Phen
Boeing 767 Doors
Mon Nov 16, 2009 10:59 pm
On watching this video http://www.youtube.com/watch?v=dijpw392JU0, I was surprised to hear that only the main left cabin door is motorized on QF 767s. Is this true for all Boeing 767s? How heavy are the other doors to lift manually?
[Edited 2009-11-16 15:03:51]
RE: Boeing 767 Doors
Mon Nov 16, 2009 11:34 pm
767 has slide up doors right? My guess is that there is a counterweight and they really aren't that "heavy". Mass of course still plays a role.
There are regs that state how difficult a door can be to open anyway.
Mir
Mon Nov 16, 2009 11:56 pm
Quoting Phen (Thread starter):
The doors are going to be pretty heavy, but they should have some sort of mechanical assist, like a set of springs that help pull the door up.
BTW, the guy in that video sounds like he should be recording movie trailers.  Smile
-Mir
474218
Tue Nov 17, 2009 12:02 am
The 767 (and DC-10, MD-11 and L-1011) passenger doors are electrically operated up and down, and work against a counter balance that is strong enough to open the door and deploy the slides in an emergency.
Mender
Tue Nov 17, 2009 12:53 am
I've not watched the video as it wouldn't open for some reason. However I've seen electrically operated doors L1 and L2 doors on the 767. The doors are counterbalanced so they are fairly easy to open with or without electrical assistance if they are correctly rigged.
Quoting 474218 (Reply 3):
If you open a door with the slide armed, the weight of the slide is effectivly detached from the door. Therefore the counterbalance pull the door upwards so strongly that you would not be able to hold it down/closed
474218
Tue Nov 17, 2009 1:09 am
Quoting Mender (Reply 4):
I have no idea what you are trying to say. But like I said, in normal operation, when the door is shut electrically it loads the counter balance so the door can be opened in an emergency and deploy the slide. When the door is opened the electric motor actually holds the door back against the counter balance.
n901wa
Tue Nov 17, 2009 1:31 am
Hi, I hope this can help. Yes on all the 767 I have worked on (Delta, Hawaiian, Qantas, Citybird, Aeroflot and Martin Air) the Foward left and sometimes the Left fwd 2 Main Cabin doors has a Electric Motor driven door. On Delta's 767 with 4 Main Cabin doors they are set up that way. On the 767 with 6 Main Cabin doors the 2 Fwd Main Cabin Doors on the Left side have Electric drives.
The doors all have a Counterbalance system but the other doors are all manual lift. When you lift the open handle the Counterbalance system opens the doors about half way up and you have to manualy have to lift them from there. When closing the Manual doors (1R 2L & R or 1R , 2R and 3L & R) you have to push the hold open latch and pull the door down till the latch system picks up the door to latch it closed. On the Electric driven doors the drives takes it down to the same point to pick up the latch system.
On the L1011 , MD-11 and DC10 all the main doors were driven all the way closed and open.
I little extra info, on the 767's with 3 Main Cabin doors and 2 Med sized doors aft of the Trailing edge are simple plug doors and only for emergencys like the overwing doors on other 767's. I hope this all makes sense  Smile Darren
tdscanuck
Tue Nov 17, 2009 1:41 am
Quoting 474218 (Reply 5):
Mender is noting that when you open a door with the slide armed, the slide is now attached to the door frame, not the door.
As a result, a counterweight that can lift the door open in normal configuration (door + slide) will give you a much higher net force when you're opening the door with the slide armed (weight of the door only).
Tom.
Mender
Tue Nov 17, 2009 1:57 am
I'm not disagreeing with you, I'm trying to make it a little clearer people to understand who haven't used a 767 door.
Clearly I've failed so I'll try to be even clearer.
With a door that HASN'T got electric assist the weight of the door is roughly balance by the counterbalance, in fact the door will gently rise up merely by unlatching it.
In fact, it is harder to close a 767 door than it is to open it because of the counterbalance is pulling the door up against you trying to close it. It's not a big upward pull but it's enough.
When the door is opened to deploy the slide, the slide detaches from the door almost straight away as it is attached to the floor by the girt bar. Because the door is now a lot lighter (without the slide) the counterbalance yanks the door up into the ceiling with such force that you wouldn't be able to hold onto it. If you've ever tried to close a door after you've deployed a slide you'll understand what I'm saying.
None of the above changes if the door has electric assist. As you say the electric motor holds the door back against the counter balance but only if you operate the switch. If you don't operate the switch it will behave like a door that hasn't got the electric assist fitted.
Hopefully this hleps
474218
Tue Nov 17, 2009 2:18 am
Quoting Mender (Reply 8):
Yes it helps and is basically what I said.
Max777geek
Tue Nov 17, 2009 9:27 am
The doors have emergency slides which in case of evacuation must be deployed so people can get out of the plane quickly without any other ways to reach the ground. The slide, normally packed, works like an emergency lifeboat and is inflated. When the airplane leave the gate (or the ground ladder goes away) the slide is "armed" it means that is phisically attached to the plane, not sure how this goes on with 767, but on some smaller planes you might have notice a metal bar which is tied to the airplane floor from a door compartment, or on some more moderns liners like airbus, it might be an handle to move, etc. In case the slide is "armed" it does not move anymore with the door, however it gets opened. So rising it manually in the 767 case, will result in much less weight to rise with the door. He ment you can't hold it manually down closed, if just - Ill assume - unlocked, with detached slide. Enough said ?
Phen
Wed Nov 18, 2009 12:18 am
Thanks for all the replies guys!
474218
Wed Nov 18, 2009 1:57 am
Quoting Max777geek (Reply 10):
Now I am really confused now.
Aren't the slide packs on the 767 passenger doors mounted on the doors?
If the slide packs are mounted on the doors they should work as they do on the other aircraft that have doors that open into the cabin overhead. So that: When the door is un-armed and the door is operated the door and slide pack stow in the overhead. However, when the door is shut and armed the girt bar on the bottom of the slide pack attaches to the latch/unlatch mechanism at the door aperture. When the door is opened in an emergency it slides up into the overhead, the girt bar pulls the slide from the door and it deploys as it falls out the door aperture.
tdscanuck
Wed Nov 18, 2009 3:03 am
Quoting 474218 (Reply 12):
Yes.
The slide is mounted to the bottom of the door. When you arm the door, the girt bar on the slide engages the lower door sill. If you open the door while armed (i.e. the girt bar is engaged) the slide is pulled from it's compartment as soon as the door starts to go up. At that point, the weight of the slide is now sitting on the door sill, so it's weight isn't felt by the door.
If you open the door unarmed (girt bar disengaged), the slide goes up with the door, so the lift system is lifting the door plus the slide.
Tom.
WNCrew
Wed Nov 18, 2009 3:36 am
Here's a decent video of a deployment. The 1R cabin door is opened and closed several times DISARMED and then it is ARMED and opened. You can see when it's opened and ARMED the door goes up and since the slide is attached to the door sill the slide pack is pulled out of the pack and falls out and inflates.
http://www.youtube.com/watch?v=ofkk_9T1OPU
474218
Wed Nov 18, 2009 4:13 am
Quoting Tdscanuck (Reply 13):
Yes.
Thanks Tom.
The 767 slide system is just like the DC-10/MD-11 and the L-1011. But the way people were describing it made no sense to me.
MD11Engineer
Wed Nov 18, 2009 2:01 pm
Not on the DC-10 / MD-11. There there exists an air motor powered by a reservoir of compressed nitrogen to open the door in emergencies if the normal electric system fails. If the backup system fails as well, you´ll need two strong men to lift up the door manually.
On the 767 there exists a huge spring in the ceiling, which carries the load.
Jan
WNCrew
Wed Nov 18, 2009 4:21 pm
Users browsing this forum: No registered users and 31 guests
