September11
Hole On A-300 Engine - How?
Wed Dec 09, 2009 5:06 pm
A hole is seen on the engine in the picture below.
Photo © Paulo Carvalho
What happened? Did the engine turbine blew up?
Airliners.net of the Future
Fly2HMO
RE: Hole On A-300 Engine - How?
Wed Dec 09, 2009 8:54 pm
Hmmm, it does look at about the right spot for the LP turbine disc to be found, though im surprised that, if it really was only one blade, the whole thing didn't have a catastrofic failure due to imbalance.
tb727
Thu Dec 10, 2009 12:16 am
Probably threw a piston.  Smile
fr8mech
Thu Dec 10, 2009 12:54 am
Isn't that where the 'king latch' lives on the cowl?
I'd say there is a 99.99% probabilty that this is NOT a turbine failure. One blade and the whole engine would've come apart.
FlyingColours
Thu Dec 10, 2009 1:17 am
According to the AAIB (UK Air Accidents Investigation Branch) it was...
"The origin of the engine failure was established to be separation of an HPT Stage 2 rotor blade, which had broken off just above the blade platform. The fracture had propagated from the edge of a 0.25" deep notch, which had been worn in the blade leading edge. Similar notches were found on all of the Stage 2 blades. Several HPT Stage 2 nozzle segments around the 12 o'clock position were found to have large cracks in the aerofoil to outer platform fillet. The cracking had weakened the cantilevered nozzle segments and allowed them to deform rearwards under aerodynamic loading and contact the leading edges of the Stage 2 blades."
The full report can be found here,
http://www.aaib.gov.uk/publications/...1___airbus_a300b4_605r__g_mons.cfm
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
avt007
Thu Dec 10, 2009 3:49 am
The loss of a blade, either compressor or turbine, will not cause a catastrophic failure. On the RR Speys, we had to check regularly to see if any LP Turbine blades were missing.
tdscanuck
Thu Dec 10, 2009 4:11 am
Quoting Fr8Mech (Reply 3):
I think you're mixing discs and blades. A blade loss isn't all that uncommon and, aside from damaging neighboring blades, the engine generally survives. A turbine disc failure, on the other hand, is very probably going to take out the engine.
Tom.
fr8mech
Thu Dec 10, 2009 11:22 pm
Quoting Tdscanuck (Reply 6):
No, not really. Just never seen or heard of a turbine blade, or cluster of blades, being liberated, radially, without trashing the engine. First time for everything.
Fri Dec 11, 2009 8:53 am
Interesting.
Any more pics of this particular Incident from another angle.
regds
MEL.
ex52tech
Tue Dec 15, 2009 5:32 am
Quoting Fr8Mech (Reply 7):
Found a blade missing from the 4th stage of the LP on a CF-6-50C2 one night, no one wrote anything up , no vibration, no anything. But an uncontained failure like that usually is noticed in the cockpit, high EGT or vibration ect...If that was an HP blade, I find it hard to believe that they didn't notice, and performance didn't fall off.
"Saddest thing I ever witnessed....an airplane being scrapped"
Users browsing this forum: Bing [Bot], GalaxyFlyer, LH707330, RetiredWeasel and 3 guests
