liedetectors
A-321 CFM56-5 Chevrons
Mon Nov 16, 2009 4:31 am
Hello all,
I just noticed that Aeroflot's CFM-56-powered A-321, pictured in the link below, has chevrons in the vicinity of the exhaust nozzle. Does anyone know the story behind this? Is this an Airbus upgrade or a long-term test article? The next CFM56-powered 321 (of Air India) off of the line did not have chevrons.
http://www.airliners.net/photo/Aerof...Russian/Airbus-A321-211/1609608/L/
If it was said by us, then it must be true.
Mir
RE: A-321 CFM56-5 Chevrons
Mon Nov 16, 2009 5:00 am
Unrelated question (but related to the pic):
What are those two little ports about halfway up the back of the pylon for? They look like drains, but drains for what?
-Mir
tdscanuck
Mon Nov 16, 2009 5:04 am
Quoting Liedetectors (Thread starter):
Unfortunately, no. I'd love to hear the inside scoop!
Quoting Mir (Reply 1):
I don't know for sure, but you usually have a drain in that area for the strut. At least one to let fuel/water out so it doesn't pool in the strut and probably another one for hydraulics if they've got a pump or resevoir in the fairing (not sure if the A321 does, but some aircraft do).
Tom.
747classic
Mon Nov 16, 2009 9:05 am
Quoting Tdscanuck (Reply 2):
I found this article over the CFM56-5B engine, installed on the A321, on the CFM website.
The following is mentioned : "The technology being developed includes: three-dimensional aerodynamic outlet guide vanes; a core chevron nozzle; and improved reverser and inlet linings on the nacelle."
See : http://www.cfm56.com/press/news/cfm5...begins+full-scale+engine+tests/339
For further info :
http://www.aiaa.org/events/aners/Presentations/ANERS-Gliebe.pdf
[Edited 2009-11-16 01:14:16]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
oly720man
Mon Nov 16, 2009 12:31 pm
http://www.airbus.com/store/mm_repos...dia_object_file_FAST37_p19_p22.pdf
It's an Airbus/CFM noise reduction device option that can be fitted. Could be that the noise rules in India are rather less onerous than in other places, hence the lack of them on the AI aircraft.
The more recent AF aircraft are fitted with them, though not always easy to see, e.g.
F-GTAR
Photo © Sergio Domingos
F-GTAS
Photo © Ruud Brinks
F-GTAV
Photo © Daniel & Robert Fall
liedetectors
Mon Nov 16, 2009 5:43 pm
Sweet! Thanks guys for the informative replies and links!
Fly2HMO
Tue Nov 17, 2009 1:01 am
Hmm never seen them before. Funny that its only on the 321s, you'd think it would be available on other CFM Airbii
keta
Tue Nov 17, 2009 7:01 am
Quoting FLY2HMO (Reply 6):
Right, why can't we see them in the A320? Neat feature anyway, never noticed it before!  Smile
Where there's a will, there's a way
GPHOTO
Tue Nov 17, 2009 7:29 am
Chevrons in the exhaust section are becoming increasingly common. For example, I noticed these two recently:
Photo © Jim Groom
Photo © Jim Groom
As well as reducing noise, I would be interested in any effect it might have (positive or negative)on fuel economy or thrust?
Jim
Erm, is this thing on?
keta
Tue Nov 17, 2009 10:44 am
Quoting GPHOTO (Reply 8):
I have a figure for the fluted nozzles on the JT8D quoting 7 dB noise reduction with about 5-6% loss of thrust. This is kind of old, though; I'm pretty sure these serrations achieve better results.
747classic
Tue Nov 17, 2009 1:12 pm
As stated in the article : http://www.airbus.com/store/mm_repos...dia_object_file_FAST37_p19_p22.pdf
The "noise package" is now standard on the A321 and an option on the other models.
The reason behind this is that the A321 (heavy weight version) doesn't comply with the new stage 4 noise limits in effect for all new aircraft, certified after 1 January 2007.
In fact this is the present noise standard, although legally not valid for the present A320 generation of aircraft, all certified before 1 januari 2007.
All other sub types of the A320 series are at or below the stage 4 noise standard and don't need the chevrons, but can be delivered as an option with this "noise package", to become even more silent.
Also stated in the article is the fact that the FADEC needs some tweaking to produce the same thrust level, so there must be a loss in efficiency somewhere.
Because this is an Airbus brochure, nothing is said about the actual loss in SFC.
ex52tech
Thu Nov 19, 2009 11:18 am
Pylon drains, from different areas of the pylon, one is in the area where the lines hook up. Many airplane's pylon drains connect to the engine, and drain out of the gang drain on the engine.
The fairing just below those drains has a channel to drain any fluids out of the area in the aft section of the pylon.
"Saddest thing I ever witnessed....an airplane being scrapped"
LH707330
Fri Dec 11, 2015 6:23 pm
Thread bump: has anybody figured out how much of a fuel burn penalty these core chevrons add? I've heard that the nacelle chevrons on the 787 cost about .25%.
Users browsing this forum: N353SK, passyflyer, Wacker1000 and 1 guest
