing and high power/weight ratio and similar statements several times. Does this mean the wing loading on an A380 is less than typical airliners? I thought that (in basic aeronautical engineering classes I took 20+ years ago) that a lightly loaded wing meant good climb performance, long glide performance, but typically less efficient cruise due to more drag. Or am I remembering wrong (or simplifying too much)? If that is true, then the only reason the A380 would have an unusually light wing load is so that they can build heavier variants. Is that the plan at Airbus? If heavier variants were built - they'd have to be cargo, I have a hard time seeing even larger passenger loads.
It seems quite inefficient to build higher performance into the product than needed, (as an engineer, we try to walk the line), but Airbus is hardly into building inefficient products - and the A380 is reportedly quite efficient - so there must be a reason. The 747 was overbuilt in several regards, but it was the first 'jumbo' (Boeing was somewhat conservative in the design) and built when engineering design/tolerance management was less efficient. I'd expect newer types (regardless of manf) to be closer to optimal.
I guess I'm confused. There must be a reason for oversized wings/power. What is it?
rcair1
vikkyvik
Wed Nov 04, 2009 6:01 pm
Quoting Rcair1 (Reply 22):
A lightly-loaded wing should result in less drag than a heavily-loaded wing, all other things being equal. Your induced drag would be reduced.
In general, climb performance is determined by excess thrust.
rcair1
Crew
Wed Nov 04, 2009 7:24 pm
Quoting Vikkyvik (Reply 23):
Thanks. I was thinking that the larger wing will cause more parasitic (form) drag - but now that I think about it - what a larger wing will do is cause the induced drag curve to shift down and/or left vs airspeed, and the parasitic curve will move up and/or left - so what changes is the airspeed at which minimum drag is achieved will change, but that does not inherently make the wing/plane less efficient, perhaps a little slower at minimum drag.... I'm sure this is way over simplified.
Duh  banghead  I knew that.... Stupid question.
rcair1
astuteman
Wed Nov 04, 2009 11:03 pm
The A380's wing is designed to entertain MTOW's in the 625t - 630t region, to support both ULR A380-800 variants and stretch versions.
As for drag, the huge wingspan probably goes a long way to offset the parasitic drag due to the large wing area (which, by the way, on a per pax basis isn't actually all that big... )
Wed Nov 04, 2009 11:29 pm
As others have said, no you're not. There is no way to tell the angle of attack, which is the angle between the wing and the airflow, from looking at the plane.
You are referring to the angle compared to the ground. While this is related to climb rate, it is not a 1:1 relationship. Planes can climb even when their fuselage is more or less level.
Bottom line, you can't really tell that much from looking at the aircraft.
SB
Thu Nov 05, 2009 7:27 am
Quoting Starlionblue (Reply 26):
Generally referred to as pitch.
S.
"Confirm leave the hold and maintain 320kts?!"
Thu Nov 05, 2009 10:02 am
Quoting SB (Reply 27):
Thanks. The name escaped me.
a380900
Sat Nov 07, 2009 2:25 pm
Also, the big wing has a strategic component: they wanted to completely corner the VLA market. With the big wing, they're telling Boeing: "There's no ways you can do bigger. If you try, we'll stretch it and we'll come close to whatever you're shooting for. Don't even think about it." Since Boeing is constrained, like Airbus, by airport standards (80m box etc...), Boeing can make a "me too" product but not something better based on economies of scale.
In other words, in getting "bigger than yours" on boeing, Airbus sized the airplane in order to prevent Boeing from ever getting "bigger than yours" on Airbus back.
Francoflier
Sat Nov 07, 2009 7:21 pm
Quoting Astuteman (Reply 25):
Interestingly, that would bring its wing loading figure almost exactly to that of the 747-400.
Quoting 9MMPD (Reply 12):
That could also be because the A380 maintains a shallower pitch during climb (and cruise) due to the fact that its lightly loaded wing uses less angle of attack. (Although I'm not sure what kind of pitch attitude it maintains in climb and cruise).
BlatantEcho
Tue Nov 10, 2009 10:29 am
Flew LAX-SYD last week on the A380.
We took off and climbed up to 32000, then stepped up to 360 and ended up at 390 a few hours out of SYD.
Seemed like a very long time to get to FL320, but I'm just SLF in in the back, so take that for what you will.
They're not handing trophies out today
Faro
Tue Nov 10, 2009 11:35 am
And it looks it. The wing is huge in proportion to the fuselage, which doesn't help the A380's aesthetics much either, but that's a shortcoming airlines are willing to tolerate...
I would be willing to bet, on the basis of passenger-per-square-meter calculation, that the A380 is the most "over-winged" airliner flying today.
Faro
The chalice not my son
