yyzala
Engines Under The Wing And On The Tail At Once
Thu Nov 19, 2009 1:35 am
I am wondering if there is any advantage in having a 4-engined airplane with an engine hanging on each main wing and two more engines in the back (MD80 style)? Obviously each design has its advantages and disadvantages but would the combination of both yield better results in terms of fuel efficiency, field performance, etc?
Spacepope
RE: Engines Under The Wing And On The Tail At Once
Thu Nov 19, 2009 1:52 am
The closest thing I could think of that has been built was the Martin XB-51. Photo of a model below.
http://www.scaleworkshop.com/workshop/images/xb51ga_3.jpg
Though the front engines were fuselage mounted, they were kinda under the wing too.
tdscanuck
Thu Nov 19, 2009 2:01 am
Quoting YYZALA (Thread starter):
The problem I forsee is that any modern airliner that needs 4 engines is big, which means large high-bypass fans. Mounting those on the tail would be a lot trickier than doing it with relatively slim engines like the MD-80.
Tom.
yyzala
Thu Nov 19, 2009 2:44 am
Quoting Tdscanuck (Reply 2):
Surely 2 engines of y thrust (big) in the front and 2 engines of x thrust (small) on the tail would solve this problem?
vikkyvik
Thu Nov 19, 2009 2:55 am
Quoting YYZALA (Reply 3):
Then you have twice as many parts, at least, because you have 2 different engines. More training for people to learn both engines, more maintenance, more spare parts to stock, etc.
Also, you'd have to put the engines on the wing rather far out to avoid having the tail-mounted engines breathing in exhaust from the wing-mounted engines (which is not good). Moving the engines farther out on the wing requires more structure, and probably longer landing gear as well, to achieve acceptable bank angles on the ground without scraping an engine.
dw747400
Thu Nov 19, 2009 3:12 am
The cost of maintaining two types of engines on one aircraft, in addition to the inherent inefficiencies generally associated with smaller, low-bypass engines, would make this a non-starter from an economic standpoint.
Boeing evaluated a "thrusting APU" concept for the 777, where a small tail mounted engine would supplement two larger wing-mounted engines on takeoff. Because of the weight and maintenance issues associated with putting a 30,000 pound thrust engine in the tail of a completely different design than the main engines, Boeing determined two larger wing mounted engines were the best solution. I expect any analysis of your concept would yield the same results.
CFI--Certfied Freakin Idiot
Thu Nov 19, 2009 6:00 am
Quoting Dw747400 (Reply 5):
The B-36 was probably a non-starter economically in many ways, but it illustrates the problem.  Wink
oly720man
Thu Nov 19, 2009 10:22 am
It was done when the VC10 was used as the RB-211 testbed, though an RB-211 is quite small in comparison to the more recent high bypass engines.
Some interesting photos (and a hair raising story) here...
http://www.vc10.net/History/Individual/XR809.html
Goldenshield
Thu Nov 19, 2009 2:05 pm
Quoting Vikkyvik (Reply 4):
Another problem is that if you lose the two big engines, the two small ones will only get you as far as the site of the crash.
bri2k1
Thu Nov 19, 2009 2:17 pm
And, the more engines, the more chances for an engine to break. One good reason to have two big engines instead of 2+n smaller ones.
Position and hold
Northwest727
Thu Nov 19, 2009 2:31 pm
Just a little trivia...the Boeing 367-80 (the 707 prototype) had a JT8D attached to the tail with a "dog-leg" pipe to route exhaust gasses over the horizontal stabilizer. This was done back in the late '50s early '60s, when the JT8D was a new engine, and needed to be tested for the 727, which it would power.
I have a book with photos of it, but can't seem to find it.
Dalmd88
Thu Nov 19, 2009 2:48 pm
Hanging a large diameter fan on the tail isn't a problem. Just look at the MD90. Those engines are about the same size as what is on the A340. The problem lies with the structure needed. By putting engines on the wing and the tail both areas need more structure.
thebatman
Thu Nov 19, 2009 4:58 pm
Here, I believe I've found a picture that basically describes what you're looking for. Of course it's totally fake! I thought it was an interesting photo...  Smile
http://i719.photobucket.com/albums/ww199/xxdarkknight/4engine_CRJ.jpg
Aircraft mechanics - because pilots need heroes too!
A346Dude
Thu Nov 19, 2009 5:23 pm
Well then why not add the 2 small engines together and make a tri-jet? Oh wait, those are uneconomic too...
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
SNAFlyboy
Thu Nov 19, 2009 6:20 pm
Quoting Thebatman (Reply 12):
Can anybody say...ground clearance?
 scared
~SNAFlyboy
yyzala
Thu Nov 19, 2009 7:04 pm
Everyone is posting a lot of negatives, but are there any advantages with such design?
nomadd22
Thu Nov 19, 2009 7:34 pm
Quoting YYZALA (Reply 15):
The mechanics who maintain them would all be able to afford new swimming pools.
Anon
aerdingus
Thu Nov 19, 2009 11:51 pm
Quoting Oly720man (Reply 7):
Very interesting! The size of the RB211 to the whoel VC10 itself is something else, I always thought the old VC was big, but damn, that engine....
2017: DUB LTN DUB FR B737
Orbis MD10
Booked: DUB STN GRO STN DUB FR B737
DocLightning
Fri Nov 20, 2009 12:05 am
Quoting SNAFlyboy (Reply 14):
That's why it's not on the ground, silly!  duck
Tail-mounted engines are good for two reasons:
1) they raise the engines off the ground so that the aircraft can land on semi-prepared fields where FOD is a risk. This was more of an issue back in the days when the first tail-mounted planes were designed. The DC-9 and 727 were examples of planes that might have used a semi-prepared field when they were first introduced, but no aircraft of that size would ever use such a field today.
2) They allow the aircraft to sit closer to the ground, which simplifies loading, MX, etc.
Most modern commercial aircraft do not need either consideration, so major jet transports that have been introduced in the last decade or so have under-wing engines. Private jets may need either of the above advantages, so I expect that they will continue to have tail-mounted engines for some time.
-Doc Lightning-
-Carl Sagan
Viscount724
Fri Nov 20, 2009 12:34 am
Quoting DocLightning (Reply 18):
They also significantly increase the aircraft's overall length due to the T-tail design common on most rear-engine designs. That may create some airport gate space issues. For example, the overall length of the shortest DC-9-10 is 6 feet longer than the 737-200, although the DC-9-10 has fewer rows of seats. The 727-200 is also a few inches longer than the longest 707-320.
Aircraft with wing-mounted engines make more effective use of the fuselage length to carry passengers.
tdscanuck
Fri Nov 20, 2009 1:58 am
There are still some 737-200's with gravel kits frequenting semi-prepared fields in odd corners of the earth...however, it's not common and, as far as I know, nobody caters to that market with newbuilds anymore.
Tom.
DocLightning
Fri Nov 20, 2009 6:03 am
Quoting Viscount724 (Reply 19):
I said they were good for two reasons. There are a lot more reasons why they aren't good. That's one. Worse aerodynamics are another. There's also more difficulty in accessing them for mx.
That's why even the new RJ's have wing-mounted engines.
-Doc Lightning-
-Carl Sagan
Zkpilot
Fri Nov 20, 2009 4:53 pm
 checkmark  This is what I was also thinking re: the engines breathing in jetwash. Engines like to breath in cold air and are much more efficient when they do so.
57 types. 38 countries. 24 airlines.
cloudyapple
Tue Nov 24, 2009 9:30 am
Quoting Zkpilot (Reply 22):
And if you noticed, aircraft with tail mounted engines usually come with wings that are mounted lower on the fuselage. MD80/90, CRJs etc. Not sure if this is to provide a clean laminar flow into the engine by avoiding any turbulence coming off the trailing edge of the wing or to save structure/weight or simply you don't need the ground clearance.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
Users browsing this forum: BoeingVista and 2 guests
