Evan767
Crew Rotation On Long Flights And Layovers
Tue Dec 29, 2009 1:21 am
I have a couple of questions as to how crew rotation works on long flights. Also, I'm curious to the nature of layovers for F/A's and pilots.
Here are a few different scenarios I'd like someone to help clean up for me. All flights are hypothetical Delta Air Lines flights since I am most familiar with that airline:
1. ATL-LAX 77L
Even though this is a 777, are there anymore pilots than a captain and first officer since this is only a 4.5 hour flight?
2. ATL-BCN 763ER
One captain and two first officers? All three are in the cockpit for take-off and landing right? When do they switch?
3. LAX-SYD 77L
I'm certain that on this flight there are two captains and two first officers. What's the crew rotation like on this 14 hour flight?
Finally, what are the layovers like for the pilots? I understand all crew stays in the same hotel, but do they share bedrooms? Are there two pilots in two twin beds? Does each crew member get his or her own room?
Thanks to anyone who may be able to clear up at least some of this mystery to me.
AirstairFear
RE: Crew Rotation On Long Flights And Layovers
Tue Dec 29, 2009 1:23 am
Crew members do not share rooms. Unless they choose to after they get there.  Big grin
Evan767
Tue Dec 29, 2009 1:42 am
Quoting AirstairFear (Reply 1):
So lets say you have 4 pilots and 12 flight attendants. The airline books 16 rooms for each crew member?
thegreatchecko
Tue Dec 29, 2009 1:48 am
Quoting Evan767 (Reply 2):
Is there any other way?
I sure as hell don't want to be sharing a bedroom with a person I just spent the entire day locked in a cockpit. Also, what would one do in the event the pilot and copilot are opposite genders?
It's just a cost of doing business.  Smile
"A pilot's plane she is. She will love you if you deserve it, and try to kill you if you don't...She is the Mighty Q400"
TWFirst
Yes. But the airline pays steeply discounted rates at the contracted hotel.
An unexamined life isn't worth living.
Flyer732
Tue Dec 29, 2009 1:50 am
Yep. Each crew member has their own individual rooms.
As far as your other questions go, I'll answer it as its done at my airline. On flights over 8 hours we have 3 pilots, usually this is 1 captain and 2 first officers, though if we are short on first officers its not out of the question to have 2 captains or even 3 captains.
The break times are usually decided between the pilots, and the lengths are dictated by the length of the flight, or if one of the pilots opts not to take a break, that can add time for the other pilots.
On a 4 pilot crew, all 4 will be in the cockpit for takeoff and landing, they will all rotate for a break during the flight. The return trip will typically be operated by the two pilots who were in the observer seats. So if crew A operates LAX-SYD and crew B is the relief crew in-flight, then on SYD-LAX crew B will operate and crew A will be the in-flight relief.
Hope that helps
sq_ek_freak
Tue Dec 29, 2009 2:08 am
Quoting Flyer732 (Reply 5):
Yep, the relief crew are also sometimes called the augmenting crew. For instance, on a tag on flight, let's say DXB-MEL-AKL-MEL-DXB, crew A would fly DXB-MEL, layover, crew B would do MEL-AKL-MEL as a turn, then crew A do the MEL-DXB run back to home base.
Ha! But yes, no sharing of rooms at all, unless by choice which doesn't always mean the obvious...I have slept over in fellow crew's rooms, especially when flying with really good friends! A sleepover if you will  Wink
Keep Discovering
don
Tue Dec 29, 2009 3:25 am
That would be too much. They book 16 rooms for all 16 of them. (Only one room per crew member).
Sorry, I just couldn't help it. My childish humor. On a serious note, while one per room is mostly correct, there are some airlines from developing countries that require junior cabin crew members to share rooms.
Transpac787
Tue Dec 29, 2009 4:58 pm
Ohhhh man, this is a sore spot with me on the DL front  Silly
Quoting Evan767 (Thread starter):
1. ATL-LAX 77L
Only two pilots fly the plane, while two others are deadheaded on it. So, essentially, DL has to crew this flight as if it were an international. One of their lesser-thought domestic rotations for an international route.
2. ATL-BCN 763ER
Yes. Per the DL pilot contract, a flight of 8:01 to 12:00 block time has 1 CA and 2 FO. A flight of 12:01 to 16:00 blocktime has 2 CA and 2 FO. A flight of 16:01 blocktime and longer will have 2 CA and 2 FO with mandatory minimum rest requirements both on layover and time off after the trip.
3. LAX-SYD 77L
Alright, there are two ways of doing crew rest.... the NW way and the DL way. This is currently a heated battle within the pilot's union, especially on the 747-400 and A330 as DL is trying to get the ex-NW crews to do it their way. So, crash course explanation here.
NW way of doing crew rest on double crew:
2 CA and 2 FO. Crew will discuss amongst themselves in preflight who wants to fly first and who wants to fly second. Whoever may need a takeoff, a landing, or whoever may be tired or wide awake may dictate who chooses what. Of course, if there is ever an impasse, the senior CA chooses first and the senior FO also chooses first.
To determine crew rest time, NW wanted all pilots to be in the cockpit 30 minutes prior to landing and 15 minutes after takeoff. So, you subtract out 45 minutes from the planned total enroute flight time. Just to make our math easy, lets say total air time is 13:45. So, you have a total of 13 hours available for crew rest. NW made this very simple. CA 1 and FO 1 flew for the first 6:30, while CA 2 and FO 2 were in the bunks. The second half of the trip, CA 2 and FO 2 would fly, while CA 1 and FO 1 went to the bunks. At the end of the flight, CA 2 and FO 2 remain as the pilots flying, while CA 1 and FO 1 sit in the jumpseats.
DL way of doing crew rest on double crew:
The most senior captain of the trip is to designate either himself or the junior captain as the "pilot in command" for the flight. The "PIC" is the only captain to sign the dispatch release, despite both CA's being equally as qualified to sign it (not to mention just as easy). The "PIC" will designate, without any form of group decision-making process, which CA will fly first and which FO will fly first. It does not matter if any particular CA or FO is short on takeoffs or landings, whatever the PIC dictates is how the trip will be flown.
DL further allows the PIC to institute any sort of inflight rest-rotation s/he deems they want. If they want to split the available rest time in half, that is their call. DL recommends, however, that the crews switch seats often, taking only 2 hour naps in the bunks at a time.
Now, here is the kicker that NW crews absolutely hate. Given the DL system of 1 captain being "pilot in command", and the other captain being a "relief captain", there are some bizarre procedures for takeoff and landing. Per the DL system, the PIC *must* be in the captain's seat for takeoff and landing. To explain what I mean, here's a quick scenario.
ATL-NRT on a 777, over 12:01 blocktime so full double crew. CA 1 and FO 1 will fly the takeoff and first half, while CA 2 and FO 2 sit in the jumpseats. On the second half, CA 2 and FO 2 will fly the aircraft while CA 1 and FO 1 go to the bunks. 30-40 minutes out from NRT, CA1/FO1 will come back from the bunks, and CA 1 will get back into the captain seat, while CA 2 sits in the jumpseat. FO 2 remains in the right seat, while FO 1 sits in the jumpseat.
NW crews hate this system because it totally defeats the purpose of even having 2CA/2FO, whereas the system DL uses is explicitly tailored to a system of having 1CA/3FO. NW also further argues that DL's way is a poor system as the CA1 (in the hypothetically situation) has just woken up, and has NO awareness of the weather in NRT, fuel on board, diverts, any on board situations, or anything like that. This is espeically felt in NRT during typhoon season when your nearest available divert may be 2 hours away. CA 2 and FO 2 have been keeping up with these developments for the last 6.5 hours, and yet DL feels that CA 1 should be the one landing the aircraft.
So.... hopefully that's slightly better than clear as mud, haha. As it stands now, most NW crews have simply flat refused to do the DL system and both CA's still sign the dispatch release so both of them can sit in the seat for takeoff and landing.
Quoting TWFirst (Reply 4):
NW actually owned the hotel in NRT, now acquired by DL. Since they rotate no less than 150 crew members through NRT at any given time, NW felt it more economical to just buy the hotel.
Luftfahrer
Wed Dec 30, 2009 1:35 am
Quoting Transpac787 (Reply 8):
Extensive answer, thanks for that.
Deadheaded in order to fly from LAX (to SYD) later on? Or just back to their base, where their duty ends?
Can it also be 2 CAs and 1 FO, perhaps as an exception? I am almost sure I have had this line-up some months ago.
Transpac787
Wed Dec 30, 2009 4:00 am
Quoting Luftfahrer (Reply 9):
The LAX-SYD and SYD-LAX flights require a double crew, 2 CA / 2 FO. Since DL does not have a LAX 777 base, nor any current international 777 rotations into LAX, they route both the plane and the crew to LAX via the domestic segment.
They need four pilots in LAX, but only two are required for for the ATL-LAX and LAX-ATL flights. Regardless, every ATL-LAX (and return) flight on the 772LR has four pilots aboard, just two flying and two on deadhead. I'm not sure which is the more senior bid line though I'd imagine the deadhead, as those crews can fly directly to LAX from wherever they may live.
While definitely more rare, it also happens.
A good example I can think of was just last week on the 747-400 crewing. For some reason on one of the days before Christmas, there was a shortage of reserve FO's for the sports and military charter flights. The company began offering these lines to CA's, to fly as FO but to still receive CA pay for the flights. Of course, this can also happen on regularly scheduled pax flights, and frequently does. Earlier this summer the same thing happened with the SEA A330 base, where SEA-AMS was somewhat regularly crewed with 2 CA / 1 FO.
PGNCS
Wed Dec 30, 2009 4:10 am
Where do you get your information?
Why is this a sore spot with you? I just looked at your profile, and you clearly don't fly for either airline.
Transpac787
Wed Dec 30, 2009 4:23 am
Quoting PGNCS (Reply 11):
Care to challenge anything I've said??
Why would it matter to you at all, other than just permitting you to be your ever-so-typical cynical self??  Wink
Evan767
Thu Dec 31, 2009 12:46 am
Interesting, thanks for clearing that up! It does sound like the NW system is better in this case.
c5load
Thu Dec 31, 2009 2:20 am
I know in the C-5 world, we all get our own rooms due to crew rest requirements. The only we share rooms is with a waiver already put in place at the airfield we are going to. That may also be why airline pilots also get their own rooms.
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
thegeek
Thu Dec 31, 2009 3:00 am
QF do it completely differently in their 747 & A330 fleets. They have the entry level pilot position of "Second Officer". A flight more than 8 hours of stick time requires one second officer, and if duty time can be more than 12:45 then they need two. Second officers can't be in the left or right seat before top of climb or after top of descent. On the 2 second officer flights, the captain or first officer must in either the left or right seats at all times. I think a SO is legal to right seat a landing or take off but company rules prohibit this.
Also, just because a given crew has flown SYD-LAX on QF107, for example, doesn't mean the same 4 man crew will fly on to JFK. Just the Captain and FO do, and I believe that the second officers fly back with a different CA/FO rather than wait in LAX.
I presume the above applies to the A380 too, but it doesn't apply to the 767 anymore as they reduced long haul flying enough that it's just not worth having 767 second officers anymore.
XFSUgimpLB41X
Thu Dec 31, 2009 3:52 am
Whoops! Until the merger, NW flew double crew trips with 1 CA and 3 FO's... Care to revisit your statements?
Years ago they did 2 CA and 2 FO...but not for a while.
Chicks dig winglets.
Transpac787
Thu Dec 31, 2009 4:06 am
Quoting XFSUgimpLB41X (Reply 16):
Contractually it was changed to that, in practice it was quite often done with 2 CA and 2 FO due to the captain overstaff that was sloughed in attrition, not an immediate dump.
Care to revisit your accusation??
Regardless, since having become part of DL since 2008 and going back to 2 CA / 2 FO, NW crews simply reverted back to their "old ways" of doing things until DL insisted their [inferior] system of crew rest should be done, issuing several memos about it. Lucky for us though, both captains can still just sign the release and choose to do it the way it's always been done.
[Edited 2009-12-30 20:09:25]
XFSUgimpLB41X
Thu Dec 31, 2009 4:27 am
Quoting Transpac787 (Reply 17):
Us? You're a student...unless your profile is a fake.
Transpac787
Thu Dec 31, 2009 4:40 am
Quoting XFSUgimpLB41X (Reply 18):
NW.
I still take sides  Wink
XFSUgimpLB41X
Thu Dec 31, 2009 5:22 am
Quoting Transpac787 (Reply 19):
NW.
I still take sides
Do you work there? You sure try to talk like you do...
Transpac787
Thu Dec 31, 2009 5:18 pm
Quoting XFSUgimpLB41X (Reply 20):
Why would it matter, at all, if everything that I've posted is correct?? You already tried to debunk me once but failed, and are now subsequently trying alternative avenues to discredit me. Strike two  Wink
Users browsing this forum: Baidu [Spider] and 1 guest
