GolfOscarDelta
Mx Procedures After Tailstrike
Tue Nov 10, 2009 12:47 am
I was just wondering what are the mx actions taken after a tailstrike for something like a 777 or a A340 vs a 172. Do they check for structures damage on a 172 in a way similar to a 777 or do they just check for skin damage etc? Or does all of it depend on the severity of the tailstrike? e.g. what if the tailstrike pad itself was broken by the severity of the strike?
Thnx in advance for the replies.
skywatch
RE: Mx Procedures After Tailstrike
Fri Nov 13, 2009 12:13 am
I don't know about the larger birds, but it's usually not a big deal on the 172. The tie-down hook on the 172 is really thick, and if you look at the hooks on training or rental aircraft, the bottom of it will usually be pretty worn down, since it is the first point of contact with the ground if the plane flares too high or rotates too aggressively. You would really have to screw up big time to have skin or the elevator hit the ground in a 172. I have scraped the hook when I was learning soft-field takeoff procedure (applied power too quickly!). No big deal, just take a look at it after the flight to make sure there are no wrinkles or scrapes in the skin. In a larger transport category aircraft, a detailed inspection of the damage is usually in order after a tailstrike. I'm sure some more knowledgeable people on here will be able to enlighten you!
---Skywatch
------Forever Watchin' The Sky------
474218
Fri Nov 13, 2009 12:50 am
An inspection of the stringers, frames and the aft pressure bulkhead is required anytime there has been a tail-strike.
stratosphere
Fri Nov 13, 2009 4:09 am
Quoting 474218 (Reply 2):
Thats true and in the case of the 777 it has a what looks like a DME antenna on the tail but it is for tailstrikes when it strikes the ground the resistance changes and give the flight deck a warning that they have had a tailstrike.
474218
Fri Nov 13, 2009 4:32 am
Quoting Stratosphere (Reply 3):
A lot of aircraft have provisions in the aft body intended to either prevent a tail strike or lessen its consequences. However, it has been my experience that these devices where just one more thing that needed to be repaired when a tail strike occurred.
L-188
Fri Nov 13, 2009 5:32 am
None needed if it is a DC-3 or Cessna 185
Fri Nov 13, 2009 9:12 am
Quoting L-188 (Reply 5):
You would if it was a tailstrike not a tailwheel strike  wink
regds
MEL.
tdscanuck
Fri Nov 13, 2009 2:36 pm
Depending on the airframe, you might not need to do all that if the tailskid itself hasn't fully crushed.
Tom.
GolfOscarDelta
Fri Nov 13, 2009 7:37 pm
Quoting Skywatch (Reply 1):
Yep the 172 i saw on the ramp a few days back had the tail skid and the tie down hook sheared off along with bits of the skin off the bottom of the rudder, the guy who had the tail strike walked off and the next guy took it back up again right away. I would assume that the rudder would be off balance or something in case the rudder was impacted at tailstrike. That got me wondering if any sort of checks were required on GA's vs. Transport Cat aircraft and the differences.
Any takes on how long that takes the plane out of service? IIRC the EK A345 that has a strike in MEL was out for a few months but that was a very severe one i presume, how about other ones with "normal" tailstrikes, how long does it take for an aircraft with a tailstrike to get back into service after the checks.
Thnx
tdscanuck
Sat Nov 14, 2009 1:17 am
Quoting GolfOscarDelta (Reply 8):
In the EK case, most of that time would have been the repair, not the inspection. I've had a tailstrike and been back in service 10 minutes after we got to the ramp.
Tom.
Dalmd88
Sat Nov 14, 2009 2:41 am
I know one thing, If I ever see the tailskid crushed or get a pilot write up for a possible strike, I'm going look real close at the belly for any scrapes. It would really suck to sign off a tailstrike inspection to only have the next downline station find all sorts of damage.
pilotpip
Thu Nov 19, 2009 4:31 am
Sounds like somebody needs to work on their preflight inspections a bit.
DMI
Users browsing this forum: shamrock137 and 33 guests
