DocLightning
Gearboxes And Generators
Mon Nov 16, 2009 8:51 pm
So one thing I've been wondering about is the talk of gearboxes and generators in jet engines.
How does one extract the rotational energy of the shafts without interrupting the airflow?
Do both N1 and N2 have attached gears? What's the arrangement that allows for that?
And how is the generator handled? It needs to produce a constant supply of juice, but with the engine speed going up and down all the time how is this regulated?
-Doc Lightning-
-Carl Sagan
Woodreau
RE: Gearboxes And Generators
Mon Nov 16, 2009 10:00 pm
In general, the gearbox is usually attached to the N2 compressor and all the accessories are attached to the gearbox (the starter, generator, oil pumps, fuel pump, hydraulic pump, generator for the FADEC - if it has a FADEC, etc.)
The generator itself is attached to a constant speed drive. The constant speed drive is attached to the gearbox. The generator requires a constant RPM, so that it can produce a steady 400Hz. It's the variation in the frequency that messes up electronics.
There are some generators out there that don't produce a constant frequency (they aren't attached to a constant speed drive, so they experience RPM changes as the engine accelerates and decelerates) - they're called "wild" generators, but I've only seen them in turboprops.
Again that's a generic explanation.
DocLightning
Mon Nov 16, 2009 10:17 pm
Quoting Woodreau (Reply 1):
So these are the parts I'm specifically asking about.
How does one attach a gearbox to the N2 shaft, which lies in the center of a bunch of whirling blades? Where does the mechanical linkage sit so that it doesn't interrupt the airflow?
And how does a "constant speed drive" work? Do jet engines have some sort of continuously-variable transmission?
-Doc Lightning-
-Carl Sagan
Woodreau
Mon Nov 16, 2009 10:38 pm
It's probably easier to see than explain:
There is a power takeup unit which connects the two. It doesn't get in the way of the airflow if that's what you're wondering.
This is what I could find - googled accessory gearbox under images.
http://media.photobucket.com/image/a...ssory%20gearbox/evo65/accessor.jpg
The constant speed drive is a "box/device" which provides the constant speed that the generator requires, it's not part of the engine. How does it work - don't need to know how it works in order to fly the plane.  Smile It either works or it doesn't. If it doesn't work, you get to do some real life abnormals. disconnect the generator and start up the APU.
So - each thing is it's own "box/device" in between the arrows:
N2 compressor -> Power Takeup Unit -> Accessory Gearbox -> Constant Speed Drive -> Generator
again not talking about any specific jet engine
NoWorries
Quoting DocLightning (Reply 2):
There's folk a lot more knowledgeable than me that will probably jump in here, but essentially a gearbox not unlike a differential allows the shaft connected to the generator to rotate at constant speed. Look up CSD (constant speed drive) and IDG (integrated drive generator)
Newer systems power alternators that are rectified to DC and then inverted to whatever frequency is needed -- more efficient that using gear regulated velocity,
[Edited 2009-11-16 14:40:03]
rwessel
Mon Nov 16, 2009 11:35 pm
The usual approach is to put a bevel gear onto the turbine shaft, and then run a shaft out the side of the engine. Usually it's the high pressure shaft, and often that shaft doubles as the drive shaft for the starter.
There are some good drawings here:
http://www.globalsecurity.org/milita...brary/policy/army/fm/1-506/Ch8.htm
The shaft does disrupt the airflow inside the engine, but so do the variety of structural members that hold the rotating parts in place. In at least some case, the shaft is run, wholly or partially, inside one of those structural members.
Usually the constant speed drive on a jet is not a CVT in the sense of varying-diameter pulleys, but rather a combination of a hydraulic pump and a hydraulic motor, and a bit of regulator to maintain the speed. In principal this is similar to the torque converter on an automatic transmission on a car.
For electricity generation, the more modern approach is to run the generator at variable speed, and then electronically convert that (varying output) to the required (fixed) output levels.
PGNCS
Mon Nov 16, 2009 11:41 pm
I have never heard that term, but have no turboprop time to speak of. I can tell you the MD-90 changed the rather bulletproof DC-9 CSD system that worked great to a Variable Speed Constant Frequency (VSCF) similar to what you describe. It is my least favorite feature of the MD-90, and one that was certainly not a step forward in my opinion.
DocLightning
Tue Nov 17, 2009 12:23 am
Quoting Rwessel (Reply 5):
http://www.globalsecurity.org/milita...8.htm
Ah, that answered a lot. So it seems that the gearbox sits within the diameter of the compressor disks so as to not impede airflow and a thin shaft (presumably in an aerodynamic fairing) passes out of the core to the gearbox.
-Doc Lightning-
-Carl Sagan
rwessel
Tue Nov 17, 2009 1:13 am
Quoting DocLightning (Reply 7):
Terminology quibble:
It's the bevel gears and shafts that are in the engine core, what's usually called the gearbox is outside the engine, on the other end of that shaft. The accessories then attach to the gearbox in various ways.
tdscanuck
Tue Nov 17, 2009 1:29 am
Quoting DocLightning (Thread starter):
You need to support the engine core, since that's where all the loads come in via the bearings. That means you need fixed structures between the outer case and the inner non-rotating structure...these take the forms of aerodynamic struts that go in between the rotating disks. The shaft is usually run inside one of these, so the shaft doesn't disrupt the airflow any more than it already was.
787 just skips the whole problem and uses variable frequency generators.
Tom.
DocLightning
Tue Nov 17, 2009 2:01 am
Quoting Rwessel (Reply 8):
Thanks for the correction.  Smile
-Doc Lightning-
-Carl Sagan
Fly2HMO
Tue Nov 17, 2009 3:17 am
Here's a cutaway of the CF6 as seen from the bottom-rear:
http://www.flightglobal.com/airspace/photos/aeroenginesjetcutaways/images/5605/general-electric-ge-cf6-50-cutaway.jpg
On almost all (civilian a tleast) engines the gearbox is somewhere between the 4 and 8 o'clock position. It's hard to make out but you can see the gearbox's drive shaft just aft of the bypass duct guide vanes in wide vertical fairing at the 6 o'clock position. This engine is a GE CF6-50.
In this pic of a CFM 56, you'll note the gearbox and accessories are offset more to the side, due to the 737's short height and thus producing the distinctive bulge on the 737 cowlings.
[Edited 2009-11-16 19:19:20]
jetmech
Tue Nov 17, 2009 6:27 am
You can see the set-up in the following picture of an RB211. Basically, there is a bevel gear set (circled in blue) that takes rotational energy off the N3 spool. This is transmitted via a set of drive shafts (red lines) to the external gearbox (boxed in green). The gearbox then distributes this to the various accessories such as the IDG. The only part of the set-up intruding into the gas path is the housing for the vertically orientated drive shaft.
http://www.flightglobal.com/airspace/photos/aeroenginesjetcutaways/images/5645/rolls-royce-rb211-535-cutaway.jpg
http://i94.photobucket.com/albums/l118/Jet-Mech/Jet.jpg
http://www.flightglobal.com/airspace.../rolls-royce-rb211-535-cutaway.jpg
Pretty much. A CSD consists of a variable displacement hydraulic pump supplying fluid (usually engine oil) to a fixed displacement hydraulic pump. The variable displacement hydraulic pump is usually of the multi-piston type with a tilting swash-plate. The input from the gearbox rotates the shaft, pistons and the cylinder block containing the pistons. The swash-plate (yellow) does not rotate, but pivots on a fixed axis as shown below. The small slipper feet (dark green ) on the bottom of the pistons slide upon the surface of the swash-plate.
http://home.planet.nl/~brink494/axpp_v.htg/axpp_v.gif
http://www.emeraldinsight.com/fig/0180560404021.png
You can see how the tilt of the swash-plate varies the strokes of the pistons, and hence the volumetric output from the pump. When the engine speed is high, the swash-plate tends to move to a neutral position to minimised the stroke of the pistons, and hence output of the pump.
When this fluid is fed to the constant displacement motor – which drives the generator - it will produce a gearing down effect, that is, the constant displacement hydraulic motor will spin at a reduced RPM compared to the variable displacement pump
When the engine speed is low, the swash-plate tends to move to a tilted position to maximise the stroke of the pistons, and hence output of the pump. When this fluid is fed to the constant displacement motor – which drives the generator - it will produce a gearing up effect, that is, the constant displacement hydraulic motor will spin at an increased RPM compared to the variable displacement pump.
The swash-plate constantly modulates between these two extremes to ensure the generator spins at a constant RPM whatever the engine RPM.
Regards, JetMech
CelticMech
Tue Nov 17, 2009 4:48 pm
Quoting JetMech (Reply 12):
Pretty much. A CSD consists of a variable displacement hydraulic pump supplying fluid (usually engine oil)........................
Ah yes...the days of learning about all this stuff from the basic licences now comes flooding back to me! I knew it was somewhere in my head!!!  Big grin
DocLightning
Wed Nov 18, 2009 6:52 am
Wow. Fascinating! Hardly an obvious solution to a problem. Now, what regulates the swashplate? Is it an act of physics, or is there a motor in the shaft that adjusts the angle to keep the output constant?
-Doc Lightning-
-Carl Sagan
rwessel
Wed Nov 18, 2009 8:24 am
Quoting DocLightning (Reply 14):
The swashplate is invariably moved hydraulically (after all, there's plenty of hydraulic pressure around). The regulation for that is more variable. In simple designs that are more concerned with constant output pressure, it can be simple feedback from the pressure on the output side pushing against a spring - if the output pressure drops, the swashplate angle is increased by the spring - if the output pressure rises, the hydraulics will push the swashplate towards flat. For better output flow control, you can attach a small constant displacement pump to the motor being driven, and use the pressure from that to move the swashplate (if the motor slows down, the pressure will be reduced). Or you can go highly electronic.
jetmech
Wed Nov 18, 2009 9:18 am
Quoting CelticMech (Reply 13):
I think one of the most interesting parts is how some of the pressurised fluid is bled off to lubricate the slipper foot. I think there is also a small amount of leakage between the piston and cylinder for lubrication purposes also. I presume both of these fluid streams make up the case drain fluid.
Quoting Rwessel (Reply 15):
As mentioned by Rwessel, the multi-piston axial pump with tilting swash plate is also the same configuration of device used for aircraft hydraulic pumps, in this case, the swash plate tilts to modulate pressure.
http://i94.photobucket.com/albums/l118/Jet-Mech/CSDpic.jpg
http://home.planet.nl/~brink494/axpp_v.htg/ppmpreg.jpg
With respect to the CSD, GE quotes that the N2 spool of the GE90 spins at 6610 RPM during ground idle, and 10.850 RPM at max power. It thus seems that the maximum speed range that needs to be accommodated by a CSD is a somewhat modest 2:1.
http://www.geae.com/education/engines101/
Regards, JetMech
[Edited 2009-11-18 01:38:31]
MD11Engineer
Wed Nov 18, 2009 12:07 pm
When you BAEC part 6 exams, did you also have to describe the internal workings of a CSD in detail?  Silly
Jan
LMP737
Wed Nov 18, 2009 5:01 pm
Quoting PGNCS (Reply 6):
The problem with the VSCF system on the MD-90 is that it was way too sensitive. The system would latch onto faults way to easily. When AA had the ex-Reno MD-90's it was common practice during the day to keep the APU running and not hook up ground power. Gate power had a tendency to fault the system, something you don't have to worry about with an MD-80.
The concept of a VSCF system is a good on. Unfortunately Douglas made a big mess. If they had done it right they would have sold a lot more MD-90's. Or if they had stuck an IDG on the aircraft instead. And put a new wing on it.
I hear Delta is getting some second hand MD-90's for their fleet. I'm not sure whether to pity or envy the A&P's over at Delta. Pity them because the 90 can be a handful, envy because it's almost guaranteed overtime.  Wink
MD11Engineer
Wed Nov 18, 2009 5:14 pm
Quoting LMP737 (Reply 18):
Back in the 1990s LH tried VSCF systems with their 737 classics. It was a big fail. The systems constantly went U/S. in the end they went back to conventional CSD / generator combinations.
Jan
NoWorries
Wed Nov 18, 2009 6:53 pm
Do any new-design commercial jets use these types of systems. The 787 doesn't, I don't thin
Quoting Tdscanuck (Reply 9):
Will any new designs still use these types of constant speed systems? I didn't think the A380 used them either.
ex52tech
Thu Nov 19, 2009 12:43 am
GE calls that gearbox inside the compressor case (frame) an inlet gearbox, it is the power takeoff for the main gearbox shaft. They were touchy to build, quite a few measurements and lash checks to accomplish. On a CF6 that shaft passageway through the case strut is also used to scavenge the oil from the N1 compressor rear bearing, and the N2 compressor front bearing, or the "B" sump.
"Saddest thing I ever witnessed....an airplane being scrapped"
tdscanuck
Thu Nov 19, 2009 3:26 am
In one of those lovely twists of fate, I found a lovely cross-section of a Trent 1000 that I was able to liberate from it's home this morning. It is an excellent overview of the major engine components and layout, and has a great view of the point inside where the power is extracted from the spools.
Here's the full view:
And here's a close-up of the bevel gears:
The right gear is the N3 spool, the left gear is the N2 spool. As you can see, there are actually separate output shafts from each spool that go into the gearbox just under the core, which sends it out to the main gearbox on the bottom of the fan case.
I have the full resolution gory detail scan (~200 MB as a TIFF) if anyone wants it. Send me a msg and we'll figure something out.
Tom.
ex52tech
Thu Nov 19, 2009 4:12 am
Quoting Tdscanuck (Reply 22):
They must be operating different portions of the main gearbox my guess would be the more loaded components would be powered by the N3, but it is just a guess. Does anyone know which spool is powering what components, and why they are operating from two different inputs?  scratchchin
LMP737
Thu Nov 19, 2009 4:56 pm
Quoting MD11Engineer (Reply 19):
I remember reading about the VSCF system being used on some 737 classics at one point. I did not know LH had it on theirs.
The 777 uses a VSCF system for backup power. Each engine has a Back Up Generator mounted on the lower r/h fan case, at least on the Trent. The two BUG's supply power to a backup power converter which converts the variable frequency to 115/400. From what I've seen it's a pretty reliable system. There was a brief period of time when the BUG's had a higher than normal fail rate. That problem seems to be rectified. Which is good because I had to change one in freezing drizzle about four years ago.
Quoting NoWorries (Reply 20):
I believe both the A380 and 787 use the VSCF system.
tdscanuck
Fri Nov 20, 2009 2:02 am
Quoting LMP737 (Reply 24):
A380 and 787 are not VSCF, they're VSVF. Variable speed-variable frequency.
Tom.
NoWorries
Fri Nov 20, 2009 12:55 pm
Quoting Tdscanuck (Reply 25):
As I undestand it then, this means that the AC generators are geared directly to the engine and their speed varies with engine speed. It's strictly solid-state electronics that tranform this varying output to whatever frequencies (or DC) and appropriate voltages are needed.
bri2k1
Fri Nov 20, 2009 2:37 pm
Quoting NoWorries (Reply 26):
There are some electrical components that don't care about the frequency, and IIRC there are both variable frequency and constant frequency buses. Isolating those systems which require constant frequency probably reduces the cost and complexity of the solid state systems. I can imagine things like anti-ice heaters don't care about frequency, and potentially lighting systems. Probably many others too.
Position and hold
tdscanuck
Sat Nov 21, 2009 4:17 am
Yes.
For systems that need it, yes. As Bri2k1 noted, many systems don't care so you don't have to bother feeding them constant frequency power.
Tom.
NoWorries
Sat Nov 21, 2009 1:37 pm
It looks like there could be quite a few trade-offs when considering CSD vs VSVF systems -- systems cost, installation, space, weight, maintenance cost, reliability, durability, efficiency, what else? To me it seems like VSVF would have the edge in most of these categories -- not sure about efficiency, possibly reliability (though VSVF seems overall so much simpler).
tdscanuck
Sat Nov 21, 2009 5:14 pm
Quoting NoWorries (Reply 29):
The big enabler for VF systems was good, reliable, high power-density solid-state electronics. The CSD is a mechanical nightmare and took a long time to get right. However, on the flip side, they sunk so much effort into getting it right that it stuck around for a long time once the reliability was there.
Now that it's easier and more reliable to do your power conditioning with solid-state, the pendulum swung to complexity on a power-handling side, dead simplicity on the mechanical side.
Tom.
Tristarsteve
Sat Nov 21, 2009 8:57 pm
The British Airways B734 fleet was also delivered with VSCF units. But due to unreliability they eventually gave up and converted them to conventional IDGs.
I think the problem was locating the electronics on the engine.
The B777 moved the electronics to the Electronic Bay. But it was still a hefty unit with a lot of cooling required and didn't produce a lot of power.
The A380 and B787 seem to have solved this with more modern electronics.
Users browsing this forum: 26point2, akiss20, harrisair, Kindredmsg, PlaneBoo and 12 guests
