A342
Fuel Injection Pressure In Gas Turbine Engines
Mon Dec 07, 2009 11:34 pm
Somehow this issue got me thinking: What are typical pressures for jet fuel injected into the combustion chamber of jet or turoprop engines?
I'm asking because I'd like to know how the injection pressure compares to that of modern diesel engines, which is up to 2000bar / 29,000psi.
It would be great if somebody could help.
A342
Exceptions confirm the rule.
Fly2HMO
RE: Fuel Injection Pressure In Gas Turbine Engines
Tue Dec 08, 2009 12:11 am
Quoting A342 (Thread starter):
According to my Rolls Royce book, the typical pressure inside a combustion chamber is around 100 to 200 psi. So theoretically you only need to overcome that pressure to be able to inject the fuel.
BUT the book also mentions that, specially in older types of injectors, pressures of up to 6000psi would be required for proper atomization of the fuel.
tdscanuck
Tue Dec 08, 2009 5:59 am
1000-1500 psi is in my head as the typical output from the high-pressure fuel pump, but I don't have any documentation handy to back that up. As FLY2HMO noted, it's got to be meaningfully higher than the combustor pressure.
I don't think there's any reason to run that high on a jet engine...they don't have nearly the same atomization issues that a Diesel does.
Tom.
jetmech
Tue Dec 08, 2009 6:26 am
Quoting Tdscanuck (Reply 2):
I suppose another reason diesel engine have such a high injection pressure is due to the finite amount of time available in which to inject the fuel. Obviously, such a requirement does not occur with a jet engine.
Regards, JetMech
Fly2HMO
Tue Dec 08, 2009 4:15 pm
Quoting JetMech (Reply 3):
Not to mention Diesels produce much much more compression.
A342
Tue Dec 08, 2009 4:37 pm
Thanks for your feedback!
Well, diesels also started out at much lower pressures, the figures I mentioned are for engines less than ~10 years old.
What really helped diesels in terms of fuel consumption was direct injection, not so much extremely high pressures. But the main advantage is emissions. High pressures DRASTICALLY reduced the amount of PM emissions, and they also enabled CO emissions to drop a bit.
So gas turbine engines have a lot to gain in terms of emissions, especially since catalytic converters and PM filters are obviously not an option in airborne applications.
True, there is no such strict requirement. However, having the fuel ignite more quickly can't hurt, since it allows you to better control the place where the fuel is burned (in a gas turbine, the hot air flow carries the fuel molecules towards the exhaust during combustion). I admit I have no clue as to how important the added precision would be in terms of combustor design, but I don't think it is insignificant either.
I might add that I do indeed realize how difficult it would be to design, certify, produce and operate a 29,000psi injection pump that delivers the necessary fuel quantities for a large turbofan.
A342
DBCC
Tue Dec 08, 2009 5:48 pm
Sorry, 2'000 bar or 29'000 psi is not used in fuel injection.
Most high pressure hydraulic equipment has a limit of 640 bar (64'000 kpa / 9'282 psi). 6mm x 2 mm wall seamless hydraulic line tubing is rated at 640 bar working pressure with a factor of safety of 2.0.
For fuel injectors, comprise of single-seam welded tubing, mostly with a maximum working pressure of 100 bar.
Have a good search on the net, and you will find most fuel injection systems run at 25-40 PSI (1.7 to 2.7 bar)
At 600 bar, the stream coming out the end of a pipe can cut 50mm (2") solid steel with no problem. Imagine what 2'000 bar could do, if anyone could make equipment that could run at that pressure.
speedracer1407
Tue Dec 08, 2009 6:52 pm
Quoting DBCC (Reply 6):
I think that if you "have a good search on the net," you'll find that common rail fuel injection systems used in modern turbodiesel engines (as A342 states) do in fact operate in excess of 1500 bar, up to 2000, and have for years.
VW group diesels are in the 1600-1800 bar range. A very simple searched pulled up this Wikipedia list of VW engines. Yeah, it's Wiki, but it may give you an idea.
http://en.wikipedia.org/wiki/List_of_Volkswagen_Group_diesel_engines
bri2k1
Tue Dec 08, 2009 7:34 pm
Here's a data sheet for one such injector:
http://delphi.com/manufacturers/cv/p...1-diesel-electronic-unit-injector/
These systems use a much lower pressure fuel delivery system to each injector, and typically use a camshaft-driven plunger to pressurize a tiny amount of fuel to the atomization pressure (2,000bar or thereabouts). This is vastly different from the huge flow rates required in a hydraulic system, or those used in a turbofan engine for that matter.
Position and hold
A342
Tue Dec 08, 2009 8:05 pm
Quoting Bri2k1 (Reply 8):
In the case of a unit injector, that's right. However, common rail systems do indeed use one central pump to deliver highly pressurized fuel to the injector.
Still, as you mention, flow rates are very low in comparison to the fuel requirements of large turbofans.
jetmech
Wed Dec 09, 2009 1:49 am
Quoting FLY2HMO (Reply 4):
I wonder what the ratio would be? Reciprocating engines base their compression process on a mechanically dependant compression ratio, whereas gas turbines base their compression process on a pressure ratio. I would be curious to see what the resulting pressure ratio was at the end of the compression stroke of a diesel engine   .
GE claims on overall pressure ratio of 42:1 for the GE90-115B at max power. According to Wikipedia, this is "equivalent" to a compression ratio of just over 15:1, which is apparently a typical compression ratio for a direct injection diesel.
http://en.wikipedia.org/wiki/Compression_ratio
http://www.geae.com/engines/commercial/ge90/ge90-115b.html
Quoting A342 (Reply 5):
With a diesel, you want the fuel to ignite as soon as possible to reduce the severity of diesel knock. However, I think this is also dependent on the temperature at the end of the compression stroke as well as the fuel injection pressure.
No doubt. With diesel injectors however, I suspect that one wants to quickly "spread" the fuel out to promote atomisation, as opposed to maintaining a focussed stream.
Regards, JetMech
[Edited 2009-12-08 18:01:13]
njxc500
Wed Dec 09, 2009 3:19 am
Here's a MFR link that states 29,000 psi
http://www.everytime.cummins.com/eve...pplications/mining/qsk23_mine.page
tdscanuck
Wed Dec 09, 2009 5:51 am
High pressure drops particulates and CO in Diesel's because it atomizes the fuel more, ensuring faster and more complete combustion before the mixture gets frozen by the temperature drop during the expansion stroke. Gas turbines don't have that problem...they hold full pressure all the way through the combustor.
It wouldn't be easy, but it's not impossible either. The pump from a big water-jet cutter could probably do the job. In my former profession, we had pumps capable of 22,000 psi at several *barrels* per minute (equivalent to well over 1 million pounds per hour, more than any jet engine ever conceived). These things are, obviously, really big and heavy but it's old technology.
Quoting JetMech (Reply 10):
If you approximate it as adiabatic compression with an ideal gas, the pressure ratio is about the compression ratio to the power of 1.4.
Tom.
LTC8K6
Modern Gasoline Direct Injection engines such as Ford's EcoBoost run over 2,000psi fuel pressures.
jarheadk5
Wed Dec 09, 2009 6:38 am
The GE T64 turboshaft on the H-53 helicopter runs fuel pressures in excess of 400psi.
Cleared to Contact
jetmech
Thu Dec 10, 2009 2:00 am
Quoting Tdscanuck (Reply 12):
That's right on the money! 15^1.4 = 44. If we take away a small percentage to account for losses we get 42 .
Regards, JetMech
[Edited 2009-12-09 18:02:05]
MarkC
Thu Dec 10, 2009 1:10 pm
It is about 600 psi. PW modern engines.
A342
Thu Dec 10, 2009 9:18 pm
Quoting FLY2HMO (Reply 1):
Quoting JarheadK5 (Reply 14):
Quoting MarkC (Reply 16):
Interesting, it seems the numbers vary widely.
Then the obvious question is: What enabled the reduction of PM and CO emissions in modern jet engines? You rarely see much visible smoke coming out of modern engines, like it was common with turbojets and early turbofans.
Yep, that would be the main problem.
A342
tdscanuck
Fri Dec 11, 2009 6:18 am
Quoting A342 (Reply 17):
As far as I know, better combustor designs and higher temperatures.
Tom.
Users browsing this forum: Dalmd88, Google [Bot] and 16 guests
