ZKNBS
Information Needed On Delta 737-700's
Thu Dec 03, 2009 4:38 pm
Can anyone tell me the MTOW of Delta's 737-700's as well as the specific engine type on their 700 fleet. I am having difficulty finding this information on the internet and my copy of JP Fleets is out of date.
dispatchguy
RE: Information Needed On Delta 737-700's
Thu Dec 03, 2009 6:31 pm
CFM56-7B26
Config - F12/Y112
All weights in lbs...
MTXW - 155000
MTOW - 154500
MLDW - 129200
MZFW - 121700
Average OEW - around 88000 lbs or so
Nobody screws you better than an airline job!
ZKNBS
Fri Dec 04, 2009 11:21 pm
Thanks for the assistance!
AA737-823
Wed Dec 09, 2009 2:59 pm
Wow.... why did they opt for -26's??? That's a lot more power than most -700s out there.
The ones I've dealt with have just had the -22's!!!
liedetectors
Wed Dec 09, 2009 5:42 pm
Delta opted for the high thrust CFM56s because they planned to use the aircraft for high altitude and/or South American destinations where good takeoff performance is a necessity.
If it was said by us, then it must be true.
dispatchguy
Thu Dec 10, 2009 1:29 am
Tegucigalpa, Honduras...
This aircraft has something I have never before seen in an AFM, a minimum weight to be able to use maximum thrust. If you are super light weight, then you HAVE to operate the airplane at a reduced thrust.
Some of the other -700s might have the same restriction in their AFM, I just have never seen it before.
[Edited 2009-12-09 17:38:37 by dispatchguy]
roseflyer
Thu Dec 10, 2009 2:40 am
Quoting AA737-823 (Reply 3):
The airplane was intended for short field or hot & high operations. Airports like those in Latin America were the intention of the airplane. Also they are flying them to shorter field airports like SNA.
DL got the 73G exclusively for performance. They were the launch customer for carbon brakes on the 737 so that they could save 500lbs in order to improve performance even more. The fleet fills a small niche at the airline, so it will never operate that many of them. People thought they were for thinner routes, but in reality they are a higher performance plane for markets where the 757 does not work.
Alitalia744
Sun Jan 10, 2010 3:11 am
Quick question, are the engines on the -832s CFM56-7B26 or CFM56-7B27s?
Some see lines, others see between the lines.
dispatchguy
Sun Jan 10, 2010 9:52 am
Quoting Alitalia744 (Reply 7):
They are the 7B26s
Alitalia744
Sun Jan 10, 2010 10:21 pm
Quoting Dispatchguy (Reply 8):
They are the 7B26s
Thanks dispatch. How are things in the OCC?
Transpac787
Mon Jan 11, 2010 12:45 am
As far as I know, AA is the only North American carrier that opted for the CFM56-7B27. For the same reason as DL with the 73G, AA wanted max performance out of their 738's for the flights to South America out of MIA.
dispatchguy
Mon Jan 11, 2010 2:13 am
Quoting Alitalia744 (Reply 9):
I left the OCC back in June, I love the new facility, but I wasnt around to see what it looks like with all the NWA bodies in there...
Users browsing this forum: Armadillo1, CanadianNorth, CFI4LIFE, cheeken, gloom, qcpilotxf, tjwgrr and 41 guests
