Faro
Are Selcal Codes Airframe-specific?
Fri Dec 25, 2009 7:39 pm
From aircraft registration sites, the impression one gets is that these codes are specific to an airframe and do not change from one operator to the another. Is this the case, and why?
Faro
The chalice not my son
BMI727
RE: Are Selcal Codes Airframe-specific?
Fri Dec 25, 2009 9:14 pm
Quoting Faro (Thread starter):
According to this Wikipedia article
http://en.wikipedia.org/wiki/SELCAL
That does seem to be the case. Having duplicates has become an issue and crews now verify that the message is intended for them.
Mir
Fri Dec 25, 2009 9:55 pm
It is the case, though there are now duplicate codes out there (though I think they try to separate the duplicates geographically). As for why, I'm not really sure. It shouldn't be too hard to have ATC assign the codes when necessary.
Having duplicate codes is not a big deal - even if you do have two aircraft with the same SELCAL code flying in the same airspace, all that will happen is you'll have both aircraft check in when you send a call out. You give the message to the one you wanted to, and just tell the other "sorry, wrong number".
-Mir
SPREE34
Sun Dec 27, 2009 4:32 pm
Quoting Mir (Reply 2):
ATC does not assign SELCAL codes. ATC has nothing to do with SELCAL at all.
ARINC, and Company radio use SELCAL.
I don't understand everything I don't know about this.
