speedbird128
ADS-B
Mon Dec 21, 2009 5:49 pm
I am an ATC, and i know all about the CPDLC side of things.
However, I would like to find out about the ADS-B side of things.
I know that a lot of info is available through ADS-B and Mode S.
Where is the data like Flight number etc inputed? The registration of the aircraft etc?
SA, for instance, have a A343 that they leased to 9W, and it still reports its VT-JWA registration. Is this registration stored onboard against the Mode-S address?
Thanks for any help!!
BAW128
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
Fly2HMO
RE: ADS-B
Tue Dec 22, 2009 12:09 am
Quoting Speedbird128 (Thread starter):
I believe they do it through the flight management computer. Even in some planes without ADS-B the FMS will ask for the flight number.
IIRC yes as well but only MX people can change the ICAO Mode S address.
I have plenty of experience with ADS-B but mostly limited to GA operations.
speedbird128
RE: ADS-B
Tue Dec 22, 2009 7:25 am
Thanks for the information...
I am familiar with the FMC / MCDU, and I suspected this is where the flight number was entered.
I imagined that the Mode S address would have to be hard-programmed. I wasn't sure about the registration. Looking at the last couple of days ADS logs, I see there are some interesting errors.
Is the ADS-B output something that can be turned on and off?
On the same aeroplane, ADS-B data isn't always transmitted...
beakerltn
RE: ADS-B
Tue Dec 22, 2009 8:34 am
All aircraft have a unique 20-bit address. This address in then decoded on the ground (or by anything containing the look up table) to give the Registration, so it's not smomething that's entered in. - The flight number however is entered in the flight management computer.
Beaker.
300/319/320/321/330/732/733/734/73G/738/744/772/77W/146/EMB135/EMB145
RE: ADS-B
Tue Dec 22, 2009 9:28 am
On the Airbus, it is on the INIT page on the FMGEC.
As far as I am aware, the registration is not transmitted. The extended mode s transponder 24 bit address is transmitted on the long and short squitters.
The first 4 to 14 bits define the state of registry, this should change if the aircraft changes from the South African to Indian registry, but the aircraft maybe operating under its original registration while under lease. Your ATC system then should lookup the 24 bit address to get the registration.
In the long squitter, the aircraft identification is broadcast every 5 to 10 seconds, but my understanding of that does not include the registration, just the ICAO wake category and the ICAO callsign (useful for the air to air ADS-B).
Not that I am aware of, have you checked to see if that is the address still on the flight plan ?
Quoting Speedbird128 (Reply 2):
Yes, it can be turned off, just like a transponder.
beakerltn
RE: ADS-B
Tue Dec 22, 2009 10:00 am
Quoting Zeke (Reply 4):
But on a commercial transponder, can you turn off just the ADSB transmission, but keep mode S on? - I think this was probably what the OP was asking?
(and sorry, I stand corrected, it is a 24bit add, not 20 bit)
RE: ADS-B
Tue Dec 22, 2009 10:12 am
Quoting BeakerLTN (Reply 5):
Yes, on the Airbus that is FANS equipped, under the ATC menu/Connection Status, the pilot can toggle ADS ON or ADS OFF.
Some people think 20 bit as that is what is the unique part, e.g. in the USA, the first 4 bits are common (FAA registered), the remaining 20 bits is the unique part of the address. Other countries have different number of bits (up to the fist 14) to make up the state of registry, e.g. Austria, the first 9 bits are common, the remaining 15 bits are unique on the Austrian registry.
speedbird128
RE: ADS-B
Tue Dec 22, 2009 3:22 pm
Thanks all, especially Zeke!
Having researched the Mode S and ADS-B bit a little more, I am getting a better understanding.
Currently our Radar System only uses Mode C, and ADS/CPDLC - although I am certain it's Mode S capable, but due to the lack of Mode S equipped planes, it's currently turned off.
It's more for my personal ADS receiver which i'm using to research for my upcoming new job which will be in Mode S/ADS territory.
Regarding the SAA A343 question, it actually applies to two of their A343's they leased out to Jet.
ZS-SXE for instance is transmitting 80018B as it's Mode S code. This is the Indian one that should have been re-set to the original 00B1F3.
I have gathered that it's my software that looks up the Mode S code, and then gets the reg and type of the aircraft.
Thanks guys!
RE: ADS-B
Tue Dec 22, 2009 7:04 pm
Quoting Speedbird128 (Reply 7):
I take it you mean ADS-C/CPDLC over SAT/VHF/HF datalinks ?
Both of those seem possible to me.
India should start with 1000 00 --- --- -- ----------, they have 262,144 possible unique registrations. 80018B (1000 00 000 000 00 0110001011) is within their range.
South Africa should start with 0000 00 001 --- -- ---------- giving them 32768 possible unique registrations. 00B1F3 (0000 00 001 011 00 0111110011) is within their range.
My guess is someone just did not covert the transponder over during the South African certification of airworthiness process.
speedbird128
RE: ADS-B
Tue Dec 22, 2009 9:23 pm
Quoting Zeke (Reply 8):
Purely SAT based as far as i know from the system architecture of the Eurocat X system.
The Mode-C I referred to was the SSR mode, we don't use Mode S.
It was originally correct upon delivery, but was changed to the Indian Mode-S code when it went to Jet, and when returned from lease, was not reprogrammed to the South African code...
Fly2HMO
RE: ADS-B
Tue Dec 22, 2009 9:30 pm
Quoting Speedbird128 (Reply 9):
I'm confused, at least in the states, every part 121 (airline) or part 135 (charter) aircraft MUST have mode S transponders, as it is a requirement for TCAS II.
Are you saying your facilities only pick up Tx signals as if they were only Mode C?
speedbird128
RE: ADS-B
Tue Dec 22, 2009 9:48 pm
Sorry i confused the issue i think.
There is no requirement in South Africa for Mode S transponders *as far as I am aware*. We have a lot of ex-1st world planes here now (a-la MD82 etc), and back in their hayday they had only mode C. And as there is no requirement for Mode S, they haven't been retrofitted.
The radar heads we have pick up both Mode S and Mode C. However, *our radar displays*, only give us Mode C data on our screens. ie the 4 digit squawk code, and the flight level.
Fly2HMO
RE: ADS-B
Tue Dec 22, 2009 10:37 pm
Quoting Speedbird128 (Reply 11):
Ah gotcha. Makes sense now.
Scooter01
RE: ADS-B
Wed Dec 23, 2009 11:44 pm
Ha-ha!
Check who is out for a test-spin right now -heading due north over the Baltic Sea
http://www.flightradar24.com/
Scooter01
Fly2HMO
RE: ADS-B
Thu Dec 24, 2009 12:41 am
Quoting Scooter01 (Reply 13):
Uhm, who?  Confused
Scooter01
RE: ADS-B
Thu Dec 24, 2009 2:24 pm
Quoting FLY2HMO (Reply 14):
Uhm, who?
Callsign was Merry X , altitude was 50000ft, speed 10000knots, so no wonder you guys missed it.
Here's a screenshot made of the track a few minutes after my first post:
http://i50.tinypic.com/15qoyzn.jpg
Merry Christmas everyone!
Scooter01
[Edited 2009-12-24 06:35:42]
Users browsing this forum: dopdoz, Horstroad, Yahoo [Bot] and 1 guest
